Discover the Magic of Soap Making: Experiment with Different Solutions at Home
  • Thread starter Thread starter Klutch1
    Soap
Creating homemade soap solutions for dishwashing, carpet cleaning, and car cleaning involves understanding the basic chemistry of soap, primarily through a process called saponification, which combines oils and a base, typically lye (sodium hydroxide or potassium hydroxide). While simple soap recipes can be found online, effective cleaning solutions, especially for carpets, require more complex formulations. Most commercial cleaning products do not rely solely on the basic soap recipe of base, oil, and water; instead, they often utilize synthetic detergents like alkyl or aryl sulfonates and polyethoxylated compounds. For those looking to delve deeper into soap and detergent formulation, resources such as McCutcheon's "Functional Materials" and "Emulsifiers and Detergents" can provide valuable insights and guidance. Safety is crucial when working with lye, as it is a caustic substance, and proper handling and heating techniques should be employed.
Klutch1
I want to start a home project to creating different soap solutions. Dish washing detergent, carpet cleaning solution, and car cleaning soap are my main focuses. I have no idea where to start as my internet research is getting no where.
What is soap made of and how can I experiment with different solutions?
What kind of tools will be needed?
Chemistry news on Phys.org
The process is called saponification, using oil and base ( lye ). Lye can be either sodium hydroxide or potassium hydroxide depending on the recipee and type of soap desired.
It is not as simple as it looks to make a suitable soap, since you are dealing with a caustic substance ( lye ). Depending upon your process you may be heating the oil of fat so do that in a safe way.
Some people make this into a hobby soap making business.
I have completed a little research and it seems that soap is made from a base+oil+water. Creating a carpet cleaner is more of creating a shampoo. Base (lye) and and a oil seems to be the way you create hand soaps or dish washing soaps. Which is very useful, figuring out the chemical compounds in a carpet cleaning solution seem to be allot more complex. I really want to start creating many of these types of chemicals but cannot find a starting point.
When carpet cleaning companies create solutions does it all derive from the basic recipe of base+oil+water=soap?
Almost never. Simple soaps based on fats and oils are rarely used for the purposes you are interested in. Most detergents are alkyl or aryl sulfonates or are polyethoxylated phenols or alcohols.
A good place to start looking is McCutcheon's" Functional Materials" and "Emulsifiers and Detergents".
http://shop.gomc.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=TMC&Category_Code=mccutch
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
