- #246
bobob
- 100
Ontology. If we can't measure something in principle, then neither can nature.
DarMM said:A short article from Griffiths:
https://arxiv.org/abs/1901.07050
Demystifier said:If the point of interpretations is not to make measurable predictions (because we already have the unambiguous quantum formalism for that), then what is the point of interpretation that is not intuitive?
The original EPR argument doesn't violate nonlocality because it has a local model right?stevendaryl said:I don't think that Griffiths' argument in section 2.2 is at all a fair rebuttal to the argument that EPR violates nonlocality
I think this is trivially avoided in Bohr and Neo-Copenhagen with the wavefunction being epistemic. The whole EPR argument can be repeated in Spekkens toy model or many other local hidden variable models. Similarly they have a collapse but nothing is nonlocal.stevendaryl said:The measurement here causes an instantaneous change there
I think his argument is more in section 5.2 that nonlocality arises from presuming a common sample space/realism for the observables. It's alternate way out from nonlocality.stevendaryl said:Griffiths' argument in section 2.2 seems to be completely missing the point. Yes, a collapse interpretation doesn't violate locality if you don't have a distributed state
DarMM said:The original EPR argument doesn't violate nonlocality because it has a local model right?
DarMM said:Just to be clear, what ultimately is your argument in this thread. Is it that contrary to conventional wisdom that giving up conventional realism doesn't save locality and that QBism and Copenhagen are actually nonlocal?
For what reason do you exclude the other ways out of Bell's theorem?stevendaryl said:As far as what I personally think, it seems to me that there are only three possibilities that make any sense: (1) something nonlocal is going on, or (2) QM is wrong (or at least incomplete), or (3) something like Many-Worlds is true (in spite of what appears to be the case, multiple macroscopically different versions of the world can exist simultaneously)
DarMM said:For what reason do you exclude the other ways out of Bell's theorem?
That seems strange to me as the retrocausal and acausal approaches do manage to replicate a good deal of QM where as MWI can't get out the Born rule so replicates no predictions at all. Ruth Kastner has even managed to get out some of QED. Not that I'm convinced by them either since there are many calculations they haven't replicated as of 2019.stevendaryl said:I can't make any sense of them.
DarMM said:That seems strange to me as the retrocausal and acausal approaches do manage to replicate a good deal of QM
I can see why you'd think that but I don't think it is valid. The retrocausal views have no space like propagation and the acausal views have no propagation at all being involved in the violation of the CHSH inequalities.stevendaryl said:I lump those in with being nonlocal. If you have effects traveling both forward and backward in time, then spacelike separations are no impediment. A spacelike separation is a combination of two timelike separations, if you allow both directions in time.
However despite people attempting to prove this is a contradiction nobody has produced a mathematical theorem to that effect, that was the purpose of Frauchiger-Renner and spin offs.When I say "Many-Worlds" I mean in general, theories in which measurements results and macroscopic variables don't have definite values, that you can have superpositions of macroscopically distinguishable states. To me, this is just a consequence of QM. There is nothing in QM that limits the size of system to which it applies. So it's actually inconsistent (what I've called a "soft inconsistency") to assume QM applies to everything and also that measurements have definite outcomes.
The Born rule is needed to derive the macroscopic worlds being classical at all, so the problems go quite deep.But I certainly appreciate the problems with that: If measurements don't have definite outcomes, then it's tough to make sense of Born's rule.
DarMM said:I can see why you'd think that but I don't think it is valid. The retrocausal views have no space like propagation and the acausal views have no propagation at all being involved in the violation of the CHSH inequalities.
The Frauchiger-Renner arguments don't fail for fuzzy reasons though, but due to specific mathematical properties of the theory like intervention sensitivity.stevendaryl said:The foundations of QM are too fuzzy to derive a tight contradiction. That isn't a plus, in my opinion
Certainly, but the acausal views don't have nonlocal interactions or nonlocal degrees of freedom so they simply are not nonlocal.stevendaryl said:Well, for the sake of categorization, there are two rough categories: (1) normal causality, in which the future is affected by the past lightcone, and (2) everything else.
I've read this now and a few of its references. It derives the same kind of trade off we've been discussing here, but in the language of causal networks. You recover locality, but at the cost of embedding the observer/the notion of agent into the theory.atyy said:
I think Griffith's argument is a bit more than this in light of his Section 5.stevendaryl said:My point is that Griffiths' is misunderstanding the EPR argument if he thinks that showing that violations of Bell's inequality can be achieved for situations that are intrinsically local. That's got things backwards. The Bell argument isn't that nonlocality is required to violate his inequality. There is no problem with coming up with a causal model that violates it locally. The difficulty is coming up with a causal model that violates it for spacelike separated observables.
What you have described here is not Copenhagen. What you have written is very much closer to the notion of Complementarity (as promoted by Wilczek, et al). A litte more about this below, but to circle back to Copenhagen briefly,Demystifier said:The so called "Copenhagen" interpretation of QM, known also as "standard" or "orthodox" interpretation, which is really a wide class of related but different interpretations, is often formulated as a statement that some things cannot be known. For instance, one cannot know both position and momentum of the particle at the same time.
But on other hand, it is also not rare that one formulates such an interpretation as a statement that some things don't exist. For instance, position and momentum of the particle don't exist at the same time.
Which of those two formulations better describes the spirit of Copenhagen/standard/orthodox interpretations?
Actually, Quantum Bayesianists would explicity state that the restrictions do not apply to ontology. (I'm not an advocate myself) but they would say that any and all of these restrictions derive from the observer's knowledge.Demystifier said:To be sure, adherents of such interpretations often say that those restrictions refer to knowledge, without saying explicitly that those restrictions refer also to existence (ontology).
I am not sure you have characterized Bell's Theorem correctly here, but I wanted to say something else.Demystifier said:Moreover, some of them say explicitly that things do exist even when we don't know it. But in my opinion, those who say so are often inconsistent with other things they say. In particular, they typically say that Nature is local despite the Bell theorem, which is inconsistent. It is inconsistent because the Bell theorem says that if something (ontology, reality, or whatever one calls it) exists, then this thing that exists obeys non-local laws. So one cannot avoid non-locality by saying that something is not known. Non-locality implied by the Bell theorem can only be avoided by assuming that something doesn't exist. Hence any version of Copenhagen/standard/orthodox interpretation that insists that Nature is local must insist that this interpretation puts a severe restriction on the existence of something, and not merely on the possibility to know something.
The point of a non-intuitive interpretation is to change one's intuition to match the physics. The ether was an intuitive interprettion, but there was no physics in an ether theory and the intuition it imparted leada to incorrect physics without adding more baggage to eliminate it. Similaly in quntum mechanics, a limitation on what nature can specify contains real physics. Trying to evade it (e.g., bohmian mechanics) should lead to different physical predictions. If it does not, then it's only intuitive to the extent that the intuition it provides is wrong and actually elimintes the real physics. The only difference between an intuitive interpretation and a non-intuitive one is that intuition sometimes follows from having to accept new physics that has no counter part in everyday intuition to analogize.Demystifier said:If the point of interpretations is not to make measurable predictions (because we already have the unambiguous quantum formalism for that), then what is the point of interpretation that is not intuitive?
Just to expand on this, in my understanding the PBR theorem says if you want a theory obeying the ontological models framework's axioms to match quantum mechanical predictions and preparation independence then the state space of the theory has to include the wavefunction.hyksos said:Perhaps the objective element-of-reality we seek is the Quantum State (PBR Theorem)
To me, non-local is not the same category as retrocausal, precisely because the former need have no causality outside the past light cone (nor back in time influences), while retrocausal explicitly does.stevendaryl said:Well, for the sake of categorization, there are two rough categories: (1) normal causality, in which the future is affected by the past lightcone, and (2) everything else.
How would anybody be able to determine this one way or the other?Demystifier said:What evidence do we have for the claim that the real stuff cannot be described mathematically?
PAllen said:To me, non-local is not the same category as retrocausal, precisely because the former need have no causality outside the past light cone (nor back in time influences), while retrocausal explicitly does.
This isn't true if retrocausal influences occur only within the light cone.bobob said:Unfortunately, that reasoning is flawed. If events are spacelike seperated, then a lorentz transformation can make them simultaneous or make either event occur before the other. So, if you assume one event causes the other, you can make a lorentz transform to a frame in which that is false, which requires the event you assumed was the cause to act retrocausally. That is what non-local means.
The argument is essentially the failure of hidden variable theories and how fine-tuned they have to be. However like most interpretative arguments it's not definitive.bohm2 said:How would anybody be able to determine this one way or the other?
DarMM said:This isn't true if retrocausal influences occur only within the light cone.
DarMM said:The argument is essentially the failure of hidden variable theories and how fine-tuned they have to be. However like most interpretative arguments it's not definitive.
Yes, but retrocausal theories don't have propogation at spacelike distances. Only at timelike distances. They simply don't have spacelike propogation so there is no point arguing about it. This is exactly the feature that makes them different from nonlocal theories.bobob said:(1) Huh? If you have spacelike separated events, the events cannot be time ordered. Therefore, the time odering is frame dependent and in particular can be made simultaneous. Neither can be the cause of the other. Neither is in the others light cone.
The part in bold is not necessarily true. Retrocausal theories (see Ruth Kastner's papers and books for an example) have events in both directions of the light cone causing the each other in a sense and yet preserving Relativity.bobob said:(2) Events which are within each other's light cone are, by definition, time ordered. If there is a cause and effect, which is the cause and which is the effect are defined by their time ordering. Retrocausal in this case would mean closed timelike world line, since all of the world lines connecting causes and effects are timelike.
To state otherwise is to flat out say relativity is incorrect.
I agree with their statements on this. I think the best version of hidden variable theories are ones where the experimental imprecision required to mask signalling is a result of some kind of thermalization or equilibrium process.atyy said:Hidden variables must be in some sense "fine tuned" as proved by Wood and Spekkens. However, they also argue that some forms of fine tuning are more acceptable than others
DarMM said:On a personal note I think such thermalization/equilibrium hidden variable theories might be the last "hope" for a realist account of subatomic physics. If they are proven to fail (i.e. it is demonstrated such thermalization cannot occur) I think we are driven to Copenhagen or QBism. I get the impression people like Robert Spekkens and Matthew Leifer have similar views, though perhaps not.
atyy said:It is argued [by Valentini] that one can still recover the standard distribution of configurations on a coarse-grained scale as a result of dynamical evolution
Valentini's argument is faulty; see this post. Much improved arguments would be needed to prove thermalization.DarMM said:I think such thermalization/equilibrium hidden variable theories might be the last "hope" for a realist account of subatomic physics. If they are proven to fail (i.e. it is demonstrated such thermalization cannot occur)
I assume there there is no causal relationship between E2 and E3 as I defined them, and this was explicitly stated in my post.bobob said:Unfortunately, that reasoning is flawed. If events are spacelike seperated, then a lorentz transformation can make them simultaneous or make either event occur before the other. So, if you assume one event causes the other, you can make a lorentz transform to a frame in which that is false, which requires the event you assumed was the cause to act retrocausally. That is what non-local means.
I fully agree, I don't think the required thermalization/equilibrium process has been demonstrated either in nonlocal or retrocausal theories.A. Neumaier said:Valentini's argument is faulty; see this post. Much improved arguments would be needed to prove thermalization.
But the past cannot be observed either, and becomes more and more uncertain as one goes back in time.jocarren said:Then the past can be viewed as deterministic
