Couldn't the universe be finite if Omega =1?
The discussion centers on the implications of Omega = 1 in cosmology, questioning whether it necessitates an infinite universe. While popular science often suggests that Omega = 1 indicates an infinite flat universe, some argue that a finite universe could still exist under this condition if it possesses specific curvature. The conversation also touches on the challenges of reconciling infinite mass with observable phenomena and the philosophical underpinnings of cosmological models. Participants express discomfort with oversimplifications in popular literature and advocate for a clearer understanding of these complex concepts. Ultimately, the dialogue emphasizes the need for careful consideration of cosmological assumptions and models.
  • #51
correct the hot big bang model has no clue how the universe started, there is no agreement on that issue
the hot big bang model only states we had a hot dense state near the beginning after 10-43 sec
Space news on Phys.org
  • #52
Since Simon may not have time to answer, would someone else well acquainted with cosmology please answer this question, which is related to my first post? Simon said that the math is simpler with a flat infinite universe. I suppose that would completely do away with having to deal with an expanding edge. Is it primarily the problem of the edge that makes the math easier with an infinite flat universe, as opposed to a finite flat universe? If there are other aspects that make the math easier, I am also curious to know. And would others agree that since that results in a model with simpler math, Occam's razor inclines us to prefer an infinite flat model over an finite flat one? Lastly, besides the easier math, are there any observational reasons to prefer an infinite flat universe over a finite flat one?
  • #53
Occam's razor has nothing to do with maths:
It states that among competing hypotheses, the one with the fewest assumptions should be selected.
It refers to similar , simpler, equivalent theories
Philosophers also point out that the exact meaning of simplest may be nuanced.
It is an issue of philosophy and philosophy of Science
  • #54
From the Wikipedia article at http://en.wikipedia.org/wiki/Occam's_razor#Science_and_the_scientific_method
In science, Occam's Razor is used as a heuristic (rule of thumb) to guide scientists in the development of theoretical models rather than as an arbiter between published models.
I would qualify this to say that is how it usually should be used, as most of us would typically prefer the simplest and most elegant explanation when choosing between two equally plausible models. That does not mean that the simpler model is the correct one, however.
I have often heard Occam's razor being applied wrongly (especially in web forums), as though it were evidence against a model.
Also from the article:
However, appeals to simplicity were used to argue against the phenomena of meteorites, ball lightning, continental drift, and reverse transcriptase.
The simplest answer is not always the correct one. Like any razor, you can nick yourself with it quite badly if you don't use it right!
I believe this relates to the post, since the post is about the less widely accepted and lesser known idea of a finite universe where Omega equals one.
  • #55
It could be torus shaped. i.e. like the game asteroids. Which is flat but if you go off one side of the screen you end up on the other side. Right?
  • #56
It is hard to fathom why this is still going... these questions have been answered several times in the previous thread but ho well, obviously not well enough. On last go...
bobie said:
as it was stated in post #2, the choice of a flat and infinite U(niverse) has been made to dodge the problem of the edge, on the false assumption that a curved U must have an edge while flat one may not.
Please quote the bit of post #2 where I write that a curved spacetime must have an edge.
But the remedy is worse than the cure, ...
Since a cure has yet to be proposed, we are pretty much stuck with the remedy.
The context of post #2 was the FLRW Universe (spelled out int hat post, and follows from post #1).
Please see:
http://preposterousuniverse.com/grnotes/grtinypdf.pdf
... this is a crash-course in GR, the final chapter deals with FLRW spacetime and the implications of the omega factor in more rigorous terms.
I hope Mordred would care to clarify these simple points of the theory:
I'm sure Mordred won't mind if I have a go too?
- infinite U means infinite space or also infinite mass?
Please read up about the FLRW Universe (Link above.)
... a uniform density over infinite volume implies the mass is, in common-language - infinite.
...if mass is finite, is it distributed on infinite radius?
The term "radius" implies there must be a center to have a radius from. Since there is no center, the question is meaningless. It is a common trap.
Let me help: the infinite mass is distributed over an infinite volume in such a way as to have a finite mass density. Better?
The FLRW Universe starts out by making assumptions about that density.
It's kinda the whole point. (see the link above for details)
- infinite means no-shape?
Define "shape".
In GR - the Universe is a 4D object not embedded in any larger dimensionality - which should make the concept of shape quite tricky even for finite Universes.
An infinite universe has a geometry described by it's metric. (see the link above for details)
- an infinite but curved U[niverse] is worse than flat one?
For a scientific definition of "worse" yes. The maths is harder to get the same value predictions: why bother?
But more to the point: curved spacetime is not ruled out (re post #2 say) by being inconvenient but by being excluded as a solution to the Friedman equations which have gamma=1.
If you want to discuss curved spacetimes, you should start a new thread (after a bit of reading - see link blah blah.)
- infinite + c = infinite or not?, if so, how can U expand?
Define "c".
If c is taken to be a finite number, then the question is meaningless: you cannot add a constant to infinity like that without more care.
naively: infinity+1 = infinity.
This causes the kind of mess that Cantor worked on.
http://www.c3.lanl.gov/mega-math/workbk/infinity/inbkgd.html
We avoid this in cosmology by never adding a finite anything to anything infinite.
...if the rate of expansion is over 3c at a certain distance what is that rate at infinite distance?
Cosmological expansion is a local phenomenon. In the FLRW Universe, the rate of expansion is the same everywhere.
- if U is (flat and) infinite right now, what is the meaning of the radius of U being now 14 Gly?
That's the age of the Universe. Big-bang cosmology proposes that the Universe had a beginning in time but may be infinite in space.
The infinite-flat FLRW Universe models one such geometry.
- was [the] U[niverse] infinite even before Big-Bang?
In the FLRW model, an infinite-flat Universe would have had to be infinite in the plank epoch ... so simple answer: "yes" - with reservations depending on what you think the words "Big Bang" mean.
Your questions suggest you may not be thinking of the same thing as me.
... if [the Universe] was [infinite before the big bang]: what is the use of this theory if it says that "even space and time did not exist before BB" , then:
... if [the Universe] was not [infinite before the big bang]: how can it be infinite now after only 14 G-years?
It is difficult to parse this question... I have put in square brackets and redone some punctuation to see if that helps - please let me know if this is not what you intended.
The second part is how can something finite become infinite in a finite time ... this is not impossible with maths - consider: y=tan(πt/2) starts from 0 at t=0 and becomes infinite in the finite time t=1. However, I don't need to go into this in more detail since the model being discussed does not propose that the Universe started out finite.
The first part seems to be asking how an infinity could have existed before the big bang if space and time did not exist before than.
This has some issues.
1. the big bang is usually taken to be the start of the rapid expansion: the Universe already existed then. i..e there was space and time before the big bang.
http://en.wikipedia.org/wiki/Big_Bang#Timeline_of_the_Big_Bang
2. by your own arguments, getting any finite something from nothing is as big-a problem as getting infinite something from nothing - they both involve, for example, an infinite percentage increase in the amount of matter and energy and spacetime. (Though "before" and "after" are problematical concepts when you are talking about time itself.) Mathematically it does not matter.
3. GR is a theoretical framework for describing space-time once it exists, it tells us nothing about conditions in the absence of a Universe.
In order to deal with the transition from nothing to space-time we need a theoretical framework beyond that supplied by GR which is off-topic for this discussion. This discussion concerns the ratio "omega" and it's relation to a particular set of theoretical models.
I quite like closed models for the Universe myself - sadly the Universe I find myself in does not care what I find appealing.
These are only the main obscure points.
These points represent common confusions experienced by beginning students of maths and cosmology and mostly come from mixing up different models, and not appreciating what happens to arithmetic when infinity is involved. These are confusions that get repeated a lot in the junk-science writings so it is important to take care with this sort of reasoning.
You would have more chance of sorting out your confusion if you stayed on topic: re: FLRW Universe with omega=1. Discuss other models in other threads - there are many already.
Other models say different things.
Don't mix them up.
Applying the FLRW Model to this Universe... which is where the interest lies after all:
The FLRW Universe is telling us that the flatness of the observed Universe suggests that we are in an epoch close to the threshold curvature between open and closed global topologies.
Simple-closed topology is "spherical".
Simple open topology is "hyperbolic"
Right between those two you have an infinite plane.
Happens to have easy(er) maths.
It's not hard to understand.
Ergo - it is a reasonable thing for a pop-science show to say.
If you prefer flat and finite, then you are welcome to do all your maths in toroidal spacetime if you really want to.
http://arxiv.org/pdf/gr-qc/0411014.pdf
... also see:
https://www.physicsforums.com/showthread.php?t=237353
Enjoy.
  • #57
Or, as we have discussed, a flat but finite space with more difficult math.
Simon, I was hoping to get your opinion regarding this. Is it primarily the problem of an expanding edge that makes the math easier with an infinite flat universe, as opposed to a finite flat universe? And what particular aspect of the math of an edge is so challenging?
(If you are not American, please pardon my use of the word "math" rather than "maths". I must be true to myself. It just does not look right when I write "maths"!)
  • #58
I do not know about math(s), but the edge raises formidable conceptual problems.
U is being, what is, all-that-exists, beyond the edge of what-is can only be what-is-not, The Nothing, which does not exist and cannot do anything, let alone bind.
Apart from philosophical formulation: what happens when a spaceship reaches the edge? can it approach it? will it rebound? can it trespass? what happens to energy/matter?, does it simply vanish? what keeps energy/matter inside the edge? ... ...
and so on and so forth.
Most likely both theoretical and technical problems have very simple solutions because they are ill-framed, they are false problems, because U has indeed an edge, but man is unable to conceive a different formulation, cannot conceive the absolute.
The parallel with the Earth is misleading, as the surface has indeed no edge, but only on 2 dimensions. Downward the edge is the crust and upwards ditto when man couldn' t fly, now is the edge of U.
It is simple to dodge all these unsolvable problems, just with a handwave and say: U is infinite, (or , when pressed)... but we really do not know.
As to math(s), wait for Simon.
  • #59
Simon Bridge said:
If the Universe is finite and flat, then it must have an edge
Is this actually true? A flat torus universe would have finite spatial volume but no edge.
I think you may be implicitly making an analogy with the case of a 2-dimensional surface embedded in 3-dimensional space. If the Earth's surface were flat but finite in area, it would have to have an edge, because there's no way to embed a flat 2-torus in 3-dimensional space. But there's no reason to impose that kind of restriction on the spatial slices of the universe as a whole, because the universe doesn't have to be embedded in any higher dimensional space.
[Edit: a flat torus universe with no edge would still not be isotropic, as Bill_K confirms in a later post.]
  • #60
...I think much has been answered (Simon/Modred/etc). They are talking about model dependent/ local of which we have 'time'/cosmic time/time-clock relation/ global time linked to motion modeled to the best of what we can in SR interpreted in GR and extrapolate to observational data's.. U as infinite is what the model predicts based from what they have so far. It's a good thing though. Infinity is just a way of telling that a model is incomplete or a hint to something new. ... I wonder how would you define an edge?
...I think the confusion is the way you conceptualized nothing/edge. It is much easier if you're imagining 'everything' is contained in everything(no edge/beginning or origin) and focus on its context and DISCOVER its dynamics(like what they do in physics). It will come in handy when dealing with infinity. So far to make an intuitive sense on the concept of infinity. It must contain some variable to make a bound system work. The only thing i could think of is BOUNCE.
... Things change relative to a/ time(conventional understanding) as a construction(to some)-if you will. We understand the universe for what we think it should be in hopes that it will obey our interpretation of nature/math. And for what it really is, remains neutral or unknown for now.
  • #61
... Nature won't allow that or you can't make an absolute postulate. We construct a mental picture of edge/center bec we put constraint to any given medium. E.x. An object such as pencil is a bounded thing. We identify it's edge as it's head/tip limited to constraint of the structure which is from the tip to the head. The universe doesn't apply to this principle. However we can assume a formulation of an edge 'IF' we put 'constraint'(the same as we did with the pencil) on the OBSERVABLE PART(not the whole isotropic and homogeneous universe) in relation to observer. The center would be any observer and the edge is in any point in the Observable universe or observable universe itself.
  • #62
I don't know why on Earth anyone would find a finite flat universe more appealing than an infinite one. By making it finite, you lose isotropy. And that is a heavy price to pay.
A finite universe is constructed from an infinite one by identifying points, so that if I travel in any particular direction I will eventually come back to my starting point. The galaxies seem to repeat themselves, like in a crystal lattice. But just like a solid crystal, the universe must then have principal axes - there is no way to make the periodicity the same in all directions.
Likes 1 person
  • #63
If you have an infinite universe you will have an infinite number of 15 Gly regions of approximately the same composition. An infinite number will be very, very similar to the one we inhabit. There will be some where a close, if not exact, copy of you and I exist. It may well be true scientifically but I find it philosophically disturbing.
Isotropy? I don't keep up on everything but I don't think the "Axis of Evil" anomaly has been completely resolved.
There are still a lot of loopholes before we declare the universe infinite.
Do we have an adequate theory of fundamental physics to declare which "constants" are truly immutable and eternal or merely slowly varying. Omega could well be asymptotically approaching 1 but never get there. On an experimental level, can we ever distinguish 1.0000000000000001, 0.9999999999999999 and 1.0000...?
  • #64
Good point about loss of isotropy! Also nice to hear the issue of how one thinks of the U treated as a matter of taste, which model one finds *more appealing*.
I don't believe it makes any different to real world computations (where there is always a limit on precision) whether one assumes Ω exactly = 1, or instead something like 1.000001.
That would correspond to a U which is spatially a 3D sphere. And the 3D spatial slice (a "hypersphere") would currently have a radius of curvature of 14400 billion light years.
In effect, no one could tell it from flat :biggrin: And with that one still has isotropy.
So it is a question of personal taste. Do you like the mathematical exactitude of Ω=1 and hopefully have the self-restraint to avoid drowning in philosophical infinity?
Or do you prefer to imagine a slightly curved very nearly flat space, while doing all your calculations as if space were perfectly flat. A very slight positive curvature is not going to change the answers--since its effect on the equations will be too small to include.
Oh, I guess it makes a difference to modeling the early universe. I had forgotten about that.
  • #65
Hi marcus, just imagine what your favourite wiseman, Anassagoras, would say to that. (what? me worry?)
Ancient sophoi discovered the truth because they followed the laws of necessity, the laws of Being: it is so because it must be so, it can only be so, and it's a miracle that it can be at all. The basic laws of Nature contrast whit what Popper said, there is ony one solution, nay, sometimes there is no solution, and Nature finds the impossible solution.
That's amazing, marcus, can you expand on that, how did you find that magic value? the likely size of U ≈1031 cm. That's just what I was describing a few posts ago!
That would solve many, almost all problems.
Would that explain also the fact that it was impossible to detect CMB going round and round, and solve the problem of inflation, too?
Can you give me some links to learn the details?
Thanks a lot!
  • #66
That's amazing, marcus, can you expand on that, how did you find that magic value? ...
Would that explain also the fact that it was impossible to detect CMB going round and round,..
I explained how to find the radius of curvature in a special tutorial thread that was in part thinking of you as reader. "Friedman for the lay learner". You have described yourself as a "LAY READER". If you sincerely want to learn standard cosmology, in good faith, then I would call you a "lay learner" and that thread is for you.
Anaxagoras (born circa 500BC) used verbal reasoning to conclude things like that the sun was a hot stone about the size of the Peloponnese section of Greece. But Aristarchus (born around 280BC) used trigonometric math reasoning and measurement of an angle to determine that the sun was much larger than the Earth!
Now our understanding is based on quantitative relations (equations) involving change, and when you read a verbal description of some finding that is only a translation into less suitable language. So if you truly want to understand cosmology, I would urge you to become acquainted with the Friedman equation.
And as an experiment to see if it helps, I will try to put the equation in a more intuitively assimilable form. And I will try out different ways of explaining to see if we can find one that works.
If we conceive of a spatial section as hypersphere then it turns out that the 3D sphere is expanding so fast that it will always be impossible for light (like the CMB) to go all the way around. So indeed as you intelligently point out, that is a non-problem.
However the question of whether to treat the spatial slice as very large expanding 3-sphere or, instead, as INFINITE with zero curvature, is in a sense a merely VERBAL or artificial problem, not to be taken too seriously. Because for the practical purposes of calculating there is essentially no difference between zero curvature and a negligible amount of positive curvature.
Given the projected expansion history there's a limit on the size of the region we will ever be able to observe and it makes hardly any difference, mathematically, whether that region is part of a huge 3-sphere or an infinite extent with average curvature precisely zero.
Mathematics is an art of controlled approximation.
So I think your first language must have been Italian. BTW I thought I detected a note of mildly humorous pride in a previous post when you mentioned the famous tenor Luciano Pavarotti. You are right to be proud. Why do you think "Anassagoras" would be a favorite sage, for me? Should he be the mascot of all who look for rational law in Nature?
  • #67
marcus said:
I detected a note of mildly humorous pride in a previous post Why do you think "Anassagoras" would be a favorite sage, for me?
I misquoted
But apparently Anaximander thought a little more deeply and said: Yes the round Earth is situated in the midst of empty space but it does not fall...because there is no preferred direction for it to fall in!
You explained it with symmetry, I explain it with necessity. As to the tenor, I mentioned him because he is a famous figure and his chest reminds one of a low bass singer. And 'great guy':cool: was meant for you! But yet your intuition was right, as to my language. I think it is also patent that English is not my language!
I'll find your thread and read it, but if you wish, tell me one thing:
I do not particularly want to know how to find the radius of curvature, but why with that very curvature U would be considerd flat and keep isotropy? does it depend on the sensibility of your instruments or it is a principle?how do you derive that figure? from Friedman equation? Do those properties apply also or a fortiori if the radius is twice that figure, say 30,000 Gly? what if that were the real, actual size of U? why would you rule that out?
Thanks for your attention, marcus, I suppose I ought to give you a break, now!
  • #68
[/QUOTE]
Hi marcus, in my opinion we talk at least about a big philosophical issue. Any deviation from
Ω = 1 related to ##k = +1## supports a finite universe.
In the case of a 3-sphere said deviation should be much smaller than 1.000001, because during inflation the critical density was roughly constant, while the matter density decreased with ##1/a^3##, whereby ##a## increased by about 1050 during this period.
  • #69
Bobie,
Your english is very good (not to worry) just at rare times slightly *different* from typical american. I don't have to say this, since you are already self-confident. As you should be!
My favorites are Anaximander (b. circa 600 B) and Aristarchus (b. circa 310 B).
But my knowledge is sketchy (partial) and you may know more about pre-Soc. and other classic topics.
I'll find your thread and read it, ...
Great! I hope you do! and that you find the explanation clear enough and somewhat helpful. It is an attempt to develop a new way of explaining the Friedman equation (or as some people say "FLRW" for friedman-lamaître-robinson-walker but it was really Alex Friedman's equation. He died in 1925 not long after finding it. Why don't they at least call it FLWR and pronounce it "flower"?)
You can look up "Friedmann equations" in Wikipedia and get a different presentation. It might be good to do. The spatial curvature term that I call "Q2" is there in the guise of "kc2/a2". I am just translating quantities into quantities I find more transparent such as radius of curvature and reciprocal expressed as growth rate. (I am ignoring the negative spatial curvature case, so my simplified Friedman is not fully general--it just covers the "flat" ie. zero curved and "hypersphere" i.e. small positive curved cases.)
  • #70
timmdeeg said:
...Hi marcus, in my opinion we talk at least about a big philosophical issue. Any deviation from
In the case of a 3-sphere said deviation should be much smaller..., because during inflation...
Hi Tim, I like your use of the word "deviation" for the amount that current Ω differs from Ω=1.
So in the case I used as example, where present-day Ω=1.000001 has a positive deviation of 0.000001 or one millionth.
Another term for the same thing, which I find pedagogically clumsy, is "- Ωk".
I think that notation, especially the minus sign, is an historical accident. People got into the habit of writing "Ω = 1 - Ωk" and the usage stuck.
I don't want to argue about whether or not a millionth is a good size present-day deviation to consider as an example. It is just a convenient example to take, numerically. The square root is recognizably 0.001, namely a thousandth. And therefore the radius of curvature of the hypersphere (today) is a thousand times the present-day Hubble radius 14.4 Gly.
I am using Planck mission parameters, essentially, which is why I say 14.4 instead of, say 14.0 which is closer to the latest figure WMAP reported.
So just to have a pedagoguish example, multiply 14.4 by 1000 and there you are.
BTW did you ever look at Charles Lineweaver's 2003 paper called "Inflation and the CMB"? It has a page or so discussing how the "deviation" (as you and I call it) changes over time. Inflation can pull it down to be very very small, but then it can slowly creep back up again. anyway one cannot so easily nail down what range it ought to be in today. The WMAP reports showed upper limits on the order of 0.01, so I would say 0.000001 is not unrealistically large (but you may disagree :biggrin:)
  • #71
Timdeeg,
I found the helpful page in Lineweaver 2003:
It is page 11 of http://arxiv.org/abs/astro-ph/0305179
Code:
0.95 < Ω[SUB]o[/SUB](z = 0) < 1.05                         (33)
0.99995 < Ω(z = 10[SUP]3[/SUP]) < 1.00005                  (31)
0.9999999999995 < Ω(z = 10[SUP]11[/SUP]) < 1.0000000000005 (32)
In order to have present-day deviation no larger than 0.05
you need, back in the time of redshift z, to have had deviation no larger than 0.05/(1+z)
so at recombination, i.e. 1+z ~ 1000 the devi must have been less than 0.05/1000 = 0.00005
and about 1 second after start, shortly after inflation, say 1+z ~ 1011, the devi must have been less than 0.05/1011, so twelve zeros before the 5.
  • #72
From this point of view, oh yes.
Yes, thanks, it belongs to some selected papers, which I have printed out some time ago. The important term is ##\rho a^2##. Because according to the Friedmann equation this term increases enormously during inflation and thus drives Ω to 1, but decreases after inflation so that "our deviation" "creeps back again". I guess the latter effect doesn't change too much if one considers the first one. But I am not aware of any figures. Anyhow, this solution of the flatness problem is really very impressive and I do hope that the Planck mission will confirm the expected primordial gravitational waves!
  • #73
Yes, that's the 'pencil on its point' problem. I remember my excitement when I read Alan Guth's "The inflationary universe".
  • #74
Hi marcus, so I was right (apart from poor memory). It struck me, last year when I read it, that a scientist can appreciate and understand philosophy. That's why I like you. A philosopher has an edge on a scientist, as he knows some truths, has some tenets. Even a student philosopher has an edge (:rolleyes:) on a cosmologist, as he knows for sure there is an edge, that U is finite and spherical, etc...
But, again, you didn't answer my questions!
I found your thread, it's a good idea, but if you want to do a really great job (for students) you should start from scratch and listen to students*, so that you can improve what is obscure (a seminar, work in progress). Then you can re-write it and make a useful 'sticky' (that'll save you hundreds of repetitive posts) or write an excellent article in wikipedia or even publish a successful divulgative booklet. At the end you might even gain a better insight into your own theory!
The main ingredients are simplicity and clarity: always choose one and the simplest option*, therefore U must be observable U ( else nobody will follow you), give first the basic data at BB and now, explain the main ideas of the theory, give a concrete example (how from the redshift of a galaxy you derive all data with your calculator (not everybody is able to deduce that) , and then you can explain the Friedman equation. It's an interesting and ambitious project. Good luck!
If you are intersted in my opinion I'd be glad to help you, send me a PM, since I do not wish to encumber your thread.
* U is infinite/finite/ we don't know , at BB space was finite/ infinite, U is flat/ has a tiny curvature, etc
**experts cannot understand students. Right now you can see there are two threads asking the same question about expansion>C. After 57 posts in my thread, I gave up hope that there is someone who wants or can listen.
  • #75
bobie said:
any deviation, however small, from absolute flat leads to a circle , however huge, I suppose. Or not?
timmdeeg said:
... we talk at least about a big philosophical issue. Any deviation from Ω = 1 related to ##k = +1## supports a finite universe. .
Hi timmdeeg, you are right, and it is not a philosophical or abstract issue , but a concrete geometric issue: a line is straight if and only if it is always/ absolutely straight. It is an undeniable truth. You call it Ω, let's call it angle. The angle between any two adjacent segments must be 0°. Even if it is 57..°/1031 the resulting figure is finite and a circle/sphere (with a huge radius, of course).
Please tell me: Friedman equation is founded on the fact that matter/gravity curves spacetime (am I wrong?), doesn't that exclude that U can be flat, a priori?
  • #76
Hi Marcus, I just realized that you replied to me in the other thread:
marcus said:
And Bobie asked how ..So in the other post I took the case that the upper end of the confidence interval was Ω = 1.000001 and the positive curvature number was 0.000001. So then the square root was 0.001 which is a thousandth. And you multiply the Hubble radius 14.4 Gly by a thousand to get 14400 Gly.
I'll continue this discussion here, since I do not wish to spoil your nice thread:
Probably you missed this post
bobie said:
I do not particularly want to know how to find the radius of curvature, but:
- why with that very curvature U would be considerd flat and keep isotropy?
- does it depend on the sensibility of your instruments or it is a principle?
- how do you derive that figure?
- do those properties apply also or a fortiori if the radius is twice that figure, say 30,000 Gly?
You explain that a curvature .000001 corresponds to a radius of 144,000 Gly, right, but my questions were:
- why with the current value you do not have isotropy and can't say U is flat?
- what so special about .000001? , if it is special, how did you determine it?
what did you mean by this?:
do you mean that we can assume that value as real?, no problem?, is it really a matter of taste?
- can the radius be really 1000 greater?
- what concrete parameters are needed in order that 144,000 Gly be the real radius?
I must have missed something!
  • #77
Hi Bobie, in General Relativity a straight line isn't what you would naturally expect from your experiences. In GR a straight line means the worldline of an inertial (force free) object, called geodesic, see here. Without knowing this definition, you would hardly agree, that a satellite surrounding the Earth is moving along a "straight line".
I took reference to a philosophical issue perhaps in another sense, as you have interpreted that. Most probably we will never know whether the universe is spatially infinite or not. Even in case it has exactly euclidean geometry this question is still open. Now you can ask, what would nature prefer? A universe where you can move along a "straight line" and never will come back to the point where you started? Or a universe where you will come back, perhaps even on paths of different length, as in the case of the 3-torus. The first possibility is the most trivial and this might be the reason why it is preferred by cosmologists. One could assume a philosophical background such that nature prefers the most trivial shape of the universe. But this is a personal comment.
Yes, the Friedmann equations are special solutions of the Einstein equations (which describe the curvature of spacetime) based on the simplifying assumption that the energy density is homogeneous and isotropic. But no, GR und thus the Friedmann equations do not say anything about the shape (topology) of the universe. This question can only be solved empirically, at least in principle.
  • #78
timmdeeg said:
Now you can ask, what would nature prefer? A universe where you can move along a "straight line" ...? Or a universe where you will come back, ...as in the case of the 3-torus. The first possibility is the most trivial and this might be the reason why it is preferred by cosmologists. One could assume a philosophical background such that nature prefers the most trivial shape of the universe..
I am not aware of a single case where nature chooses something trivial, she always finds the best/most simple solution. All is simple for her, maths is a man-made artifice, probably she can only do +1 and -1.
As marcus says commenting on Anaximander, nature obeys the law of symmetry, timmdeeg.
I call it as the necessity of Being: order, equality, proportionality, balance;
Infinite is not trivial shape, but no shape/edge.
The sphere is the most simple yet the most complex and symmetric shape, the only locus where the contradiction between finite and infinite is solved, conciliated. It is not a coincidence that Hubble sphere and visible U are spheres.
...the Friedmann equations do not say anything about the shape (topology) of the universe. This question can only be solved empirically, at least in principle.
How do you solve it empirically? are you sure you can detect any curvature? why is Ω =1.000001 so special?
  • #79
No, because curvature of *spacetime* does not require curvature of *space*. The curvature can all be in the time dimension. In the case of the flat Friedmann model, that's exactly what happens: each spatial slice is flat, and the spacetime curvature is entirely contained in the fact that the universe is expanding, i.e., changing with time.
  • #80
Can someone tell me why with such a radius one has isotropy, and not with the current one (144 Gly, 0.01)?
  • #81
bobie said:
... why is Ω =1.000001 so special?
It is not special - it is just a value that falls within the present observational limits of roughly 0.95 ≤ Ω ≤ 1.05; Ω = 1 identically would be somewhat special. Some data-sets seem to indicate a very slight bias towards Ω > 1, but I do not think that is taken too seriously at present.
I think Marcus just chose any value within the limits to use as an example of how to calculate the radius of curvature for a very slight positive spatial curvature. The value itself has nothing to do with isotropy.
  • #82
Jorrie said:
It is not special ... The value itself has nothing to do with isotropy.
Bill_K said:
. By making it finite, you lose isotropy. :
Thanks Jorrie, but marcus says:
"Good point about loss of isotropy!.14400Gly...with that one still has isotropy"
If radius is 14.4 or 14400 Gly U is still finite, the two statements are conflicting. Which is right?
marcus agrees with Bill, but adds that, by choosing that value, you rescue isotropy. Isn't he saying that ?
The model says that we do have isotropy anyway:
The Big Bang theory of the evolution of the observable universe assumes that space is isotropic
marcus adds:
... have a radius of curvature of 14400 billion light years...In effect, no one could tell it from flat
From what value you can't tell it from flat?
Lastly, marcus hints that that value would not imply great changes in the model
could that be the actual, real value? could you remodel the early universe with no big problems?
  • #83
Finite, like the surface of a sphere is finite, yet unbounded - you can go on and on around it without reaching an edge. Surface isotropy is then not a problem. Add one spatial dimension (to the surface) and you have something like a positively curved, isotropic, unbounded, 3-D universe. You run into trouble is if you should think "flat (or open), isotropic and finite". This cannot apply to the universe as a whole.
bobie said:
Besides that:
From the moment our observational evidence rules out Ω = 1, irrespective of how close to unity one of the limits is. The cosmic model we use allows virtually any value of Ω; it is just observations that can narrow it down. The best we have today is that it sits at or very close to 1, but if not exactly 1, we are not sure on which side it is.
  • #84
Jorrie said:
Finite, like the surface of a sphere is finite, yet unbounded ..
You are describing the Earth situation.
But that does not fit the Hubble sphere nor the visible U, nor, in conclusion, the model. That would fit a true analogy with an inflating balloon, which is not accepted.
If we limit our speculations to visible U, as any rational man-of-science should ("whereof one cannot speak..."), the situation is the one I have descripted above, a sphere, flat inside and curved on the edge.
Is this relevant to my questions?
That would rule out that U is flat. We know for sure then: any shape, but not flat.
And, if Bill is right:
, then U must be infinite by postulate. Infinite (edit: infinite, not just finite-unbounded) and not flat, does that make sense?
  • #85
If we limit our speculations to visible U (as any rational man-of-science should "whereof one cannot speak...") the situation is the one I have descripted above, a sphere, flat inside and curved on the edge
Bobie, I think you are confusing yourself. The surface of an inflating balloon is a perfectly acceptable 2-D analogy for a positively curved universe. The observable universe is represented by a surface-circle around your vantage point (or for any balloon surface dweller). The radius (and 'curvature') of that circle is limited by the age of the present expansion (how far light could have traveled) and has nothing to do with the size or the spatial curvature of the cosmos.
The radius of the balloon itself represents the radius of spatial curvature. For a "flat" universe, let that radius tend to infinity... Think about it carefully and I'm sure you will eventually embrace the balloon analogy - correctly used, it is amazingly useful.
And if Bill is right: Then U must be infinite by postulate. Infinite and not flat, does that make sense?
We would also know whether the curvature is negative or positive (i.e. open or closed).
Open (negative curvature), infinite and isotropic makes sense, not so?
  • #86
Sorry, what is the cosmos, now ?
whatever you mean, how do you measure or conjecture its size/radius? Are you talking of what is outside the visible U? ..."...thereof one must be silent"
The radius of the balloon itself represents the radius of spatial curvature. For a "flat" universe, let that radius tend to infinity... the balloon analogy ...is amazingly useful.
A flat universe? you have just excluded the possibility that Ω=1
(Please, let's abandon any analogy, even if you think they're useful. That makes confusion. Surely they are not necessary to answer my simple question.)
Are we discussing Ω <1?, anyway, were you suggesting that Bill did not mean infinite, but finite-unbounded?
My question was:
"Good point about loss of isotropy!...14400 Gly..with that one still has isotropy"
Is it related, by any chance, to this?:
The latest research shows that even the most powerful future experiments (like SKA, Planck..) will not be able to distinguish between flat, open and closed universe if the true value of cosmological curvature parameter is smaller than 10−4
Probably I should wait for marcus to clarify what he meant. Thanks, anyway, Jorrie.
  • #87
Bobie, to me you seem really confused about cosmology. I'm afraid the two of us do not communicate all that well and I'll rather leave it to others to help you out.
Sorry about that.
