Coulomb's Law: Direction of Force on -C Charges
  • Thread starter Thread starter jazzchan
    Coulomb's law Law
Coulomb's Law describes the interaction between point charges, where like charges repel and unlike charges attract. In the scenario with a positive charge (+C) and two negative charges (-C), the forces between them can be determined based on their positions. For two positive charges, such as 5C and 6C, located at different points on the x-axis, they will repel each other. Consequently, the force on the 5C charge will point in the negative x direction, while the force on the 6C charge will point in the positive x direction. Understanding these interactions is crucial for analyzing the behavior of charged particles.
jazzchan
Dear all...
i have a question about coulomb's law as follows:
if there are three point charges are placed at the x-axis, first is +C, second is -C and the last one also is -C.
How could i know the direction of the force at the second and third one ??
best regards.
jazz
You'll have to be more specific: where are the charges? I assume you need to find the forces that these charges exert on each other? Remember that like charges (same sign) repel and unlike charges attract.
Dear Doc Al
what is meaning of repel ??
if there is two postive charge at the X axis, one is 5C at x = 0, other is 6C at x = 40,
so what is the force direction ?? positve or negative ??
thanks
jazz
Repel means push away. Attract means pull together.
I assume you are talking about the forces they exert on each other?
Since these charges are both positive, they will repel each other. So:
(1) the force on the 5C charge at x = 0 will point in the negative x direction
(2) the force on the 6C charge at x = 40 will point in the positive x direction
Make sense?
thanks a lot !
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
