Cosmological constant as a perfect fluid
EDerkatch
Hi everyone,
If anyone could point me in the right direction with this problem I'd really appreciate it.
"Show that the cosmological constant can be interpreted as a perfect fluid having an equation of state w=-1."
I have a rough idea of how to do the second part of the proof: if the cosmological constant can be interpreted as a perfect fluid then
ρ(dot)+3(a(dot)/a)(ρ+P)=0 (conservation equation)=>ρ+P=0 due to the continuity of a perfect fluid.
But how do I show that it can be interpreted as a perfect fluid?
My guess is if you can show that everything works the same if you interpret it as a perfect fluid and do your magic (whatever you just did), then you just showed that it can be interpreted that way.
What I mean is, you make the guess that it can, do some math, and if everything works out the same, then your assumption is valid.
If w=(-1) for a perfect fluid then rho+p=0. So by the conservation equation rho(dot)=0. Hence it's a constant. A 'cosmological constant'. Perhaps I don't understand the question?
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
