Current Transform and Mesh Analysis
The discussion revolves around solving mesh analysis problems in circuit theory, specifically focusing on problems 4.2 and 4.3. The user successfully solved problem 4.2 but struggled with redrawing the circuit for problem 4.3, which required identifying three mesh currents despite only seeing two meshes. After considerable effort, they realized that applying Kirchhoff's Current Law (KCL) with the current supply from the original circuit allowed them to derive the third mesh current. The user's professor confirmed this approach as correct, leading to a resolution after several hours of work. The discussion highlights the importance of understanding transformations and applying KCL in mesh analysis.
naosyth
1 Problem Statement:
2 Relevant Equations
KVL
KCL
Ohm's Law
3 Attempt at Solution
I solved Problem 4.2, which was just mesh analysis on the original problem. I got the correct answers, indicated by F.A. The problem I am having with 4.3 is how to redraw the circuit with the indicated changes. When I redraw it, I am left with only two meshes, but I need to find three mesh currents. All I really need is to be pointed in the right direction on how to redraw the circuit, and where the three mesh currents would be. I have been working on this for hours and have tried too many things to list it all here...
Edit: This is where I am at so far:
Ignore the equations under the circuit, that was just me trying random ideas...
I don't see why you need three mesh currents.
I don't either, that's the problem. The question says the find the mesh currents, and lists three answers. Without the current transform, then it is an easy problem. With the transform though, I am quite confused...
Aha! I got it! When you do the transformation, you get two meshes, but then you apply KCL with one of the meshes and the 13A current supply from the original circuit to get the third mesh current. My professor replied to my email shortly after I did this, and confirmed that this is the correct solution! It feels good finally solving this, after 4 hours!
Yeah - you only needed to find three currents.
In the first version of the problem, they corresponded to the meshes.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
