Convergence of a series with tests
trap101
Determine whether the series converges or diverges:
\sum ln k/ k3
now I said that this series converges by the comparison test, using ln k / k since I know that goes to 0
Would that be the right logic?
In the series, k tends towards what value? Your question is missing that information.
oh, sorry. k is tending towards ∞
\sum ln k/ k3
You haven't written enough to tell. What comparison test are you using? What convergent series are you comparing it with?
I was using a basic comparison test. And I was using ln k/ k as my convergent series. Unless ln k/ k is not a convergent series, but it is a convergent sequence though.
Maybe you confuse sequences and series. What makes you think$$
\sum_{k=1}^\infty \frac {\ln k}{k}$$is a convergent series? Just because the kth term ##\frac {\ln k} k\rightarrow 0## doesn't mean the series converges.
Actually I've been trying to straighten out that confusion, but your right I do mix them up sometimes. Ok, well by a comparison test with 1/k, that would mean $$
\sum_{k=1}^\infty \frac {\ln k}{k}$$ is a divergent series
but then that doesn't help me here because $$
is larger than
\sum_{k=1}^\infty \frac {\ln k}{k^3}$$
perhaps a limit comparison with
\sum_{k=1}^\infty \frac {\ln k}{k}$$ would work?
Use that ln(k)≤k for large k.
Yes, then that simplifies to 1/k2 which converges based off of p-series.
Thanks
On another note...what's a good way to stop confusing sequences, partial sums, and series?
Concentration.
micromass said:
Concentration.
:biggrin:
I have another quick question about the basic convergence test:
If lim an as n-->∞ ≠ 0 then Ʃ an will diverge.
is the an that is being talked about at the beginning of the theorem the "sequence" an or is it the values of the partial sum of all an that they are talking about?
trap101 said:
I have another quick question about the basic convergence test:If lim an as n-->∞ ≠ 0 then Ʃ an will diverge.
The a_{n} you are referring to is a sequence of terms. The k-th partial sum of \suma_{n} is defined S_{k}=a_{0}+a_{1}+a_{2}+...+a_{k}. I hope this clears up some of the confusion you've been having regarding series, sequences, and partial sums.
##a_n## is the nth term of the series ##\sum_{n=1}^\infty a_n##. Of course if the series starts with ##n=0## it isn't exactly the nth term any more, it's the "general term", but it is still a good way to keep things straight.
