- #36
Bystander
- 1,705
Originally posted by arcnets
I have done some more experiments.
First, I used pure water (just simmering) and tried to reproduce the effect with salt, then with sand.
Observation: No effect(!)
Then I remembered, in the original experiment I had some molten butter in the water.
I tried to reproduce that.
Observation: With salt only a small effect (if any), with sand no effect.
Next, I thought, what else was there in the original experiment? The noodles, of course. But also 2 spoons of 'Instant Fleischbrühe' (German for 'meat extract powder').
Sorry to bother you with these 'unphysical' ingrediences, but what influences may they have?
Still puzzled...
Several points (of many possible): 1) you are dealing with a heat transfer process, and the degree of superheat you can establish in the pan/pot/cauldron is going to be proportional to the magnitude of the enhanced boiling effect you observe --- translated to English, turn the burner up to full blast; 2) the butter and noodles may have contributed to the superheat at simmer by quenching the pot's built in nucleation sites with butter, and by reduced thermal conductivity of the water-butter-noodle system; 3) butter on the surface is probably going to quench nucleation sites on sand as it enters the mix; 4) "3)" suggests a couple other experiments you can try (I hope you're treating this with the respect due something that can scald you rather severely) --- at full heat (max superheat), try the salt, the sand, and wetted salt and wetted sand (I'd say a slurry in a teaspoon with enough water that you can dump the slurry rather than having to snap it into the water); 5) once you get the sand to work, if you've got a thermometer that let's you read to tenths of a degree at 100 C, try measuring temperature at the bottom of the pan for a) water, b) water plus salt, c) water plus salt plus sand, and d) for the last mess after you've let it cool, and brought it back to a boil.
Don't run your utility bill up too much, but have fun.
