Core Material for Long-Run Solenoid Circuits
For a long-run solenoid circuit, selecting the right core material is crucial to manage heat and maximize efficiency. Iron is recommended for its high magnetic permeability, making it suitable for strong electromagnets with minimal power consumption. However, alternatives like powdered iron or nickel-iron cores may offer better efficiency and lower hysteresis for applications requiring rapid on-off cycling. The use of a capacitor in parallel is essential for controlling the frequency of the circuit, as it affects the discharge intervals and overall performance. Ultimately, the choice of core material should balance availability, cost, and the specific magnetic properties needed for optimal operation.
Phaedrus
http://img16.imagevenue.com/img.php?loc=loc76&image=054_doorbell1.jpg
I am building a circuit such as the one above. The only difference is that it will be running for long periods of time. So heat becomes an issue. To make the most efficient and strongest electromagnet I am wondering what I should be looking for in core material. The cores will be 5/16" x 1 1/4" wrapped with 22 or 24 ga. magnet wire. This will be a DC circuit with voltages between 3-8 volts at around 1 amp give or take. Operating frequency will be between 80-160 Hz for long periods of time...like 20 minutes or more. There can be between 228-304 turns per coil...Not sure about this as the permeability and saturation is different for each core material. Also I'm trying to keep the resistance under 1 ohm per coil. If it means anything I will be using a capacitor in parrallel to the coils to catch the spark...usually a 30v 47uf.(incidentally if anyong can explain to me why changing the cap. value has such a drastic effect on the htz it would be greatly appreciated...I mean the cap. must be doing something besides just catching the spark...)
well, I am probably not as experienced as other people on this forum, but ill give my 2 cents
For the core, i think iron would be the best, it has the highest magnetic permeability, so you will get the strongest electromagnet possible, without using too much power in the coils. An ironm bol will work just fine and i find that the ones that are threaded just make winding the wire easier as it will give it some uniformity(not that it matters too much anyways)
As for the capacitor, it will probably be essential in creating the desired frequency of ring because capacitors discharge at constant intervals, so having a cap that will discharge every 120hz for example will cause the dc current moving towards the magnet to pulsate at 120hz, now this could be completely wrong, as i have little experience with capacitors
Iron is what I'm using now. I was wondering if there are better materials or alloys that would lend themselves better to this application...for lowest hysterysis...highest permeability...etc. Thanks for the reply.
i don't know its exact composition, but it is used in the deflection of electrons on the back of a TV tube..
it is a dark , kind of brittle material , which has outstanding magnetic properties.. maybe you could crush it up and form it to the shape that you want with some polyester resin..
that seems a bit overkill just to make an electromagnet(unless u need it to be super powerful with the very least amount of energy), anyways out of all the common materials you can easily get, iron is best
I agree iron is the best overall as far as availability and cost go. But what if I wanted to increase the efficiency of the coil...more efficiency = less voltage=less heat. I've been researching and have come across powdered iron cores...nickel iron cores...etc. Cost is not an issue. What I am looking for is a lead on what would give me the greatest flux density and since this will be turned off and on about 100 times per second I need the least amount of hysteresis...the least amount of magnetic memory...etc.
thanks
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
