Could 9th Harmonic Be Causing Noise on Local Telephone Company's System?
  • Thread starter Thread starter WFO
    Bell Harmonic
The discussion centers on the identification of a significant 9th harmonic affecting a local telephone company's system, attributed to power line issues. The primary suspect for the harmonic is the presence of cathodic protection systems associated with pipelines in the area, rather than the 1200 Hp gas line pump, which does not contribute to the harmonic when inactive. Participants suggest exploring filters for mitigation, with a focus on equipment that the telephone company can implement directly. Grounding practices and the potential influence of line conditioners installed by the power company are also highlighted as areas for further investigation.
  • Understanding of harmonic distortion in electrical systems
  • Familiarity with cathodic protection systems
  • Knowledge of grounding techniques in electrical installations
  • Experience with line conditioning equipment
  • Research available harmonic filters suitable for telephone systems
  • Investigate the impact of cathodic protection on power quality
  • Learn about grounding best practices for substations
  • Explore the functionality and installation of line conditioners
Utility engineers, telecommunications professionals, and electrical technicians involved in power quality management and harmonic mitigation strategies.
WFO
We have a local telephone company complaining to our utility that they have noise on their system. We have investigated and found a fairly significant 9th harmonic on the power line. This seems to play havoc with phone systems.
What is a likely cause of a 9th harmonic? We are a rural utility with little industrial load. The area in question, however, has a lot of pipelines and cathodic protection.
I understand there are filters readily available. Where are they to be found and how much are they likely to cost?
What types of industrial load do you have. I would think it's coming from some type of equipment.
http://www.nepsi.com/pmfilt.htm"
The only industrial load is a 1200 Hp gas line pump, which does not appear to be the culprit (i.e., the harmonic still exists when the pump is down). The rest of the area is rural load.
The link was good, but I was looking for something the phone company could put on their equipment.
If you are very rural, the power company may have installed a line conditioner (step-up transformer) to combat voltage drop over long runs. There is one 1/10th of a mile from me. The power company had been trying to serve this entire road with a single-phase hot line and a ground, but the boom in housing out here made that a problem. I don't know if such equipment could induce such a harmonic, but that would be place to start.
Is the telephone equipment in a substation? You might to be able to use some type of optical isolation equipment but you are going to have to share a common ground. If the equipment is in a substation, have you looked at how well you're grounding?
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 39 ·
15K
10K
  • · Replies 133 ·
28K
