Converting a splitter from parallel to series.
  • Thread starter Thread starter wasteofo2
    Parallel Series
Using a splitter to combine signals from two guitars into one amp can lead to volume loss when connected in parallel. Attempting to rewire the splitter in series resulted in one strong and one weak signal, indicating improper configuration. Experts suggest that isolation through a mixer is the best solution for combining signals without losing quality. Connecting outputs directly together is not advisable, as it can lead to interference and signal blocking. A mixer is recommended as an effective and simple way to achieve the desired sound without compromising volume.
wasteofo2
So I've got this splitter that's I've been using to take the signal from 2 guitars and combine them into one so I can plug them both into one amp. However, when going form 2 to 1, it conjoins the signals in parallel, so they both lose volume. I took it apart, and tried to connect it in series. It ended up looking like this:
http://img169.imageshack.us/img169/5975/circuitpz6.jpg
The result was that the input jack connected directly to the out gave a full signal, and the other gave a much weaker one. There must be a simple way to do this, but I'm stupid.
Any help would be appreciated,
Jacob
wasteofo2 said:
…So I've got this splitter…
I’m not into audio stuff but in general the output of electronic devices should not be connected together but should be isolated from one another. From your drawing, the splitter is not appropriate for what you are trying to do. I believe you want a $5.00 mixer as in this link:
http://search.ebay.com/guitar-mixer_W0QQfnuZ1QQfsooZ1QQfsopZ3QQxpufuZx
I have to agree there, and not just because Geniere is the expert in this matter. Isolation through a mixer is the proper way to go. If you absolutely have to combine the signals, I'd think that parallel is far more desireable that series. At least you're getting some sort of proportional mix that way, as opposed to stacking signals on top of each other, some of which probably block others.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
