Creating Table of contents in PDF
  • Thread starter Thread starter ComputerGeek
    Pdf Table
To modify a PDF file to include a Table of Contents (TOC) that allows for easy navigation, it is suggested to first write the component sections of the document and convert them into a PDF. After creating the sections, a TOC should be written and hyperlinked to the respective sections before generating the final PDF. For converting an existing PDF into a navigable format without using Adobe Acrobat, a series of command-line tools can be utilized on a Unix machine. The process involves converting the PDF to PostScript using pdf2ps, then to HTML with ps2html, generating a TOC with htmltoc, converting back to PostScript with html2ps (using the --toc option), and finally converting the PostScript back to PDF using ps2pdf. This method aims to enhance the document's navigability by allowing users to click on sections in the TOC to jump directly to the desired content.
ComputerGeek
I was wondering.. How can you modify a PF file to have the TOC organization in the drawer rather than the flat page preview?
Some PDFs of large documents have an organization that separates the PDF into sections and when you select that element or an element from the tree below an element, it jumps to that page.
any Idea how I can add that to a PDF so it is no so obnoxious to navigate?
Computer science news on Phys.org
Try writing the component sections then converting them to a PDF. When all is said and done, write the TOC and hyper-link the sections before creating the PDF of the TOC...
Actually, I was hoping for help on taking an Old PDF I got on line and converting it to such a system so I can just click on the section I want to jump to. I do not have Acrobat either.
Do you have access to a unix machine?
If so you can do this:
pdf2ps (convert pdf to postscript)
ps2html (convert postscript to html)
htmltoc (generate table of contents)
html2ps (convert html to postscript) make sure to use the --toc option
ps2pdf (convert postscript to pdf)
I think it should work, but I'm not sure. Try it if you can.
In my discussions elsewhere, I've noticed a lot of disagreement regarding AI. A question that comes up is, "Is AI hype?" Unfortunately, when this question is asked, the one asking, as far as I can tell, may mean one of three things which can lead to lots of confusion. I'll list them out now for clarity. 1. Can AI do everything a human can do and how close are we to that? 2. Are corporations and governments using the promise of AI to gain more power for themselves? 3. Are AI and transhumans...
Thread 'ChatGPT Examples, Good and Bad'
I've been experimenting with ChatGPT. Some results are good, some very very bad. I think examples can help expose the properties of this AI. Maybe you can post some of your favorite examples and tell us what they reveal about the properties of this AI. (I had problems with copy/paste of text and formatting, so I'm posting my examples as screen shots. That is a promising start. :smile: But then I provided values V=1, R1=1, R2=2, R3=3 and asked for the value of I. At first, it said...
