Coulomb's Law: Solving for Speed of Particle
  • Thread starter Thread starter SupremeV
    Coulomb's law Law
The discussion focuses on calculating the speed of a charged particle using Coulomb's Law and Newton's Second Law. A particle with a charge of 8 µC is released from rest at a distance of 1.4 m from another fixed particle with a charge of 6 µC, and its mass is 3x10-6 kg. The correct approach to determine the speed when the particle is very far away involves applying the conservation of energy principle, rather than using the kinematic equation V2 = V0 + 2ad, which is invalid due to the non-constant acceleration as the distance increases.
  • Coulomb's Law for electric forces
  • Newton's Second Law of Motion
  • Conservation of Energy principle
  • Kinematic equations for motion
  • Study the application of conservation of energy in electrostatics
  • Learn about variable acceleration and its implications in particle motion
  • Explore advanced kinematic equations and their limitations
  • Review examples of similar problems involving charged particles and energy conservation
Physics students, educators, and anyone interested in understanding the dynamics of charged particles and the application of fundamental physics principles in problem-solving.
SupremeV
1. The problem statement, all variables given/known data
A particle of charge 6 µC is held fixed while another particle of charge 8 µC is released
from rest at a distance of 1.4 m from the first particle. If the mass of the second particle is
3x10-6 kg, what is its speed when it is very far away from the first particle?
F=ma
F= kQ1Q2 / r2
V2=Vo +2ad
I pretty much worked through most the problem. In the end, I used coulomb's law in combination with Newtons 2nd law to get a= 73469 m/s2. However what's bugging me is the distance that the speed is "very far away". I'm under the assumption that means at a point where the force from the first particle no longer affects the second. However, when I back-tracked using the answer(454m/s) the distance ends up being 1.4( the original distance) with the velocity equations.
Apologies, I searched google and found a similar problem: rocket is launched straight up from the Earth's surface at a speed of 1.60×10^4 m/s.
What is its speed when it is very far away from the earth?
One of the helpers suggested conservation of energy, and I applied this to this problem it worked! Sorry!
You do realize that the acceleration is not constant? It decreases as the distance between the particles grows. So your V2 = Vo + 2ad formula is not valid over the trajectory of the second particle.
Why not try a conservation of energy approach?
9K
39K
