Covariance of Newton's 2nd Law under Galilean boosts
The discussion revolves around the covariance of Newton's second law under Galilean boosts, exploring the implications of mass and force invariance between inertial reference frames. Participants examine the assumptions necessary for claiming that Newton's second law holds across different frames, particularly focusing on the definitions of force and mass.
  • Some participants question whether the assumption that force remains the same across frames is necessary for claiming covariance of Newton's second law.
  • Others argue that if force is defined as ##\mathbf{F} = m\mathbf{a}##, then it follows that force is invariant and thus supports the covariance of the law.
  • A participant suggests that the definition of inertial reference frames (IRFs) as special is crucial for understanding how force is measured and compared across different frames.
  • Concerns are raised about the validity of claiming form invariance of the equation ##\mathbf{F}=m\mathbf{a}## without asserting that ##\mathbf{F}=\mathbf{F'}##, indicating a need for clarity on the definition of force.
  • Some participants emphasize that Newton's laws cannot be discussed meaningfully until force is clearly defined, suggesting that the author of the textbook may address this later.
Participants express differing views on the necessity of asserting that force is invariant across frames for the covariance of Newton's second law. There is no consensus on the implications of defining force and mass in this context.
Participants note that the discussion is based on a specific section of a textbook that introduces Galilean transformations and form invariance, but does not provide a clear definition of force at this stage. This lack of clarity may contribute to the ongoing debate.
Shirish
I'm reading a section in a textbook on the explanation of covariance of Newton's 2nd law under Galilean boosts. It's explained that ##\mathbf{a}=\mathbf{a'}## (where we're considering two frames ##S## and ##S'## moving inertially w.r.t. each other). Mass is assumed to not vary across the frames, i.e. ##m=m'##: if an observer in ##S## claims that the mass of some particle is ##m##, then an observer in ##S'## also claims the same mass.
So essentially the RHS of Newton's 2nd law is invariant between ##S## and ##S'##: ##m\mathbf{a}=m'\mathbf{a'}##.
Do we implicitly assume here that a given force acting on a given body does not change depending on the frame of reference? Without this assumption, i.e. ##\mathbf{F}=\mathbf{F'}##, I don't see how we can claim that Newton's 2nd law is covariant.
If we assume we know what we mean by the mass of the particle and we can measure ##\mathbf a##, then ##\mathbf F## is defined by Newton's second law.
The point of this exercise, I guess, is to show that if ##\mathbf F## is defined as ##\mathbf F = m \mathbf a##, then ##\mathbf F## is invariant and the second law is covariant.
Sorry if I sound rude, but are we sure about that? If we define the force as ##m\mathbf{a}##, then let's say we shift to any other non-inertial reference frame ##S''##, under whatever transformation, such that ##\mathbf{a}\neq\mathbf{a''}##.
Even in that case, an observer in ##S''## can say that ##\mathbf{F''}## is defined as ##\mathbf{F''}=m\mathbf{a''}##, and so Newton's second law has the same form in ##S''## => it should be covariant across all frames and should be a universal physical law (which, from what I've studied, it isn't outside of inertial reference frames).
I don't have access to your textbook, so I can't say exactly what the author is assuming as postulates or definitions. That's why I used the phrase "I guess".
One way out of this is to define inertial references frames (IRF) as special. Then the force on a particle, for example, is defined by what you measure in an IRF. And, you show that the force you measure in one IRF is the same in them all.
I have no way of knowing how your book intends to proceed.
The section I'm reading is "Coordinate transformations and the principle of covariance". Then it explains two specific types of Galilean transformations: boosts and rotation about the ##z##-axis. Till this point, force isn't mentioned anywhere, just the transformation matrices are derived which is standard stuff.
Immediately after there's a subsection on "Form invariance". I'll quote:
The idea of form invariance can be illustrated using the Galilean transformation, because acceleration is invariant under that transformation: ##\mathbf{a'}\equiv(d^2/dt'^2)\mathbf{r'}=(d^2/dt^2)(\mathbf{r}-\mathbf{v}t)=(d^2/dt^2)\mathbf{r}=\mathbf{a}##. Observers in ##S## and ##S'## agree on the form of Newton's second law: ##\mathbf{F'}=m\mathbf{a'}=m\mathbf{a}=\mathbf{F}##, where mass is the same in all IRFs. What about electromagnetism? (then starts discussing about form invariance of Maxwell's equations).
Hope this gives the exhaustive context. The reason I didn't find the above paragraph satisfactory is that one can't claim the form invariance of the equation ##\mathbf{F}=m\mathbf{a}## without asserting (for some reason that I'm trying to understand) that ##\mathbf{F}=\mathbf{F'}##. Without that assertion, one can only claim that the quantity ##m\mathbf{a}## is invariant across IRFs under a Galilean boost and nothing more (it's true for rotations too but the above paragraph is concerning boosts only).
It seems clear to me that one can say nothing about Newton's laws, their covariance or otherwise until force has been defined in some way. Fundamentally, an equation only makes sense if you can define everything in it.
That said, I assume the author must cover this somewhere. He must say something about what he means by force by this stage in the book.
Totally agree with that statement. As for mentions of force before that point:
1. Force is mentioned as the reason a massive object changes its state of inertial motion.
2. In IRFs, acceleration is caused solely by forces. Forces arise from physical interactions.
Apart from that, no concrete definition of force - it's only mentioned as the reason for acceleration / change in state of motion up until that point.
I guess that counts as being defined by ##m \mathbf a##. Note that any function would do. If ##m## and ##\mathbf a## are invariant, then anything that depends solely on ##m## and ##\mathbb a## must be invariant.
PeroK said:
I guess that counts as being defined by ##m \mathbf a##. Note that any function would do. If ##m## and ##\mathbf a## are invariant, then anything that depends solely on ##m## and ##\mathbb a## mus be invariant.
And I guess we can define ##\mathbf{F}## that way for IRFs because the only source of acceleration in IRFs is force? I mean, even if I go to the non-inertial frame ##S''##, I'm not allowed to define ##\mathbf{F''}=m\mathbf{a''}## (in that case Newton's second law would be covariant across non-IRFs too) since forces aren't the only sources of acceleration (more specifically coordinate acceleration)?
Shirish said:
And I guess we can define ##\mathbf{F}## that way for IRFs because the only source of acceleration in IRFs is force? I mean, even if I go to the non-inertial frame ##S''##, where ##\mathbf{a''}\neq\mathbf{a}##, I'm not allowed to define ##\mathbf{F''}=m\mathbf{a''}## (in that case Newton's second law would be covariant across non-IRFs too) since forces aren't the only sources of acceleration (more specifically coordinate acceleration)?
I think the point is that ##\mathbf a## is definitely not invariant across all reference frames. Whatever else you do ##F = ma## must vary from frame to frame in terms of the quantities involved. Also, ultimately, all that has really been shown here is that ##\mathbf a## is invariant under across IRFs. Nothing really follows from that alone. But, if you make assumptions about mass and force and the relationship between them, then you have a covariant second law.
Makes sense. One last thing: Newton's 2nd law seems to deal with coordinate acceleration. If I defined some other quantity as ##\mathbf{K}\equiv m\mathbf{a_p}##, where ##\mathbf{a_p}## is the proper acceleration, then this "law" ##\mathbf{K}=m\mathbf{a_p}## would hold even in non-inertial frames in Newtonian mechanics, right?
I honestly don't know the role of proper acceleration in classical mechanics.
For the sole particle
1)For the sole particle in the 2 Newton law ##m\boldsymbol a=\boldsymbol F## the force can depend on ##\boldsymbol r,\boldsymbol{\dot r},t## only
2)The Galilean invariance implies ##\boldsymbol F =0##.
This is exactly the 1 Newton law: in an inertial frame the acceleration of the sole particle is equal to zero
For the closed system of ##N## particles $$m_1,\boldsymbol r_1,\ldots, m_N,\boldsymbol r_N\quad m_i\boldsymbol a_i=\boldsymbol F_i;$$
the Galilean invariance implies that the forces ##\boldsymbol F_i## do not depend on ##t## and depend on all kinds of differences ##\boldsymbol r_j-\boldsymbol r_k,\quad \boldsymbol {\dot r}_j-\boldsymbol {\dot r}_k## only
I'm sorry to be stubborn, but I don't think I'm satisfied on an answer to my original question.
I revisited this question recently and just to recap, under a Galilean transformation, we notice that ##a=a'##. We assume that ##m=m'## (Newtonian mechanics).
Let's say Newton's second law holds in one of the frames: ##F=ma## and we want to prove the covariance of this law under the Galilean transformation, i.e., that even in the other frame, ##F'=m'a'(=ma')## holds.
It's easy to show that ##ma=m'a'##, so now we must show that ##F=F'## to actually show that ##F'=m'a'##, since if ##F'=F##, then ##F'=F=ma=m'a'##.
I'm very sure we cannot define ##F=ma## or ##F=m\frac{dv}{dt}##, because then I can trivially claim Newton's second law for all frames - inertial or non-inertial - and for all sorts of transformations.
I have tried my level best to see if ##F\neq F'## produces a contradiction (without assuming any variation of ##F=ma##), but haven't been successful. Would appreciate any help, thanks in advance!
I might have misunderstood, but I will try my best! Newton's first law asserts the existence of IRFs, and Newton's second law can count as a definition of force via. ##\vec{F} = m\vec{a}## in an IRF. Here ##\vec{F}## are real forces (between interacting material bodies) and they fully account for ##\vec{a}## in the IRF. Under a Galilean boost, this ##\vec{a}## is, as you say, an invariant.
You can tell if you are in an accelerated frame of reference since if you hold an accelerometer it will read a non-zero value. Then ##\vec{F} = m\vec{a}## no longer applies, and you would have a means of knowing this via. the accelerometer. Of course you can make Newton II work by introducing inertial forces.
Fair enough, for force defined via the accelerometer reading (to ensure that we're not measuring fictitious forces on top of the physical force), in non-inertial frames Newton's 2nd Law doesn't apply.
But still the main point of the question remains: if we define ##\vec{F} = m\vec{a}## even for IRFs, I can still trivially claim the covariance of Newton's 2nd Law across inertial frames, irrespective of the transformation we use to switch between them, which I don't think is correct.
There's certainly a reason we go through the trouble of proving that ##a=a'## under a Galilean transformation. But that has to be supplemented with a justification of why ##F=F'##. So the point of the question is: what makes us say that ##F=F'## across inertial reference frames?
Forces are frame invariant; i.e. both observers must agree on the extension of a spring, or the distance between two point charges. The physical laws describing these real forces are invariant in all frames (even in accelerating frames!).
Of course, things like magnetic forces throw a bit of a spanner in the works (e.g. ##\vec{F} = q\vec{v}\times\vec{B}##), but then you're really into the realm of relativistic field theory! This isn't really related to your question.
I don't quite understand what you mean by this. If you transform into another IRF (be it via a rotation, or a translation, or a boost, or all three!), then Newton II will hold in that frame too. ##\vec{F}## is the same in all inertial frames, and so is ##\vec{a}##!
Fair enough. So then, "The physical laws describing these real forces are invariant in all frames" - is another assumption/postulate, correct? So then ultimately it all boils down to empirically justifying that forces are frame invariant, right?
etotheipi said:
I don't quite understand what you mean by this. If you transform into another IRF (be it via a rotation, or a translation, or a boost, or all three!), then yes, Newton II will hold in that frame too. ##\vec{F}## is the same in all inertial frames, and so is ##\vec{a}##!
So what I meant was in an argument where we want to show that Newton's 2nd Law is covariant under a Galilean transformation, we should not define ##F=ma##. If, of course, it's true - by assumption or empirical justification - that forces are frame invariant as you said, then my question is resolved.
Obviously I'm aware that forces are frame invariant, but my purpose was to know for sure why we say that. Is it a postulate in Newtonian mechanics, or is it experimentally observed, etc.
For one thing, there is no way of choosing a "preferred" IRF, so if ##\vec{F} = m\vec{a}## holds in one IRF it better hold in all of the other ones (you have proven that if ##x' = x + vt## then it follows ##\dot{x'} = \dot{x} + v## and ##\ddot{x'} = \ddot{x}##, so the force must evidently be the same under a Galilean boost!).
Generally forces in classical mechanics (i.e. gravitational, electric, ...with the exception of the weird magnetic force!) depend only on the relative separation of two particles i.e. ##\vec{F}_{12} = f(\vec{r}_1 - \vec{r}_2)##. The vector ##\vec{r}_1 - \vec{r}_2## is of course invariant in all frames of reference (inertial and non-inertial), so it follows that the force on anyone particle due to a given interaction is also frame invariant.
The second paragraph sounds sensible to me for sure, in the context of Newtonian mechanics (which is what we're focusing on anyway).
I'm not entirely convinced by the first paragraph. All we can say, if ##F=ma## didn't hold in all frames, is that this equation wouldn't represent a physical law. As a parallel, briefly stepping into SR, simultaneity doesn't hold across all IRs and is hence discarded as a physical law. Violation of simultaneity doesn't imply any preferred frame and by the same token, a potential violation of the 2nd law in Newtonian mechanics wouldn't imply a preferred frame either - just that it would have to be thrown out as a physical law.
But again, what you wrote in the second paragraph sounds like a convincing argument so far in favor of the invariance of force magnitude in IRs.
Shirish said:
As a parallel, briefly stepping into SR, simultaneity doesn't hold across all IRs and is hence discarded as a physical law. Violation of simultaneity doesn't imply any preferred frame and by the same token, a potential violation of the 2nd law in Newtonian mechanics wouldn't imply a preferred frame either.
In special relativity the 4-force is a frame invariant quantity, whilst the spatial component (that which we usually call force) is frame variant. Likewise, coordinate accelerations in special relativity are also frame variant between IRFs.
However, the physical law ##\vec{F} = \frac{d\vec{P}}{dt}## is of course valid across all inertial frames.
This is key; a physical law is invariant in all inertial frames of reference. (And classical mechanics, we can also add in 'non-inertial forces' in accelerated frames so that physical laws regain their original form).
etotheipi said:
In special relativity the 4-force is a frame invariant quantity, whilst the spatial component (that which we usually call force) is frame variant. Likewise, accelerations in special relativity are also frame variant.
Fair enough, but I didn't claim that the physical law ##\vec{F} = \frac{d\vec{P}}{dt}## isn't valid across IRs in SR. In any case, SR is a completely different ballgame so I'll refrain from getting deeper into that for this thread at least (another reason is that I've yet to properly study relativistic dynamics and want to clear up my concepts in the Newtonian domain first :-p). Still don't think the principle of relativity is sufficient to claim invariance of force across IRs in Newtonian mechanics.
Ak okay, yes apologies if I misinterpreted your post!
No, perhaps not. What I was trying to say is that if you accept that accelerations are invariant under a Galilean boost, and that if you also accept ##\vec{F} = m\vec{a}## as a definition for IRFs, then it must follow that ##\vec{F}## be invariant under a Galilean boost too! In other words, if it works in my frame, then it must still work for someone running at 5ms-1 alongside me, since they are both equally valid as choices of IRF.
Maybe someone else can provide further insight? :smile:
The chain of reasoning I'm looking for is in a different direction, i.e. if we accept that accelerations are invariant under a Galilean boost, and if we have a justification for the claim that ##\vec{F}## is invariant under a Galilean boost too, then it must follow that ##\vec{F} = m\vec{a}## holds in IRFs (which is essentially the covariance of Newton's second law).
That justification is what I'm looking for. From our discussions (and thanks so much for the help btw) so far, the justification is empirical / the fact that physical laws giving rise to the forces depend only on invariant quantities like the length separation.
Shirish said:
The justification I wanted was in the other direction, i.e. if we accept that accelerations are invariant under a Galilean boost, and if we have a justification for the claim that ##\vec{F}## is invariant under a Galilean boost too, then it must follow that ##\vec{F} = m\vec{a}## holds in IRFs.
I see; however I think this is backward. Even if you could justify that forces and accelerations are invariant under Galilean boosts, it still doesn't tell you that the constant of proportionality is ##m##.
IMO the most consistent way to view it is to take Newton's three laws as axioms for classical mechanics in inertial reference frames. You can prove that accelerations are invariant under the Galilean boost, and it pretty much then follows that forces are frame invariant too.
It's up to you how you choose to try to learn physics, but with this approach you seem to be spending a lot of time going round in circles.
Newton's laws are supposed to be conceptually simple. I really can't understand the problem here.
You're probably right and it probably doesn't matter in the grand scheme of Physics understanding, but the fact still remains I didn't like the unsatisfactory reasoning for covariance of Newton's 2nd Law from wherever I looked it up from (for example, https://www.quora.com/How-do-you-pr...nertial-frames-under-Galilean-transformations).
It's very important to me to have a very clear understanding of what's considered an axiom/postulate based on empirical observations, and what all are mathematically/logically derived consequences.
Specifically for this type of question, I felt that distinction wasn't there.
If ##F=ma## holds in an inertial frame and we can show that ##a## is invariant under a Galilean boost then either ##F## is also invariant or Galilean relativity does not hold. By the latter, I mean that we could measure the force required to accelerate an object at ##a## in two different frames and get a different value, violating the principle of relativity and allowing us to deduce an absolute speed for the frame.
We have never been able to detect an absolute speed in reality. That eliminates the second possibility, leading to the claim that ##F## is also invariant under Galilean boost.
Could you elaborate a bit more on this? How do we measure the force required to accelerate an object at ##a## without assuming ##F=ma## in ##S'##?
And how can we deduce an absolute speed for the frame in this scenario?
You use a force meter (e.g., a spring) and an accelerometer (e.g. a clock and a ruler). ##F=ma## is a statement about the relationship between their readings, and assuming Galilean relativity it tells you that the relationship will always be the same independent of speed. If relativity does not hold then the same devices will give different readings when in different states of motion.
Absolute speed was possibly not the right word, but if ##F'## is not the same value as ##F## then it must be larger or smaller. You could then keep track of ##F'## to measure your speed. With the additional assumption that there's a frame where the force takes a macimum or minimum value, it would be reasonable to conclude that this corresponds to a universal state of "at rest".
The first point follows from a failure of the principle of relativity. The latter does require an additional assumption about the mathematical form of that failure, yes.
  • · Replies 35 ·
  • · Replies 0 ·
  • · Replies 19 ·
10K
  • · Replies 117 ·
10K
