Current flow through conductor immersed in water
The discussion revolves around the challenges of inducing and maintaining a magnetic field in a small conductive particle immersed in water. The particle's conductivity is significantly higher than that of water, which complicates the ability to generate a strong electromagnetic field without bypassing the particle. Participants note that the decay time of the induced magnetic effect is extremely short, making it difficult to achieve useful velocities for the particle after disconnecting the power source. There is also a consensus that water, being a poor conductor, would not effectively facilitate the desired current flow to the particle. The conversation highlights the complexities of using conductive materials in non-ideal environments, emphasizing the need for careful consideration of the medium's properties.
BernieM
I have a small conductive, non-magnetic particle in which I will induce a fairly strong electromagnetic field into using a flow of current. I will then disconnect the power source that makes the particle electromagnetic. How long will it take the magnetic effect of the particle to diminish? Particle conductivity is around 5x10^7 sieverts. Particle diameter (assume round) is about .1mm
My first reaction would be to relate the rate of change of induced field around the particle to treat the particle as a half wave dipole and think of its resonant frequency. You will induce a current in this dipole (how will you couple it to produce a "strong field"?). The tuned frequency of a 2mm dipole is around 75GHz. So the decay time would be less than the order of the period (1.5 e-11 s).
It will momentarily be a part of a complete circuit as a dead short. Think rail gun where the projectile is momentarily in contact with the rails as part of the armature.
The time domain you mention I believe is way too short to be of use to me.
I was going to break the contact with the circuit using a very strong magnetic field and was hoping that in the short time that it retained it's magnetic field that I could accelerate it to a useful velocity (which isn't very fast, >.5m/s and <5m/s)
With as short a time as you mention, I think the magnetic field would have to be nearly astronomically strong to get it to those velocities. But that's why I am asking the questions, because I don't know for sure.
The surface spark produced when such current through the particle is abruptly broken may result in the particle being vapourised, or at least alloyed with the contact surface.
EDIT forget that, the title indicates immersion in water. Conductive water?
Water will be on the order of micro to millisieverts conductivity. Think typical ground water or river water(is there such a thing as typical? ok so not a whole lot dissolved metals in the water but some like calcium and iron,) not salt water.
I think you'll have no hope of getting worthwhile current through particles immersed in a conductive medium. You'd like the medium to conduct current to your particles but not bypass around them? I can't see it happening.
Water is not a good conductor. In World War II when the Germans could no longer get transformer oil for their power line transformers from the USA, they used deionized water in them with excellent results. When the particle is in circuit the resistance is extremely low in the path through the particle, while the resistance through the water is extremely high. It should work like a pair of resistors in parallel, one having high resistance, the other low, and so Ohm's law says most of the current will take the low resistance path to ground.
Haha, really? I didn't know that
Not only ancient transformers but, in these modern times, High Power Radio transmitters use deionised water to cool anodes, at many kV, which dissipate hundreds of kW. Water is a pretty good insulator. But these particles would need to be chemically isolated from the insulating water or any ions from their surface would rapidly contaminate the water and it would no longer insulate.
Do you have some link? Modern high power radio transmitters I know about are all realized on the basis of solid state power electronics.
I feel this is a bit like the Crocodile Dundee line:" that's not a knife, THIS is a knife!"
When I say High Power, I mean 100kW+ and http://www.contelec.com/sw418drmfeatures.htm. I don't know how high power the solid state transmitters go but this valve transmitter is current, afaik.
There are alsohttps://www.thalesgroup.com/en/microwave-imaging-sub-systems/iots-uhf-tv-broadcast that use 80kW+ Klystrons. They also have a water cooled collector, I believe, which operates at high Volts. Klystrons are terrific value with both high power and high gain- all in one device.
Thanks. SS can go pretty high in power. First found : http://www.nautel.com/solutions/high-power-mw-nx-series-100kw-2mw/
Normally, UHF TV frequency range is too high for SS . Klystrons beasts are used instead for UHF and very high powers.
