Curvature of Time: How Do We Experience It?
  • Thread starter Thread starter sanman
    Curvature Time
sanman
We can all see what curvature of space looks like, just by throwing a ball and watching it follow the natural geodesic.
But what does curvature of time look like?
How do we experience it?
We typically experience the passage of time in what seems to be a forward linear manner. The forward part seems to be due to how our nervous system works, thus giving a chronological bias towards causality in our perception.
But if we can see how gravity curves space, then how do we percieve how it affects time?
Time dilation.
Garth
But Time Dilation isn't supposed to happen unless we approach some significant fraction of the speed of light. Meanwhile, we can observe the curvature of space even when standing totally still, can't we?
Are we saying that acceleration towards the speed of light is similar to an object undergoing freefall, whereby it moves according to the natural geodesic curve of space? So then "time dilation" or curvature of time, becomes apparent or manifest to us due to lightspeed being a reference frame analogous to freefall?
Due to the constraints of our nervous system, we tend to perceive T as an ordinal axis, compared to X,Y,Z where we have full degrees of freedom along each axis.
So when we don't have full freedom on the T-axis, and can only experience it in a "forward time" direction, then we can only experience this time dilation as a deviation or discrepancy in the passage of time.
If Time could move backwards, we could experience gravity as a repulsive force, and then presumably would we similarly experience the curvature of time as "time contraction" instead of time dilation?
No that involves the curvature of both space and time.
No. Time dilation happens anytime there's gravity, and anytime any two things are moving in relation to one another. You're experiencing a kind of time dilation right now by sitting in the Earth's gravitational well. When you fly in an airplane, you're experiencing another kind of time dilation.
The magnitude of these time dilations is very small by human standards, so you don't really notice it. It is observable with atomic clocks, however.
The force keeping your butt in the chair is, in fact, a result of the curvature of space. You might need to consider that you cannot have curvature in space without curvature in time.
No, objects that are accelerated do not follow geodesics.
Light speed is not a frame of reference. A reference frame is nothing more than a coordinate system, generally chosen so that some observer is at its origin.
Every technical term you used here (ordinal, degree of freedom) is used incorrectly, so I have no idea what you're trying to say.
If you change all positive charges to negative charges, flip all movements as in a mirror image, and then reverse time, you might be surprised -- nothing changes. Things keep on doing what they were doing before. The physical laws are invariant until these transformations, collectively called CPT (charge, parity, and time). Thus, the "direction" of time is an arbitrary choice, at least in the way that the physical laws operate.
Something like that. The physical laws would not be the same if you only reversed time, so the physics would actually be completely different. I'd have to think about it a bit to explicitly figure out all the consequences.
- Warren
Gravitational time dilation can be experienced even when "sitting still". Time dilation happens anytime one is near a large mass, not only when one is moving.
The following quote may be of some help. It's excerpted from
http://www.eftaylor.com/pub/chapter2.pdf
You keep talking about “curvature” of spacetime. What is curvature?
The word curvature is an analogy, a visual way of extending ideas about three dimensional space to the four dimensions of spacetime. Travelers detect curvature—in both three and four dimensions—by the gradual increase or decrease of the “distance” between “straight lines” that are initially parallel. In three space dimensions, the actual paths in space converge or diverge. Think of two travelers who start near one another at the equator of Earth and march “straight north.” Neither traveler deviates to the right or to the left, yet as they continue northward they discover that the distance between them decreases, finally reaching zero as they arrive at the north
pole.
How does this relate to gravitational time dilation? Attempt to form a square in space-time, by moving 1 meter up, 1 second into the future, 1 meter south, 1 second into the past.
You don't wind up at your starting point in space-time, because (to oversimplify a bit) clocks at different altitudes don't tick at the same rate due to gravitational time dilation.
This is very similar to the way that one does not wind up at one's starting place by starting at the equator on the Earth, going 1 meter north, 1 meter east, 1 meter south, and 1 meter west. The reason is the same - curvature.
In Riemann geometry, a 1-dimesional curve or a 1-dimensional manifold cannot be curved. Thus, time as a 1-dimensional entity cannot be curved either. What can be curved is space or spacetime.
Note that relativity works with pseudo-Riemannian manifolds.
Most of the rules are the same but for instance in a pseudo-Riemannian manifold the arc length between two points can be longer than the length of any geodesic between them.
This is true, however an object following a geodesic path may appear to be accelerating in some respect due to the curvature of space-time. e.g. the bending of light around the sun can be interpreted as the light accelerating towards the sun. If we throw a ball it ends up on a geodesic, yet it appears to accelerate towards the Earth etc..
If this geodesic doesn't minimise the arc length, then how is it defined? A path that parallel transports its tangent vector into itself? I was under the impression that these definitions are identical... not sure where that came from though...
According to wikipedia the definition of a geodesic on a (psuedo-)Riemannian manifold is "Just as in a standard metric space, a geodesic on a (pseudo-)Riemannian manifold M is defined as a curve γ(t) minimizes the length of the curve."
Wikipedia can be wrong though (the grammar in the above quote is, at the least!)
Chroot's comment refers to the observer-independent spacetime 4-acceleration rather an observer-dependent spatial 3-acceleration [familiar to Galilean/Newtonian kinematics].
because of gravity, clocks in sattalites go faster than clocks on Earth - this is taken into account in GPS systems.
What I said above about Riemannian geometry is true also for the pseudo-Riemannian geometry. Your observation on the arc length above does not imply that a curve may be curved. The pseudo-Riemann curvature of a 1-dimensional curve is zero.
I always like the use of imaginary numbers here to explain the time axis of the graph.
I imagine a graph with an (x,y,z,t) axis. You can use whatever you like to represent the fourth axis, but imaginary numbers are an already oft used axis so it makes sense to use it in discussion about time and space curvature. In this context I can equally equate a curve in space with a curve in time prvided I've set the graph up correctly. I was thinking about this with relation to time after looking into complex numbers, couldn't you call this time I thought? And a friend said yes someones already done it, seems obvious.
there's the much more simple representation with minowski diagrams. But if I want to get at least an intuitive grasp of 4D space-time I think about it something like that.
This is also called a Wick rotation.
But while a Wick rotation works in flat space-time it does not so in curved space-time. Which is one of the current problems in the development of a quantum theory of gravity.
Yeah it's only a way of dealing with it in your head(intuitively) I assume you mean that the bend caused by the magnitude of the vector and the relation to time doesn't match up with Gravity and it's relation because of the warping of space itself. Interesting.
Just think of gravities bend in space and time in the same way as you would the relation to c, and time. Even though one cannot be mapped in a relation to the other, one is a direct consequence of the other. I'm sure there are better analogies.
I never really took physics but I think that the direction of gravity (like other fields) would stay the same regardless of whether you go backwards or forward in time. For example:
If someone threw a ball upward, it would decelerate until it reached the apex and then accelerate downward until it hit the ground. If you filmed the event and played it backwards, you will see the ball jump from the ground at a given velocity and decelerate until it reached the apex and then accelerate downward until it landed in the person's hand. In either case, the acceleration is downward. When I use the terms 'accelerate' and 'decelerate', I am referring to the apparent behavior of the ball as it travels along the geodesic.
However, I believe that what I said above still holds true from the standpoint of Einstein's field equations. The time component of spacetime curvature (if I'm not mistaken) is expressed as a function of -dt^2 (or dt^2 depending on convention). Which means the sign (+ or -) should not affect the equations.
Also, the only law that I can think of that reverses with time reversal is the second law of thermodynamics.
It's been 23 years since I tested out of physics at college so please be patient with me if I am dead wrong.
To get the effect of moving backward in time, on curvature; substitute with "-t" in equations instead of "t" in the Curvatur Tensor. To get the effect of moving backward in time, on gravity; substitute with "-t" in equations instead of "t" in the final free fall equations.
Wonna add, curvature in GR, is a 4-dimensional concept. It simply means, that transformations from certain frame to another are flat (i.e. roughly speaking; not so simple as SR's). So, I agree with your point of view grant9076 in checking the equations like this. But ... you have a very good mathematical engineer! .. Are you a mathematician or an engineer?
Schwartz VANDSLIRE.
Thanks but actually, I'm a pilot by trade. Although I did well when I got my bachelors in engineering, it has been a couple of decades and I really haven't thought about that stuff until I first visited this site a few months ago. So, I cannot consider myself to be either.
However, although testing out of physics never gave me the opportunity to study relativity in detail, it always seemed to make perfect sense. Personally, I think that it is only a matter of time before some genius out there unifies Einstein's theory with quantum mechanics.
In addition to the above thought experiment, another unsophisticated thought experiment that I did as a teenager that cemented my belief in general relativity was the following:
If a particle with negative mass was in a gravitational field, it would sense it as repulsion. However, because it has negative mass, it will react opposite to the force and 'accelerate' downward just like a particle with positive mass. I reasoned at the time that if the reaction to gravity is the same for a negative mass as it is for a positive mass, then it must be true for every mass in between including zero mass. Based on these 2 thought experiments, I concluded that whether something has positive mass, negative mass or no mass, whether it travels forward or backward in time, if it exists, it has to react to gravity in exactly the same way.
I saw no other option but to conclude that gravity is a distortion of spacetime and that Einstein was fundamentally right. These thought experiments made the concept more intuitively obvious to me than any article or book that I have read on the subject prior or since.
Two quick comments
Hi all, this thread has been rather confused, I think, so I've been avoiding comment, but maybe I can help a bit after all:
Don't get that. But for what it is worth, in geometric units in which (G=c=1), path curvature (acceleration of a particle) has units of L^{-1}, while sectional curvature (components of Riemann curvature tensor) have units of L^{-2}, where L stands for some length unit, such as cm. In Einstein's field equation, we form the Einstein tensor by a kind of generalized "trace" of the Riemann tensor, so its components are expressed in the same units, so these must agree with the units of mass-energy density, pressure, and stress (as in the stress tensor from elastodynamics). And they do!
I don't understand what the first sentence means, but the signature used is a convention and of course making a different choice slightly changes our description of the physics/geometry, but doesn't change the physics/geometry we are describing!
You mean, the only law you can think of which is not symmetric under time reversal? (There are some more subtle examples.)
I am not sure why this is supposed to establish that gtr is a reasonable theory, but for others, I think that grant is saying that in Newtonian gravity, if you consider a pair of pointlike objects, one with positive mass m_1 > 0 and one with negative mass m_2 < 0, then the "gravitational force" on the second particle reverses the expected direction (but has the expected magnitude) in Newton's inverse square force law F_2 = \frac{G \, m_1 \, m_2}{r^2} = -\frac{G \, m_1 \, |m_2|}{r^2}, but the response to this force, given by F_2= m_2 \, a_2 = -| m_2 | \, a_2, is to accelerate in the opposite of the expected direction (but with the expected magnitude); these two reversals cancel out, so that the second particle falls toward the first, like a_2 = G \, m_1/r^2. But, by the same reasoning, the first particle falls away from the second (that is, the inverse square force on the first particle reverses the expected direction, but not its response to this force), like a_1 = -G \, |m_2|/r^2. If m_2 = -m_1, the two particles will in fact maintain constant distance, so that we have a zero mass system which spontaneously accelerates indefinitely with constant acceleration. No doubt this disconcerting runaway acceleration is why Newton forbade negative mass.
Since gtr has a Newtonian limit, we should expect to encounter the same problem in gtr unless we forbid negative mass-energy. This is more or less what we do, modulo the awkward fact that in classical terms, one would have to say that the energy density in between the two plates in the Casimir effect is negative.
First, please pardon my lack of using the text tools (someday, I'll try to figure it out). What I was trying to say was that I always thought that spacetime was a 4-dimensional pseudo-riemannian manifold and that the metric tensor expresses the square of the shortest distance between 2 points (ds^2) as some function G (a diagonal matrix) of (-dt^2*c^2, x^2, y^2, z^2). What I was saying was that whether dt is negative or positive, -dt^2 will be the same and the overall equation will not change.
With regard to the particle, what I was trying to say is that:
If a particle with a positive mass started off at a given position and a given velocity with respect to a planet (or other celestial body), it will follow a particular path because of the gravitational field. Now if you replace the particle with one of negative mass and the same initial position and velocity, the path will be exactly the same. Because I considered at the time that the same would be true for every particle mass in between, then that path must be the real unaccelerated (geodesic) path for that given position and velocity. Because this path is curved and not straight, I reason that the curvature could only be caused by the gravity which is distorting the spacetime.
Yes, that is exactly what I was saying. For my own education, if you know of any other examples then please let me know.
Nothing to it: surround your latex pseudocode by "tex" (inside brackets "[" and "]") and "/tex" likewise inside brackets.
grant9076 said:
What I was trying to say was that I always thought that spacetime was a 4-dimensional pseudo-riemannian manifold and that the metric tensor expresses the square of the shortest distance between 2 points (ds^2) as some function G (a diagonal matrix) times -dt^2 \, c^2 +x^2 +y^2 +z^2. What I was saying was that whether dt is negative or positive, -dt^2 will be the same and the equation will not change.
Did you forget some "d"s in that expression?
1. A spacetime model is "a 4-dimensional pseudo-riemannian manifold", correct.
2. A metric which is a scalar mutiple of the Minkowski metric,
ds^2 = G(t,x,y,z)^2 \, \left( -c^2 \, dt^2 + dx^2 + dy^2 + dz^2 \right)
where G(t,x,y,z) is a scalar function on the spacetime, is a "conformally flat spacetime model", which is special property not enjoyed by all spacetimes. For example, the FRW dusts are conformally flat, but the Schwarzschild vacuum solution is not.
3. "whether dt is negative or positive, -dt^2 will be the same and the equation will not change", correct.
So these are positive or negative mass test particles, i.e. they assumed to have masses (in absolute value) sufficiently small that they do not disturb the ambient gravitational field. OK, I agree, then positive and negative mass test particles (regardless of mass, as long as its small enough to not disturb the ambient gravitational field, within the limits of measurement) will have "equivalent world lines" in a suitable sense (e.g. in a static solution like the Schwarzschild solution, we can imagine experimenting with first a positive and then a negative mass test particle, tossing them in the same direction with the same velocity from a static spaceship).
Hmm... I am still not sure I quite follow, but this sounds closely related to Einstein's own reasoning via the equivalence principle c. 1913, as he was searching for his geometrical theory of gravitation.
The syntax is "QUOTE" and "/QUOTE" surrounded by brackets.
OK, another example: parity conservation turned out to be violated by the weak interaction http://en.wikipedia.org/wiki/Parity_conservation
Thanks for the example Chris. Please forgive my ignorance as I have been out of the science mindset for a very long time. I think that there is a thing or two that I need to teach myself about Hilbert spaces. :frown:
Also, yes I did forget to put my d's in.
Hilbert spaces, eh? Those are usually understood to be infinite dimensional vector spaces (typically, spaces of functions), and I don't think we were discussing them here, but maybe I overlooked or misunderstood something.
That's curvature of time, not curvature of space
The curvature of space in Solar system is very small, about 10^-8
It only shows up as perihelion shift in Mercury orbit
See page 229 of "Gravity from the Ground up" by Schutz
Newtonian gravity as the curvature of time
Note that it requires a particular coordinate system to separate out "space" curvature from "time" curvature. The coordinate independent approach only talks about "space-time" curvature, leaving the split of space-time into space+time open to interpretation. I'd be interested in seeing a quote of what Schutz said, exactly - I don't have that textbook. I'm prestty sure he's talking about the Schwarzschild coordinate system, but I'd like to see his exact wording (I've ocassionally wanted to use the words "time curvature" msyelf, but I've never seen anyone do it, so I've been avoiding doing that.)
"Newtonian gravity as the curvature of time"
Here is the website of the book "Gravity from the Ground up" by Schutz
http://www.gravityfromthegroundup.org/
Here is the link to "Newtonian gravity as the curvature of time" in that book
http://www.gravityfromthegroundup.org/pdf/timecurves.pdf
All of Newtonian gravitation is simply the curvature of time.
Here is the exact words Schutz said:
"All of Newtonian gravitation is simply the curvature of time."
  • #31
Why can't we have curvature in space without curvature in time?
Can we have curvature in time without curvature in space?
Is it true if we say "All of Newtonian gravitation is simply the curvature of time." as in the book "Gravity from the Ground up" by Schutz (page 229)
  • #32
I'd suggest sticking exactly to what Schutz said - Newtonian gravity is (or can be described as) "the curvature of time". The difference is the qualifier "Newtonian gravity" rather than "gravity".
The biggest problem with this description is that it is a bit vague, but it is probably acceptable in a popularization, especially if you have someone like Schutz to refer the reader to when they have questions. (There's a good chance they will have questions).
The reason to stick with what Schutz said is that in general, it is more accurate to describe gravity in general (as opposed to Newtonian gravity) as the curvature of space-time (and it takes fewer words). More on this latter.
The point is that in the Schwarzschild coordinate system, at low velocities the spatial part of the curvature of space-time is negligible. This means that space-time is curved while the spatial hyperslices are nearly flat. It's reasonable to describe this as "the curvature of time". The spatial curvature, while ignorable at low velocities, becomes important at high velocities - it's needed to explain the extra (double) deflection of light by massive bodies that GR predicts. All of these statements are coordinate dependent - as any statement that divivdes space-time into space and time must be.
One final point. There is a certain amount of confusion possible even with the more general statement "gravity is due to the curvature of space-time", as seen by the famous elevator experiment. Unfortunately, addressing this point in detail tends to get rather long-winded and technical. The basic problem is one of defintions - the term "curvature" is a bit overloaded with multiple interpretations of what it means in an exact, mathematical sense in popular usage (and even some textbooks).
  • #34
  • #35
mendocino said:
Can you tell me why the time coordinate in the visualization is a closed circle?
see other thread
  • #36
Another way of visualizing the curved space-time, specifically the curved space-time due to a black hole (which will apply to any spherically symmetric massive body) is given in:
http://arxiv.org/PS_cache/gr-qc/pdf/9806/9806123v3.pdf
This is rather nice if one is familiar with special relativity, because it is an embedding diagram of space-time, i.e. gravity is no more and no less than drawing SR space-time diagrams on this curved surface.
Of course to fit this diagram into three dimensions, all but the r and t coordinates have been suppressed.
Unfortunately, I find the diagrams a bit hard to follow personally, though I've been playing around with them a little recently.
  • #37
You might find Don's slides (and link to his course notes) useful:
Don Marolf - "Teaching Black Holes"
http://www.aapt-doorway.org/TGRUTalks/Marolf/Marolf1of5.htm
as part of last year's AAPT Topical Conference on Teaching General Relativity to Undergraduates (http://www.aapt-doorway.org/TGRU/ ),
which has a lot of interesting slides and posters.
  • #38
OK, thanks.
I think I'm getting it - attached is my color coded version of the Schwarzschild geometry based on Marolf's paper.
It is an embedding of the r-t radial plane of a Schwarzschild black hole in a 3 dimensional Mikowski geometry, as described by the paper. The only advantage of this diagram over the ones in the link is that it's color coded. Drawing it was very useful to me in understanding the paper, however.
It has four regions, as it is the fully extended Schwarzschild spacetime, which is a non-traversable wormhole connecting two different asymptotically flat space-times.
The two asymptotically flat spacetimes are colored green and blue, which represent the exterior region of the black hole outside the event horizon. I think of the green region as "our" space-time (for no particularly good reason).
Note that these are the same four regions that are shown on a penrose diagram of a black hole. For readers unfamiliar with Penrose diagrams see for instance:
http://en.wikipedia.org/wiki/Image:PENROSE2.PNG
the diagram for the Schwarzschild geometry is the one labelled "static wormhole".
There are also two interior regions, colored red and pink. The pink region represents the interior of a white hole, the red region is the interior of a black hole. As T increases, any object in the pink region must eventually leave it and enter the blue or green regions.
The singularity itself is located at R=0, which corresponds to Y = -infinity (which also implies T = +infinity or T=-infinity, as per the Penrose diagram). The attachment is only drawn for Y greater than -5, however.
The event horizon, at r=1, is a lightlike (null) surface where differing colors intersect.
The coordinate labeled T is the time coordinate of the Minkowski geometry, X and Y are space coordinates. T increasing determines the direction of increasing time for any (timelike) worldline.
Lines of constant r are planes of constant Y on the diagram. Y>0 corresponds to r>2M, i.e. one of the two exterior regions. Y<0 corresponds to r<2M, i.e. one of the two interior regions. Y=0 is the event horizon.
The equations used to construct it are interesting, and unfortunately are a bit obfuscated in the paper (in my opinion).
We wish to create a map from (r,t) to (X,Y,T), where (r,t) are the Schwarzschild coordinates, and (X,Y,T) are the coordinates of our embedding. The Schwarzschild radius is assumed to be unity (i.e the mass of the black hole is 1/2 in geometric units).
The coordinate Y can be expressed as an integral, and depends only on r
\int_1^r \left( 1+1/R+1/R^2+1/R^3 \right) dR
By construction, when r=1, Y=0, i.e. the event horizon is located at Y=0.
The X and T coordinates are functions of both r and t. For the exterior region, the formula is:
X = \pm 2 \sqrt{1-1/r} \cosh t/2
T = 2 \sqrt{1-1/r} \sinh t/2
The plus and minus sign gives two separate regions, the green and blue, representing the two different asymptotically flat space-times in the exterior region.
In the interior region, the formula is slightly different
T = \pm 2 \sqrt{1-1/r} \cosh t/2
X = 2 \sqrt{1-1/r} \sinh t/2
Again, the plus and minus signs represent different regions.
I won't go through the algebra in detail, but one can confirm that
-dT^2 + dX^2 + dY^2
yields the Schwarzschild metric when re-expresed in terms of dr and dt, i.e. one substitutes
dT = (dT/dt)*dt + (dT/dr)*dr
dX = (dX/dt)*dt + (dX/dr)*dr
dY = (dY/dr)*dr
and gets the Schwarzschild metric
(-1+1/r) dt^2 + 1/(1-1/r) dr^2
One may note that r=1 from the above transformation equations corresponds to a point, T=0 and X=0, but the event horizon is actually a line. This happens because Schwarzschild coordinates are ill-behaved. The event horizon really has the topology of a null surface and because we are modeling only 1+1 dimensions said "null surface" is a pair of lines on the diagram.
  • #39
I disagree with that assessment. As I recall, it is the curvature along the time dimension that exactly reproduces Newton's gravity. Adding in the curvature of space is necessary to account for the precession of Mercury. Gravity Probe B is measuring the curvature of space around the earth; specifically that going all the way around is a little shorter than you would expect based on the mathematical value of π.
If you measure the distances between some points in a vertical plane around the trajectory of a thrown ball, you will get results that Euclid would agree with, even if the most accurate tools are used. But if you put clocks at those points, you will find the higher ones tick faster. The natural motion of the ball serves to minimize its "proper time". Or is it maximize? I don't remember. But the point is to show how it involves time, not curved space.
  • #40
It is obvious that curvature of space only, would only affect objects which are already moving through space. But gravitation also affects objects which are initially at rest, so you have to consider the curvature of space-time.
  • #41
How does this differ from what JDlugsloz is saying, or are agreeing with him?
  • #42
I agree with him. Just wanted to put it in simpler words, why gravity cannot be curvature of space only.
