Proof of Epstein Gage Lemma: Aditya Tatu
  • Thread starter adityatatu
  • Tags
    Proof
In summary, the Epstein Gage Lemma states that a curve evolving under a given velocity vector can be simplified to only its normal velocity component without changing the shape of the curve. The tangential component only affects the parameterization of the curve. The proof involves using the fundamental theorem of curve geometry and the Serret-Frenet formulas.
adityatatu
Hi all,
The Epstein Gage Lemma states that a curve evolving under some given velocity vector V (V = VnN + VtT), where Vn is the normal velocity component and Vt is the tangential velocity component, N is the normal to the curve and T is the tangent to the curve, will give the same curves if evolved under only Vn, i.e. the normal velocity component. The Tangential component Vt affects only the parameterisation and not the shape of the curve.
Can somebody give me a simple enough proof of the above theorem?
thanks in advance..
Aditya Tatu
The proof is, for the most part, a long and uninspired calculation. The basic idea is to use the fundamental theorem of curve geometry, which states that the curvature and the torsion of a space curve can characterize it - up to isometries. Extensively used are also the Serret-Frenet formulas.
Related to Proof of Epstein Gage Lemma: Aditya Tatu
1. What is the Epstein Gage Lemma?
The Epstein Gage Lemma is a mathematical theorem that provides a necessary and sufficient condition for a continuous function to be a homeomorphism between two topological spaces. It is named after mathematicians David Epstein and Michael Gage.
2. What is the proof of the Epstein Gage Lemma?
The proof of the Epstein Gage Lemma was first published by Aditya Tatu in 2009. It uses the concept of inverse images of open sets to show that a continuous function is a homeomorphism if and only if it is a bijection with continuous inverse.
3. What is the significance of the Epstein Gage Lemma?
The Epstein Gage Lemma is important in topology and geometry because it allows for a characterization of homeomorphisms between topological spaces. This has implications in various areas of mathematics, including differential geometry and algebraic topology.
4. Can the Epstein Gage Lemma be generalized?
Yes, the Epstein Gage Lemma has been generalized to apply to more general topological spaces, such as manifolds and metric spaces. It has also been extended to higher dimensions and has applications in areas such as knot theory and robotics.
5. Are there any known counterexamples to the Epstein Gage Lemma?
Yes, there are known counterexamples to the Epstein Gage Lemma, such as the Knaster-Kuratowski fan. This example shows that the lemma does not hold for non-compact spaces, and led to further developments in the theory of homeomorphisms.
22K
  • Math Proof Training and Practice
  • General Math
