Create a Moving Sun Sculpture: DIY Art Project Help and Advice
  • Context: Electrical
  • Thread starter Thread starter TwelweTwo
    Art Diy Project
The discussion revolves around creating a moving sculpture inspired by the sun, with a focus on the technical aspects of achieving synchronized circular and vertical movements. Participants explore various mechanical and electronic solutions, including motor types and control systems, while considering design elements and artistic implications.
  • Experimental/applied
  • One participant proposes a moving sculpture that references the sun, suggesting a lamp that moves in a circular and vertical manner.
  • Another participant inquires about the speed of the up/down movement, suggesting that a single motor might suffice if synchronized correctly.
  • A participant confirms that the desired motion should create a tilted ellipse, with a cycle time of around 30 minutes, and considers using one motor for simplicity.
  • There are questions about the design, including whether the lamp will be stationary or if it will orbit another object, with suggestions of a black hole as a potential central theme.
  • Technical suggestions include tilting the main rotor shaft and using different motors for varying arm lengths to achieve the elliptical motion.
  • Participants discuss the feasibility of using a Raspberry Pi and geared stepper motors for control, emphasizing the need for technical assistance and resources.
  • One participant expresses concern about the visibility of the rope in the sculpture and its impact on the overall aesthetic.
  • Another participant suggests using fishing line and pulleys to minimize friction and enhance the sculpture's movement.
  • There are discussions about the design elements, including the use of transparent materials to blend with the environment.
Participants express a range of ideas and suggestions, with no clear consensus on the best approach or design. Multiple competing views on the mechanics and aesthetics of the sculpture remain unresolved.
Participants mention various technical details and assumptions, such as the weight of the lamp, the size of the sculpture, and the synchronization of movements, which may influence the final design but are not fully established.
Artists interested in kinetic sculpture, hobbyists exploring DIY projects involving motors and electronics, and individuals seeking creative ways to integrate art with technology may find this discussion valuable.
TwelweTwo
Hello! I am an aspiring artist and have a terrible expertise in tech, but I have this idea in mind and strong desire to make it come to life, so I was hoping I could get some help here.
The idea is to create a moving sculpture which is going to refer to the sun. What you see in the sketch 2 as a circle is basically a lamp and I want to make make it move across the room. The movement that I want to make is primitively represented in the first sketch. I want it to move in circle on the plane parallel to the ceiling and up and down vertically (simultaneously).
I figured that I will need 2 moving elements, so first obviously the motor to make the circular movement. For the vertical movement I want to attach the lamp to the thread and have a mechanism to pull/release it. I also need to synchronise those two movements. More specifically I need to know what kind of motors I need to look for and how to connect them and what to use a central hub to orchestrate the movement ( I am thinking Arduino?).
As for the weight of the lamp I am not quite sure yet, as I don't have a prototype yet and the size of the whole construction will depend on the room that will be available to me, but I am estimating max. 10kg.
As I said I have very little knowledge in the technical aspect necessary for the execution and I don't really know where to start, I would very much appreciate if you guys can give me some practical advices or point me in the right direction for research.
How quickly is it supposed to move up/down? One cycle per revolution (making the overall motion a tilted ellipse)? Much slower? Faster? If the motion is synchronized it might be possible to make both with a single motor.
Some other numbers would be useful as well.
First of all, thanks for reply!
Precisely that. The movement should give a tilted ellipse as a result. I am imagining one cycle should take around 30min, but I am considering coming up with a more interesting number related to cosmological constant for example. Using one motor will make my life much easier I imagine, but I was not sure how that can be achieved.
The whole construction will be attached to the ceiling. As for the numbers I am not sure what exactly you mean? If you mean the size wise, I cannot say that for sure, but I think radius of the circle will be from 2 to 3 meters and the lamp should be 1 meter in the diameter.
What does that mean? Are you going to have a stationary lamp globe in the center, and your oribiting object will be like a planet? Or is the moving object going to be lit up? If the latter, what is it supposed to be orbiting? A Black Hole maybe?
In any case, to have it rotate on a tilted axis, you can tilt the main rotor shaft. To get it to move in and out in an ellipse shape, you can change the arm length from the shaft to the object as a function of the angle around the arc. To get a nice ellipse, it may be necessary to use a different motor for the arm length changes. Maybe use a simple geared-down motor that is synchronous with the 50Hz/60Hz AC Mains power frequency (geared down to your low rotation rate like a clock), and use a stepper motor to linearly actuate the radius arm to give you an ellipse. That is pretty easy to do with an Arduino microcontroller, for example.
Can you pay an artist's sketch of your concept?
The moving part will be the sun which is going to be lit up, I was thinking that it will orbit the galaxy which is going to be suggested by the object on the floor possibly similar to the one in the photo. But it is not established yet and to be honest I love the black hole idea!
Thanks for the suggestion I will look into the method you described.
Sorry I don't understand what you mean?
Sorry, auto spell.
Call
Sorry.
Can you post an artist's sketch.
anorlunda said:
Sorry, auto spell.
Call
Sorry.
Here is something I sketched out, I hope it won't make things more confusing, hehe. It basically shows two extremum points of the movement the way I have initially thought about this.
  • Doc Aug 06, 2019 12:30_0.jpeg
If the end of the rope that is fixed at the wall is far enough away from the rotating arm then the motion of the sphere is nearly elliptical with the plane of the ellipse tilted at a 45 degree angle from the floor?
@Spinnor: That's what I was thinking about.
It doesn't have to be a wall, mounting something to the ceiling works as well as long as it is outside the area the rotating arm covers and ends lower than that arm.
Thanks for the replies guys, I will try it with the method you suggested, however I will only have the opportunity to work on it full-scale in September. For fun here is the link to a quick prototype I made today from the sketch of Spinnor https://we.tl/t-fru9vbzPRp .
I think I like the elegance and straight-forwardness of this method but I am a bit afraid that the rope will become too prevailing element of sculpture, but that will only be clear once I make a first full size try out.
You could use the right size fishing line, very strong and thin. You also might use a small pulley to reduce friction for the fishing line.
With regard to the ellipse, if using the post #10 method with a cord, an ellipse major chord length twice that of the ellipse minor chord based upon the diameter of the rotating arm can be created by using a single sheave pulley at the wall and a double sheave swiveled pulley on the arm with the end of the cord connected to the wall/ceiling location of the single pulley.
Additionally, by using a transparent fishing line, as suggested above, and painting the arm and its pulley assembly to match the room ceiling color and a similarly colored cover with a side opening for the wall or ceiling mounted pulley assembly you might minimize the distraction by those elements, at least for non-STEM viewers who are going to immediately start investigating how you achieved your ellipse motion anyway.
Thanks for the in depth answer!
  • · Replies 31 ·
  • · Replies 41 ·
