- 2
A cylinder has a well fitted 2.0 kg metal piston whoe cross sectional area is 2.0 cm2 The cylinder contains water and steam at constant temperature. The piston is observed to fall slwoly at a rate of 0.30 cm/s because heat flows out of the cylinder through the cylinder walls. As this appehns some steam condenses in the chamber. The density of the steam inside the chamber is 6.0x10-4 g/cm3 and the atmospheric pressure is 1.0 atm Calculate the rate of condensation of steam? At what rate is heat leaving the chamber? What is the rate of change of internal energy of the steam and water inside the chamber?
