What is the most cost-effective method for determining crystallization pressure?
  • Thread starter Thread starter kubedgamer
    Pressure
The discussion focuses on finding a cost-effective method to determine the crystallization pressure of an unknown fluid. A suggested approach involves using an anvil cell, which is noted for its affordability and effectiveness in measuring pressures during crystallization. Participants highlight the challenges posed by the unknown properties of the fluid, such as its melting point, which can complicate experimental setups. A referenced paper discusses measuring pressures from freezing ice but is deemed unsuitable for the specific needs of the inquiry. Ultimately, the anvil cell is recommended as the most economical option for this purpose.
kubedgamer
Given an unknown fluid, what would be an efficient and/or cheap way of finding it's crystallization pressure through experiment.
I would like to keep costs at a minimum and work from off the shelf components if possible.
Hi kubedgamer,
A seemingly cheap setup is described here:
http://www.igsoc.org/journal.old/10/59/igs_journal_vol10_issue059_pg312-315.pdf
When you say unknown liquid, it could mean that a given setup will be easily inadequate by the virtue of the liquids unknown melting point and overall behavior.
Lok said:
Hi kubedgamer,
Hi Lok,
Thanks for your reply.
I saw that paper earlier, unfortunately they're focusing on finding the pressure exerted by freezing ice against an obstacle.
"Polycrystalline ice, growing from the melt, can exert a pressure against an extended obstacle,
even though it is free to grow in other directions. Pressures of over 0.2 bar (20kl m-z) have been measured
with simple apparatus. This phenomenon may be important in explaining the frost-shattering of rocks"
Unfortunately, not what I'm after :(
So you would like to find... the pressure at which the unknown liquid freezes?
That's correct :)
In this case I cannot imagine something cheaper than the obvious anvil cell.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
