Current through a bound cross-section
To find the current through the outer section of a wire with a given current density J = (3.07 × 10^8)r^2, one must calculate the current by integrating the current density over the specified area between r = 0.917R and r = R. The area of the bounded section is determined by subtracting the area of the inner bound from the outer bound, but simply using the areas is incorrect due to the dependence of current density on radial position. The correct approach involves setting up the integral ∫ J ⋅ dA, where dA must be expressed in terms of r. This integration will yield the accurate current value in the desired region, addressing the initial miscalculation.
Destroxia
[/B]
The magnitude J of the current density in a certain wire with a circular cross section of radius R = 2.20 mm is given by J = (3.07 × 108)r2, with J in amperes per square meter and radial distance r in meters. What is the current through the outer section bounded by r = 0.917R and r = R?
Givens
R = 2.20 mm = 2.20E-3
J = (3.07E8)r^2
r = .917R (inner bound)
r = R (outer bound)
Cross section of wire (area) = [/B]pi(r)^2
Current Density =
J = I/A
[/B]
Since we are attempting to find the current in a bounded section we need to subtract the outer bound area from the lower bound area:
pi(R)^2 - pi(.917R)^2 = bounded section area
Since we have the current density we can use I = JA:
(3.07E8)r^2* ( pi(R)^2 - pi(.917R)^2) = 736.8
It wants the answer in mA so = 736000 mA
It says my answer is incorrect, and I'm not sure where I went wrong.
Apparently the current density depends upon the radial position within the conductor. So you can't simply deal with the areas involved, you need to take into account the current density over the cross section. You'll need to set up an integral to compute the current in the desired region.
So am I only going to be integrating the area, or will the current density be involved? Is it the equation ∫ J ⋅ dA ?
∫ J ⋅ dA is the appropriate notion. You'll have to work out the details since J is a function of r, and you'll need to express the differential area element dA in terms of r, too.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
