What Is a Crosspoint Switch in Electronics?
The discussion revolves around the concept of a crosspoint switch in electronics, specifically focusing on the existence and functionality of criss-cross resistor networks for signal routing. Participants explore both passive and active solutions, as well as the potential for DIY implementations versus commercially available options.
  • One participant inquires about a criss-cross resistor network that can connect inputs and outputs in both straight and cross configurations.
  • Another participant suggests that a passive crosspoint switch can be created using resistors and analog multiplexers.
  • A different participant expresses a preference for existing solutions rather than DIY options, indicating a desire for simplicity.
  • One participant provides a link to a commercial crosspoint switch, noting that bandwidth and headroom requirements are unknown.
  • Another participant confirms the existence of a criss-cross resistor network, explaining that it is commonly referred to as a crosspoint or crossbar switch, but emphasizes that it typically requires external control and is not passive.
  • Additional alternatives such as multiplexers and demultiplexers are mentioned as potentially simpler options depending on the application.
Participants express differing views on the nature of crosspoint switches, particularly regarding whether they can be passive or require external control. There is no consensus on a specific solution, as some prefer DIY approaches while others seek existing commercial products.
Participants do not specify bandwidth or headroom requirements, which may influence the choice of components. The discussion also highlights the distinction between passive and active switching solutions without resolving the implications of these differences.
Individuals interested in electronics design, particularly those exploring signal routing solutions or looking for components for specific applications in circuit design.
likephysics
Does a criss-cross resistor network exist?
I need something (preferably passive), that comes in both criss cross and straight paths.
Maybe a switching array of some sort?
I am looking for something that connects-
A-->A
B-->B
C-->C
D-->D
and
A-->D
B-->C
C-->B
D-->A
It can be 2 different parts for straight and cross connection. But the package has to be same.
I know I can use FPGA/CPLD. But I want something simpler.
What you want is called a passive crosspoint switch. You can easily make one yourself with a few resistors and four 2-1 analog muxes.
Well, making one is the last option. I wanted to check if anything already existed.
I can confirm that a criss-cross resistor network does exist. It is commonly referred to as a "crosspoint switch" or "crossbar switch" and is used in electronic circuits for routing signals between different inputs and outputs. This type of network allows for both straight and cross connections, as described in the content. However, it is not a passive component and typically requires external control to switch between connections. There are also other types of switching arrays available, such as multiplexers and demultiplexers, which may better suit the desired simplicity. Ultimately, the specific component or circuit design will depend on the specific application and requirements.
  • · Replies 17 ·
  • · Replies 19 ·
  • · Replies 31 ·
