cremedelacreme
- 8
A copper wire of cross sectional area 2 mm^2 carries a current of 10 A. How many electrons pass through a given cross sectional of the wire in one second?
Nope. That's Ohm's law. Hint: What does the unit Ampere mean? 1 A = ??cremedelacreme said:Err V= IR?
Perhaps the area is irrelevant.But I don't know how to relate with Area...
Right!cremedelacreme said:Ampere = Charge / Time
Careful: If Current = charge/time then charge = current * time.So
Charge = Ampere / Time
Good!ooh
we find the charge
and since
one electron has a charge of 1.6 x 10^-19
thus, we divide the charge by the charge of one electron...
On average, one ampere (A) of current represents the flow of approximately 6.24 x 10^18 electrons per second through a conductor. Therefore, the number of electrons flowing through a copper wire per second depends on the amount of current passing through it.
The number of electrons in a copper wire does not directly affect its conductivity. Instead, it is the arrangement and mobility of these electrons that determine the wire's conductivity. Copper is a good conductor because it has a large number of free electrons that are able to move easily through the metal.
While the atoms in a copper wire are indeed neutral, they contain negatively charged electrons that are able to move freely within the metal. When a voltage is applied, these electrons are able to flow from one end of the wire to the other, carrying electricity with them.
The number of electrons in a copper wire remains constant, as the number of protons and electrons in an atom are always equal. However, the number of free electrons (also known as conduction electrons) can change depending on external factors such as temperature and applied voltage.
The number of electrons in a copper wire does not have a direct effect on its magnetic properties. However, the flow of electrons through the wire can create a magnetic field, which can be strengthened or weakened by the number of turns in the wire (known as the number of loops or coils) and the amount of current flowing through it.
