Counting Passwords with Restrictions
Curiouspoet
Counting Lists With Repetition
How many ways can you create an 8 letter password using A - Z where at most 1 letter repeats?
I'm not sure how to attack this problem but first I thought that A-Z considers 26 letters so with no restrictions on passwords we can create 268 passwords. I'm thinking it's 268 - X, where X is a term or a series of terms, but I'm not sure how to determine them, or if this is even the correct setup.
Well there are two cases given by the restrictions as follows:
A) No letter repeats in which we have a k list without repetition which is given by (n)k = n!/(n-k)!
B) One letter repeats in which case I think it's 26*[(n-1)!/(n-k-1)!].
And of course in this case n = 26 k = 8. Is this correct? If not could someone give me a hint?
In the case of taking an 8-list of 26 letters where at most 1 letter repeats, would it just be the sum of case A and case B as I wrote?
i think you almost nailed it. i would separate it to 2 sections.
one - no repeating. in this particular case, we choose 8 letters from 26 and count all the ways we can order them, which is what you've mentioned \frac{26!}{(26-8)!}
two - one letter repeats. in this one, we choose only 7 letters from 26 and count all the way we can order 8 letters and subtract the number of ways we order the letters when the two similar letters are together.
why is that? i'll let you ponder about it. :)
then - as you've already typed, you will add what you've gotten from the 1st section and add it to the result of the 2nd section and that's the
answer to your question.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
