Coupled 2nd-Order Non-linear ODEs
cepheid
Staff Emeritus
I'm trying to solve the equations:
\ddot{\phi} + 2\left(\frac{\cos \theta}{\sin \theta}\right) \dot{\theta}\dot{\phi} =0​
and
\ddot{\theta} - \sin \theta \cos \theta \dot{\phi^2} =0​
for \theta(\lambda), \phi(\lambda) where the dots represent differentiation w.r.t the parameter \lambda.
Chain rule, other differentiation tricks
I've tried to tackle the first equation by writing:
\frac{\cos \theta}{\sin \theta} \dot{\theta} = \frac{1}{\sin \theta} \frac{d}{d\theta}(\sin \theta) \dot{\theta} = \frac{d}{d\lambda}[\ln (\sin \theta) ]​
I'm wondering if it's correct to do that. It seems to follow from the chain rule, but I'm not sure. If so, then the equation becomes:
\frac{\ddot{\phi}}{\dot{\phi}} = -2\frac{d}{d\lambda}[\ln (\sin \theta) ]
\frac{1}{\dot{\phi}}\frac{d \dot{\phi}}{d\lambda} = -2\frac{d}{d\lambda}[\ln (\sin \theta) ]
\frac{d \ln ( \dot{\phi})}{d\lambda} = -2\frac{d}{d\lambda}[\ln (\sin \theta) ]​
Then I integrated both sides w.r.t. lambda:
\ln ( \dot{\phi}) = - 2\ln (\sin \theta) + \mathrm{~const.}
\dot{\phi} \propto \frac{1}{\sin^2 \theta}​
Then I tried substituting this result into the second ODE, but it gave me:
\ddot{\theta} \propto \frac{\cos \theta}{\sin^3 \theta}​
which I don't know what to do with.
Just bumping the thread. Any insight you might have, esp. regarding the last line, would be most helpful.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
