Cyclical formula? (noob warning)
  • Thread starter Thread starter romanawgarlic
    Formula
romanawgarlic
Hello all! I am just a guy whos taking a basic statistics course and came across a phenomena that interested me. Probably very basic, but i can't figure it out by myself.
Was messing around on my TI-84 the other day, and ended up just pressing "solve" on a binomial probability function where the probability of the events were the answers of the previously performed function. I don't know exactly how to explain it, so i'll just write it out:
(10 nCr 1)(ans^9)((1-ans)^1)
weirdly, i kept getting numbers around the same values, so i put the equation into excell and ran it a thousand times with a random starting number (0<x<1). strangely, no matter what the first number was, the answers always tended to the same four numbers, in the same order:
0,385203336 0,048336317 0,30947461 0,110469374
What gives? Nothing about this in my textbook, and i don't know where to start searching on the internet. An explanation or link to related theory or anything that will alleviate my puzzlement would be much appreciated.
Thanks y'all!
Are you saying that you evaluated the function
10 x^9(1-x)
and kept getting the same numbers as you varied x?
10 x^9(1-x)
sorry, got the equation mixed up! (feels like it shouldn't matter, but apparently it does when i plug it into excell
1. started by plugging a random number 0<x<1 into 10 x(1-x)^9
2. took the answer i got from that and put it through the same function 10 x(1-x)^9
3. took the answer from step 2 and put it through the equation again, and again, about a thousand times.
result: i ended up getting these numbers as answers time and time again in that order:
sorry about not being clear, I'm not great with mathematical terminology.
if you want to try it for yourself, you can put this in cell A3 in an excell sheet:
=RAND()
and this in cell A4
=10*POWER(A3,1)*POWER(1-A3,9)
then repeat the formula in the cell of A4 as many times as you need (about 100 times should do it)
thanks
With a first power instead of a ninth power, this iteration is known as the logistic map
http://mathworld.wolfram.com/LogisticMap.html
It seems to have a lot of the same properties
try to graph y=f(f(f(f(x)))) with f(x) = 10 x(1-x)^9. The graph will intersect in 4 places with the graph of y = x, which are the points of the cycle you've found
Namaste & G'day Postulate: A strongly-knit team wins on average over a less knit one Fundamentals: - Two teams face off with 4 players each - A polo team consists of players that each have assigned to them a measure of their ability (called a "Handicap" - 10 is highest, -2 lowest) I attempted to measure close-knitness of a team in terms of standard deviation (SD) of handicaps of the players. Failure: It turns out that, more often than, a team with a higher SD wins. In my language, that...
Hi all, I've been a roulette player for more than 10 years (although I took time off here and there) and it's only now that I'm trying to understand the physics of the game. Basically my strategy in roulette is to divide the wheel roughly into two halves (let's call them A and B). My theory is that in roulette there will invariably be variance. In other words, if A comes up 5 times in a row, B will be due to come up soon. However I have been proven wrong many times, and I have seen some...
