Could Deforistation lead to lack of ability to light fires?
  • Thread starter wasteofo2
  • Tags
    Lead Light
In summary: Most oxygen in the air is produced by algae, not rainforests. If all of the oxygen production in the world was stopped, and the remaining oxygen was completely consumed, then sure forest fires wouldn't be able to light. But then again we'd all be dead. Trees included.We need about 0.16 atmospheres partial pressure of oxygen to remain conscious.
wasteofo2
478
The rainforest produces a good amount of o2 (exactly how much I'm not sure), could deforistation of the rainforest lead to such a decrease of o2 in the air that fires wouldn't be able to light? About how much could the percent of o2 in the air vary before fires stopped being able to burn?
Chemistry news on Phys.org
Don't trees consume as much oxygen at night as they produce during the day? I heard something like that somewhere...might have been TV.
Yes, algae produces about 70% of the worlds o2 and the rainforests produce about 20%. I'm not saying eliminating all the o2, but if let's say, the current amount of o2 in the air (about 21% or so, right?) was reduced to something like 19%, humans would, as a whole, be fine.
Bassically what I'm asking is: what percent of the air does o2 need to make up for fires to burn?
Depends entirely on air flow. If you have massive amounts of air flow, you can have a roaring fire with very low concentrations of O2. If you have poor air flow, higher concentration of O2 in the air is needed.
what about in your house, with presumably no airflow or very little, perhaps that caused by central air, a fan or a draft.
- Warren
Care to put that in terms of percent, or does that bassically mean 16%?
You can't just express it in percent -- it depends on the pressure. For example, at 1 atmosphere of total pressure, here on the surface of earth, I need a 16% fraction of 02 to stay conscious.
If I dive to 33 feet in seawater, I am exposed to 2 atmospheres of pressure. There, I can survive with only an 8% fraction of 02.
- Warren
16% assuming that the air pressure is at 1 atm.
Alright, I understand that, so bassically if all the rainforests were completely destroyed without any other loss of vegetation we could just remain concious
Or we could pressurize our living environments.
- Warren
- Warren
By doing what, living in underwater colonies, building domes around cities?
Do you happen to know the atmospheres partial pressure needed to light a fire?
Depends on the fuel.
- Warren
the fuel being oxygen in the air, or did you mean like wood/oil?
The oxygen is (not suprisingly) the oxidizer. The fuel is the wood, oil, or other substance which is oxidized by the oxidizer.
- Warren
Well how much difference is there between different sources of feul, for instance, wood and oil.
A huge difference.
- Warren
So how much atmospheres partial pressure do you need to sustain a wood fire and an oil fire?
Why do you thik he would know that? It's not exactly common knowledge.
I can't answer the question directly, but try THIS site for the opposite approach. At an altitude of about 5 miles, you're above 50% of the atmosphere so the pressure is half of what it is sea level. AFAIK, climbers in the Himalayas (sp) don't have problems lighting fires.
Practically nothing discussed on this board is common knowledge. I just kinda figured how much o2 pressure you'd need to light a fire on wood would be relatively common knoweldge among people who talk about the ridiculously advanced things which are discussed on this board.
Actually most of what is discussed here is common knowledge. It's mostly at the level of undergraduate science classes. Suplemented here and there with more expert opiniongs.
How much O2 you need to light a fire is not common knowledge. Furthermore, your original question pertained to forest fires. Most of which, I believe, are triggered by lighting strikes. And I think a bolt of lighting could probably start a fire with very little oxygen. So as far as forest fires are concerned, I think the question isn't so much about starting the fire as it is sustaining it.
It's further complicated by the fact that as oxygen is reduced, the fire doesn't just go out, it is slowed.
Frankly, I think the lower limit of oxygen needed for wood to burn is quite less then that needed for aerobic organisms to breathe. Cut the oxygen level too low and you'll have a bunch of dead trees burning slowly.
Mmm, I realize that, it just seems that if you understand all this stuff which is so far beyond what the average joe can even begin to imagine, that how much o2 you need to light a fire would be fairly common knoweldge, I guess I was wrong.
I didn't say anything about forest fires, i referenced the rainforest as an o2 source, sorry if that somehow got misconstrued.
So bassically we'd all be dead before lighting fires became a problem?
That seems to contradict what chroot said, unless I misunderstood one or both of you, or my assumptions about mountain climbing are wrong.
As understood:
It's not disputed that tehre's approx 21% o2 in the air.
Chroot said you need 16 atmosphere's partial pressure of o2 to stay concious.
You're saying that there's 50% atmospheres partial pressure 5 miles up, which means that there's really only about 10.5% atmospheres partial pressure of o2.
I know mountain climbers take o2 tanks with them, but i didn't think they are constantly using them, and I'm pretty sure I recently saw photos of everest climbers who were supposed to be about 16,000+ feet up with no o2 masks on doing work.
So, where am I, you or chroot wrong?
Mountain climbers are in much better than average shape.
Very few people, if any, can survive at 25,000+ feet with no external oxygen supply. Some people may be able to survive on as little as 0.10 atmospheres partial pressure of O2, but probably not for long.
- Warren
- Warren
There was just a thing on the history channel about some early attempt to reach the sumit of everest and they said that over 16,000 feet the body starts to deteriorate. Not sure, however, whether it's due to lack of oxygen or the low temperature or the lack of air pressure or a combination of all of them plus other variables.
Well, the lack oxygen is a HUGE part of it, certainly.
BTW, my figure of 0.16 ATA PPO2 (atmospheres absolute partial pressure O2) is what is usually used by advanced mixed-gas technical scuba divers (like me). We don't mix or use any breathing gas that will produce < 0.16 ATA PPO2 at its working depth. This means that 0.16 ATA PPO2 is enough to support virtually anyone for virtually any length of time. There are certainly people who can operate just fine at 0.14, or 0.12, or 0.10 -- 0.16 is just a conservative figure, with some "safety margin" built in.
And to answer your earlier questions, there are a couple of relevant points:
1) Define "fire." Do you mean "the chemical reaction in which fuel is oxidized?" Or do you mean "flame?" The chemical reaction can exist at almost ANY partial pressure -- it'll just run very very slowly, as has been pointed out.
2) The actual partial pressure necessary for a fire to grow given some fuel is strongly dependent upon many, many factors. You can't assign a particular PPO2 to wood, say, because big logs, little sticks of kindling, and sawdust all present greatly different surface areas to the atmosphere. An oil that has a high vapor pressure will burn more easily than another. An oil that has been atomized (sprayed into tiny droplets) will burn easier than an oil left in a vat of liquid, and so on.
Because fire is so sensitive to the geometry, composition, etc. of the fuel, it is not possible to assign a particular PPO2. The devil is in the details.
- Warren
When referencing fire, i was thinking more like the types of small fires or sparks you need to do things like fire a gun or start an engine, but I've pretty much gathered that we'd all be dead before cars didn't start due to lack of oxygen.
  • #31
yes, there are better methods for preventing forest fires then elimination oxygen in the atmosphere
  • #32
uhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
I never said anything about forest fires damnit!
  • #33
One thing that has not been mentioned with the altitude argument, is that if you think about breathing engines of aircraft that require oxygen to burn fly at very high altitude. so my understanding is that oxygen does not need to be plentiful at all for a decent combustion, i do also take the assumption that aircraft move very fast so they'll cover more particle space.
People who live in higher altitude are healthier as the body goes through more stress so they generate into much hardier systems. Also taking in effect the geography is more rugged and requires effort, so they don't get time to catch the bus and chill out smoking a cigarette while the wind blows it out every 20seconds.
can someone translate 25,000ft in metres quickly.. i couldn't bother searching it on the net.. however if you talk in metres from 4000m->6000m it's no problem. Even everest being almost 9000m you can still sustain yourself without problems. They carry oxygen tanks as it is easier for someone who hasn't adapted/climatized in that region already putting in a big effort climbing such a mountain.
  • #34
Sorry, Pawel, but I have to take offense to just about everything you've said here.
Aircraft that fly at high altitudes uses turbines to compress the intake air. See "turboprop" and "turbojet" engines.
People who live at altitude are healthier? Do you have any research to support this claim, or is it just speculation?
Go to www.google.com and type in "25000 feet in meters."
9000 m is 27,000 feet. Almost everyone on Earth will die at those kinds of pressure altitudes. Most people need oxygen to survive above 15,000 feet or so.
- Warren
  • #35
Remember those old tin can space ships, the Apollo missions and all? They had VERY oxygen-rich air mixtures, but in very low pressure. But their oxygen intake was about normal, because at lower pressure the oxygen moledules are further apart. So at richer oxygen mixes and lower pressure, you get the same saturation of oxygen as at lesser mixes at higher pressure. The result being that the oxygen was hitting their lung tissue at roughly the same concentration as they were accustomed to.
I'll try to be more clear. The important thing is the saturation of oxygen. In lower pressure, you need more of it per volume or air. In higher pressure, you need less of it per volume of air.
<h2>1. What is deforestation and how does it impact the ability to light fires?</h2><p>Deforestation is the process of clearing or removing trees and other vegetation from an area. This can impact the ability to light fires because trees and other plant materials are often used as fuel for fires. With less trees and vegetation, there is less available fuel for fires.</p><h2>2. How does deforestation affect the availability of firewood?</h2><p>Deforestation can significantly decrease the availability of firewood. As trees are cut down and not replaced, there is less wood available for use as fuel. This can lead to a scarcity of firewood, making it more difficult for people to light fires.</p><h2>3. Can deforestation lead to a lack of oxygen, making it harder to start fires?</h2><p>Yes, deforestation can contribute to a lack of oxygen. Trees play a crucial role in producing oxygen through the process of photosynthesis. With fewer trees, there is less oxygen being produced, which can make it harder to start and sustain fires.</p><h2>4. How does deforestation impact the environment and weather patterns, which can affect the ability to light fires?</h2><p>Deforestation has a significant impact on the environment and weather patterns. Trees play a crucial role in regulating temperature, humidity, and rainfall. With fewer trees, there can be changes in weather patterns, such as droughts or floods, which can make it harder to light fires.</p><h2>5. What are some potential solutions to combat deforestation and ensure the ability to light fires?</h2><p>Some potential solutions to combat deforestation include sustainable forestry practices, reforestation efforts, and using alternative sources of fuel for fires. It is also important to raise awareness about the importance of preserving forests and the impact of deforestation on the environment and our ability to light fires.</p>
  • Mechanical Engineering
10K
  • Materials and Chemical Engineering
  • Thermodynamics
