hilarious
- 1
In the cross product, why is vectorA*B=-(vectorB*A)
How does the right-hand rule apply to this formula?
Apply the definition of cross producthilarious said:In the cross product, why is vectorA*B=-(vectorB*A)
hilarious said:How does the right-hand rule apply to this formula?
The cross product, also known as the vector product, is a mathematical operation between two vectors that results in a third vector. It is used to determine the direction and magnitude of a vector perpendicular to the two original vectors.
The cross product is calculated using the right-hand rule, which involves taking the first vector in your right hand, pointing your fingers in the direction of the second vector, and then curling your fingers towards the first vector. The direction of the resulting vector will be perpendicular to both original vectors.
The right-hand rule is used for the cross product because it is a convention that helps us determine the direction of the resulting vector in a consistent and intuitive way. It also allows us to visualize the vector in 3D space.
The direction of the cross product is significant because it tells us the orientation of the resulting vector in relation to the two original vectors. This is important in many applications, such as determining torque in physics and the direction of rotation in engineering.
No, the cross product can only be calculated in 3D space. In 2D space, the cross product would result in a vector with a magnitude of 0, as there is no perpendicular direction to the two original vectors.
