Could the reason why I can't select any kernels in VS Code be this error?
  • Thread starter Thread starter arhzz
arhzz
I am trying to run an .ipynb file and have installed Miniconda as well as created an environment as such
-conda create -n <env_name> python=3.7 ipykernel jupyter
I am assuming this is successful as I can activate this environment via the anaconda prompt and following command
-conda activate <env_name>
Then I downloaded and installed VS code and I am trying to edit an .ipynb file. I want to select a kernel, via VS Code but when I press the button on the upper right corner I am greeted with the message that I need to install Python and Jupyter extensions. As soon as I do that the following error shows up
"Extension activation failed run the 'Developer: Toggle Developer Tools' command for more information
Source: Jupyter (Extension)"
and I am not able to select any kernel.Additionaly,when I try running any Jupyter related commands such as
"Jupyter: Create Interactive Window"
I get error messages of the following type:
Command 'Jupyter: Create Interactive Window' resulted in an error (command 'jupyter.createnewinteractive' not found)
This error is common as far as I know and has been discussed here at StackOverflow. See following link Extension activation failed, run the 'Developer: Toggle Developer Tools' command for more information
Now I have tried the solution that was suggested on this question and it did not work. I tried installing prior versions of jupyter as well as tried completely deleting the extensions from the extensions folder. My last resort was reinstalling VS code altogether but that either did not resolve the issue.
So my question is could this be the cause of me not being able to select the kernel? If so how do I resolve this issue.
Many thanks!
Technology news on Phys.org
Try doing it without the environment switch. Most devs install VS Code separately so its available in any environment.
What do you mean without the environment switch? Could you elaborate more.
On a side note I am now certain it is a VS code issue since I tried doing it the oldschool way and just opened a juptyer notebook and it worked just fine.
I misread what you were doing.
The suggestions I saw were:
1) Make sure that after switching to your new environment, you can run the Python command
//// which python
//// python --version
On my macOS, there is no Python; instead you call it up via python3.
2) Add Jupyter kernel for notebooks:
//// python -m pip install ipykernel
//// python -m ipykernel install --user --name xyz --display-name "Python (xyz)"
3) After switching to your new environment, when starting up VS Code, do it via the 'code' command to be sure it's got the same environment.
//// code .
4) You may need to initialize conda in your .zshrc (or .bashrc...):
//// conda init zsh // (or whatever shell you're using: bash, sh, csh, ksh...
$$ which python
$$ python --version
$$ python -m pip install ipykernel
$$ python -m ipykernel install --user --name xyz --display-name "Python (xyz)"
$$ code .
$$ conda init zsh // (or whatever shell you're using: bash, sh, csh, ksh...
Ah I see, already did that. Unfortunatly did not help. Guess I am going to stick with the oldschool way
Some comments recommended manually pointing VS Code to the Python executable via its configuration settings.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
