Convergence of an infinite series
The discussion revolves around the convergence of infinite series, particularly focusing on the conditions under which a series converges or diverges. Participants explore examples such as the harmonic series and p-series, examining the implications of terms approaching zero and the rates at which they decrease.
  • One participant questions why a series with terms tending to zero does not necessarily converge, prompting a discussion on the nature of convergence.
  • Some participants cite the harmonic series as a key example of a divergent series despite its terms approaching zero.
  • Others argue that the rate at which terms decrease is crucial for convergence, with references to the p-series as a specific case where convergence depends on the value of p.
  • A few participants propose that intuition about adding smaller and smaller terms can be misleading, emphasizing the need for a deeper understanding of convergence criteria.
  • Some contributions highlight the relationship between the harmonic series and integrals, suggesting that the integral test can provide insights into convergence behavior.
  • One participant introduces Ramanujan summation as a method to analyze divergent series, suggesting it offers a different perspective on convergence.
Participants generally agree that terms of a series must approach zero for convergence, but there is no consensus on the implications of this condition. Multiple competing views exist regarding the importance of the rate of decrease of terms, and the discussion remains unresolved on the broader implications of these observations.
Limitations in the discussion include varying interpretations of convergence criteria, dependence on specific examples, and the complexity of mathematical proofs related to series convergence.
This discussion may be useful for students and enthusiasts of mathematics, particularly those interested in series convergence, mathematical reasoning, and advanced summation techniques.
Jazzyrohan
For a series to be convergent,it must have a finite sum,i.e.,limiting value of sum.As the sum of n terms approaches a limit,it means that the nth term is getting smaller and tending to 0,but why is not the converse true?Should not the sum approach a finite value if the nth term of the series is tending to 0?
This is in relation to the preliminary test for convergence of infinite series.
I believe the sum of ## \sum\limits_{n=1}^{+\infty} \frac{1}{n} ## does not converge. This is a good example of why the converse is not true.
I guess the standard example here is the harmonic sum: ##\sum_{n\in\mathbb{N}}\dfrac{1}{n}## does not converge.
I am aware of the example but what is the reason of its sum being infinite?Since it's terms are getting smaller,shouldn't the sum approach a finite value as only smaller and smaller values are getting added?
Obviously not. The reason lies in its proof. Intuition often fails for terms like infinity. You add less and less, but you add something.
Is that not true for every series(even convergent ones)? We keep adding something,even if it's less but still the convergent ones approach a finite value.
Is it related to the rates at which the term is getting smaller?
Sure, it is true for convergent series, too. What do you want to know? ##\sum \frac{1}{n^2}## converges, ##\sum \frac{1}{n}## does not. So?
It's just not that simple. Clearly the terms have to go to 0 or the series will not converge. But that is not enough. The terms have to go to zero fast enough. A simple example to consider is:
##\Sigma a_n##, where
##a_1 = 1##
##a_2 =a_3 = 1/2##
##a_4 = a_5 = a_6 = 1/3##
And if you don't like that so many are equal, you can have them decrease by tiny amounts.
FactChecker said:
It's just not that simple. Clearly the terms have to go to 0 or the series will not converge. But that is not enough. The terms have to go to zero fast enough. An simple example to consider is:
##a_1 = 1##
##a_2 =a_3 = 1/2##
That's what I was asking earlier that the rate of decreasing must be fast enough,for example,the p series converges for p>1 as the terms are decreasing at a rate that they are going to hit a limit but for p<1,the terms are not decreasing fast enough.This change occurs at close to p=1 at which the terms just lose the rate required for them to converge.
Am I thinking right?
I have to assume that "p series" means power series ##\Sigma \frac1 {p^n}##. Then you are correct. It converges for ##p>1## and diverges for ##p<1##.
It can be shown using the fact that the partial sum of a geometric series is ##S_n=\sum_{(k=0)}^nr^k=\frac{(1-r^{(n+1)})}{(1-r)}##
Here's maybe a more intuitive way of looking at it: let [itex]a_n[/itex] be any sequence that tends to infinity, but for which [itex]a_{n+1}-a_n[/itex] tends to zero (for example, [itex]a_n=\sqrt{n}[/itex] or [itex]a_n=\log(n)[/itex] work). Then [itex]\sum_{n=1}^\infty (a_{n+1}-a_n)[/itex] diverges to infinity but its terms tend to zero.
For any ##n\in\mathbb{N}##, no matter how large, you can find a number ##k\in\mathbb{N}## such that ##\sum\limits_{m=0}^{k}\frac{1}{n+m} > 1##. From this it should be easy to see that the harmonic series approaches infinity.
look at the terms of the harmonic series and group them in sets of 1, 2,4,8,16,... terms, i.e.
1/2 + (1/3 + 1/4) + (1/5 + 1/6 + 1/7 + 1/8) +...
you can see that the terms in each grouping add up to at least 1/2.
i.e. 1/3 + 1/4 ≥ 1/4 + 1/4 = 1/2, and (1/5 + 1/6 + 1/7 + 1/8) ≥ (1/8 + 1/8 + 1/8 + 1/8) = 1/2, ...etc
since there are infinitely many of these groupings, the full sum is infinite.
On another note: The Riemann integral [itex]\int_{t=1}^{N}\frac{1}{t}dt=\ln(N)[/itex] can be approximated pretty good with the series [itex]\sum_{n=1}^{N-1}\frac{1}{n}[/itex]. Thus [itex]\sum_{n=1}^{N-1}\frac{1}{n}\approx \ln(N)[/itex]. It can be proved that [itex]\lim_{N\rightarrow \infty}(\sum_{n=1}^{N-1}\frac{1}{n} - \ln(N))=\gamma[/itex] where γ (the Euler-Mascheroni constant) ≈ 0.57721566490153286060651209008240243104215933593992... (https://en.wikipedia.org/wiki/Euler–Mascheroni_constant).
indeed since the function 1/x is decreasing, it follows that the integral of 1/x from n-1 to n, is less than 1/(n-1) and greater than 1/n. Hence the integral from 1 to n, i.e. ln(n), is less than 1 + 1/2 + 1/3 + ...+1/(n-1) and greater than 1/2 + 1/3 +...+ 1/n. Thus since the integral approaches +infinity as n does, so is the series. And the difference 1 + 1/2 +...+1/n - ln(n) is increasing and always ≤ 1. (Just look at the graphs of these functions.) Hence this difference converges to some limit less than 1, which limit is the definition of the euler constant. It was given as a homework problem in my first year calculus class in 1960, to decide whether this limit is rational, a question I learned was (and is still) an unsolved problem. Of course it was remarked that "undying fame" awaited the solver of that homework problem.
I did give this in my thread on summing divergent series but there is a method that can sometimes be used to tell if a series is divergent and tell us a bit more about the divergence - Ramanujan Summation. It's based on the Euler-Maclauren series; a not what I would call rigorous, but short, derivation I will now give. Define the linear operator Ef(x) = f(x+1). Define Df(x) = f'(x). Also f(x+1) = f(0) + f'(x) + f''(x)/2! + f'''(x)/3! ... (the Maclauren expansion), or Ef(x) = f(x) +Df(x) + D^2f(x)/2! + D^3f(x)/3! ... = e^Df(x). We Also need the Bernoulli numbers which are defined by the expansion of x/(e^x - 1) = ∑B(k)*x^k/k! - you can look up the values with a simple internet search.
f(0) + f(1) + f(2) ... f(n-1) = (1 + E + E^2 ++++++E^(n-1))f(0) = (E^n -1/E-1)f(0) = (E^n -1)(1/e^D -1)f(0) = D^-1*(D/e^D -1)f(x)|0 to n = D^-1f(x)|0 to n + ∑ B(k)*D^(k-1)f(x)/k!| 0 to n = 0 to n ∫f(x) + ∑B(k)*D^(k-1)f(n)/k! - ∑B(k)*D^(k-1)f(0)/k!. Now the sum is from 1. Let n → ∞ and most of the time Sn = ∑B(k)*D^(k-1)f(n)/k! → 0 so we will assume that - certainly its the case for most convergent series since,usually, d^n/dx f(n) → 0 for all n. So you end up with ∫f(x) - ∑B(k)*D^(k-1)f(0)/k!. So f(0) + f(1) + f2) +f(3) ...= ∫f(x) - ∑B(k)*D^(k-1)f(0)/k!. Notice regardless of n (- ∑B(k)*D^(k-1)f(0)/k!) does not depend on n and is called the Ramanujan sum. Again note the sum is from 1. We would like the Ramanujan Sum to be the same for convergent series. This is done by defining it as ∫f(x) + C where C is the Ramanujan sum. If it is finite then it is ∫f(x) + C. If it is infinite it is defined as C.
It makes mincemeat out of summing the Harmonic Series. 1/n → 0 as n→∞. Same for the derivatives. So that part is satisfied - ie you can neglect the middle bit and get Σ1/n = ∫1/x+1 +R where R (the Ramanujan Sum) is the Euler-Mascheroni constant. You see immediately its (1 to ∞) ∫1/x + R after a change of variable x' = x+1 we have In (∞) + R'
You get a deeper appreciation of what's going on if you use Ramanujan summation on the zeta function ζ(s):
https://en.wikipedia.org/wiki/Riemann_zeta_function
If s>1 its convergent (integral test) and you get ζ(s): = (0 to ∞)∫1/(x+1)^-s + R where R is the Ramanujan sum. But a little work with integration shows this is 1/(s-1) + R and is true for any s > 1. So one gets ζ(s) - 1/(s-1) = R. Now the trick; R is holomorphic in the complex plane so can be extended to the entire plane. So we have ζ(s) = 1/(s-1) + R valid for the entire plane except for a non-removable singularity at s =1 ie the Harmonic series. By analytic continuation do things like 1+1+1... become finite? I will leave that for you to ponder - there is an ∞ - ∞ hidden deep in there. But there is no trick I am aware of to get rid of that singularity - some divergent series you can use tricks (a bit more of that later) to sum it and get sums for things like 1 +1 +1 + 1... which is obviously not summable - or is it? See later.
There is another function called the Eta function defied by η(s) = 1 - 1/2^s + 1/3^s - 1/4^s ... (Note by the alternating series test this is convergent for s>0). Now one can easily derive a simple relation between the two:
https://proofwiki.org/wiki/Riemann_Zeta_Function_in_terms_of_Dirichlet_Eta_Function
We have ζ(s) = 1/(1 - 2^(1-s))*η(s). Which make ζ(s) convergent for s>0 except for s = 1. What happened? Well in the derivation you started with ζ(s) - η(s) so divergences may cancel and you are left with a finite number. Of course that finite number must be the number from analytic continuation - so really you have a hidden infinity cancellation - somehow..
This is very easily seen in 1 + 1 + + 1 ... Its obviously ∞. But wait using the above equation you have 1 + 1 + 1 ... = (1 - 1 + 1 - 1...)/-1
Now 1 - 1 + 1 - 1...is called Grande's Series and is in fact 1/2. Some simply can't see this so I will explain it very carefully. 1 - x + x^2 - x^3... is convergent for |x|<1 (ratio test) and is 1/(1+x). It is not convergent for x=1. But wait - how about if x = 1-1/n then it is convergent for all n. If n is very large - (you know typical non rigorous calculus stuff) you have for all practical purposes 1/n is zero - in fact if you want you can take the limit n→∞. So intuitively, and for all practical purposes 1 - 1 +1 -1 + 1... = 1/2. Rigorously we can generalize Abel's theorem and take the limit x- → 1:
https://en.wikipedia.org/wiki/Abel's_theorem
Some however say things like S = 1 - 1 + 1 - 1...1 - 1 + 1 - 1... = S + S or S =0 so is inconsistent. Well the answer lies in the definition of an infinite sum which says you can't do that except in some cases - but that would take us off topic. I simply wanted to show its very reasonable if its 1/2 - in fact so reasonable it can't really be anything else.
In fact its an example of a summation method called Abel Summation - but that will take us too far.
The thing to note is 1 - 1 + 1 - 1... = 1/2 so 1 +1 +1 +1 ... = -1/2. The infinity in 1+1+1... must be canceled by something - it's in the Eta function - somehow it cancels it out.
Have a bit of a muck around using Ramanujan summation and look at ζ(s) - η(s). I haven't done it so see what you find out.
Thanks
Bill
  • · Replies 17 ·
