Maintaining Constant RMS Current in an AC L-R Circuit
The discussion focuses on maintaining a constant RMS current in an AC L-R circuit to achieve a stable magnetic field strength in a solenoid while varying the frequency from 1 to 5000 Hz. The current regulator in use is only maintaining voltage, leading to insufficient current flow at high frequencies. Suggestions include using L-C tank circuits with different resonances, transistors to manage capacitors, or sizing a capacitor to ensure adequate current while shunting excess. Concerns are raised about the potential overheating of transistors at high voltages and the need for specific current and frequency requirements. The conversation seeks practical solutions and advice on whether to purchase or build a suitable device.
enigma
Staff Emeritus
I'm working with a device which is basically an AC L-R circuit.
The device I have hooked up to the voltage supply which I was informed was a 'current regulator' is only maintaining a constant voltage. This results in a trickle of current to flow through at high frequencies.
I need to find a way to keep a constant RMS current running through the solenoid (I need a relatively constant P-P magnetic field strength) while the frequency of the AC current varies from one to several thousand Hz. Discrete increments may be OK, but a dynamically varying capacitance would be optimal.
I know they have these devices, because the power companies have capacitor banks attached to power poles. What I don't know is what they are actually called, whether they are dynamic or discrete, how much they cost, and if it's easier to buy them or make one.
Any information would be helpful.
-thanks
Hmm.. I find myself wondering if a current mirror can operate in AC... let me think about this.
- Warren
My preliminary thoughts are to somehow link up a bunch of L-C tank circuits with different resonances hooked up to (in sequence) inverters, an RC with low resistances, and then transistors which would turn on and off capacitors for the main LRC.
EDIT: I am concerned with this one that the transistors will get cooked if operated in 100V AC
Another option might be to simply size a capacitor to provide at least the required current at the voltage limit over a wide enough operating band (with the very low frequencies clipped, obviously). Then somehow shunt the current if it exceeds the peak level. This won't result in a clean sine wave, but I think I can deal with that since the material we're testing will be reaching saturation levels before the field hits full strength anyway.
*bump*
Anyone have any comments or ideas here?
Can you give me some specifics to work with? How much current do you need? What frequency? How much impedance will the coil have at its worst frequency?
- Warren
The current will not be more than 2 Amps, and will most likely be quite a bit less.
Frequency will range between 1 and 5000Hz
The current coil's inductance is in the 10 milliHenry range, although that may change a bit (no more than by 10^(+-1)).
The resistance of the coil is ~9 ohms, but again that may change if we wind a new one.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
