Conversion of sound signal to electrical signal
Converting sound signals to electrical signals for practical applications like lighting is highly inefficient due to the low energy density of sound. Most speakers operate at less than 0.5% efficiency, making it impractical to generate significant electrical power from sound alone. Capturing sound energy to power devices like light bulbs would require an enormous amount of sound energy, far beyond typical levels. A more feasible approach is to use a condenser microphone to capture sound and then amplify the signal using an external power source. Exploring alternative project ideas may be advisable to avoid investing time in an unviable concept.
indian_tiger
Hello guys.
I was thinking of making a project in which i convert sound signal to electrical signal which can be put to use for proper electrical work like lighting a light bulb. Can anyone help me on this issue. Like if it is already in practice and feasiblity of such project and how can i go about it.:smile: :smile: :smile:
Very infeasible, sound energy density is very low unless painfully loud. So where do you get the energy source and how do you get close to it because otherwise it propagates in spherical waves and dissapates extremely quickly.
Also, the transducers, the speakers, are incredibly inefficient. A large majority of the speakers are less than .5% efficient. If the conversion from acoustical to mechanical to electrical remained the same in reverse, to light an LED you'd need like enough energy that could light a thousand or even a million LEDs if you captured the energy otherwise (like capture the heat and convert it to steam and then spin a turbine et cetera).
If you simply want to capture the sound to a low-level electrical signal and then amplify it from another electrical power source, you could just take a simple condenser microphone and build/purchase a suitable amplifier that could then drive the light bulb.
I remember my prof talking about how if everyone in New York screamed or yelled as loud as they possibly could and you could somehow contain this energy you would barely be able to light up a lightbulb.
looks like i am on a wrong track. Maybe i have to go for some other topic or try something else in this regard. Guys if you know something else about it please let me know, so that i don't waste much of my time on doing a project which ultimately yields nothing.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
