Help! EM Exam: Covariant LW Fields Derivation Questions
decerto
Hi I am doing some exam revision for an EM class and I'm trying to understand a few things about this derivation. Specifically in equation 18.23 why do we not consider the derivative of the four velocity i.e ##\partial^{\alpha}U^\beta##
Then going from 18.23 to 18.25 why is ##\frac{\partial(x-r(\tau))}{\partial x_\alpha}=2(x-r(\tau)^\alpha)##, where explicitly does the upper alpha come from?
Also in computing these fields he goes back and uses the integral representation of the potential why is this done as opposed to calculating ##\partial^\alpha \frac{e\mu_0c}{4\pi}\frac{U^\beta(\tau)}{U\cdot [x-r(\tau)]}|_{\tau_0}##
In the expression
A^\alpha = C \int d\tau U^\alpha \theta(x_0 - r_0(\tau)) \delta([x - r(\tau)]^2)
there are two positions involved. You are considering A^\alpha at some position x^\mu, and you are considering the contribution due to a point-mass at position r^\mu. U^\alpha is equal to \frac{d}{d\tau} r^\alpha. It doesn't depend on x^\mu.
Because of the weird metric used in SR, if Q is a 4-vector, then
Q^2 = (Q^0)^2 - (Q^1)^2 - (Q^2)^2 - (Q^3)^2
So (x - r(\tau))^2 = (x^0 - r^0(\tau))^2 - (x^1 - r^1(\tau))^2 -(x^2 - r^2(\tau))^2 -(x^3 - r^3(\tau))^2
So we have 4 equations:
  1. \frac{\partial}{\partial x^0} (x - r(\tau))^2 = 2 (x^0 - r^0(\tau))
  2. \frac{\partial}{\partial x^1} (x - r(\tau))^2 = -2 (x^1 - r^1(\tau))
  3. \frac{\partial}{\partial x^2} (x - r(\tau))^2 = -2 (x^2 - r^2(\tau))
  4. \frac{\partial}{\partial x^3} (x - r(\tau))^2 = -2 (x^3 - r^3(\tau))
Those can be summarized by:
\frac{\partial}{\partial x^\alpha} (x - r(\tau))^2 = 2 (x_\alpha - r_\alpha(\tau))
where x_\alpha = \pm x^\alpha, with the plus sign only in the case \alpha = 0
Now, if we instead do \frac{\partial}{\partial x_\alpha}, then we get, instead
  1. \frac{\partial}{\partial x_0} (x - r(\tau))^2 = 2 (x^0 - r^0(\tau))
  2. \frac{\partial}{\partial x_1} (x - r(\tau))^2 = +2 (x^1 - r^1(\tau))
  3. \frac{\partial}{\partial x_2} (x - r(\tau))^2 = +2 (x^2 - r^2(\tau))
  4. \frac{\partial}{\partial x_3} (x - r(\tau))^2 = +2 (x^3 - r^3(\tau))
That's because again x_\alpha = \pm x^\alpha, so the signs change for all cases except for the \alpha = 0 case. That can be summarized by:
\frac{\partial}{\partial x_\alpha} (x - r(\tau))^2 = 2 (x^\alpha - r^\alpha(\tau))
I don't know, he just thought it was easier that way.
Likes decerto
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
