D dimension scalar potential for point charge
The discussion focuses on deriving the scalar potential \(\phi\) for a point charge \(q\) in \(d\) spatial dimensions, which is expressed as \(\phi(r) = \frac{\Gamma(\frac{d}{2}-1)}{4\pi^{d/2}}\frac{q}{r^{d-2}}\). Participants analyze the electric field strength \(E(r)\) and its relation to the potential, leading to questions about an extra factor of \(\frac{1}{\sqrt{d}}\) in the calculations. Clarifications are sought regarding the summation over dimensions and the implications for the components of the electric field. The conversation concludes with an acknowledgment of misunderstandings in the derivation process, emphasizing the importance of careful mathematical reasoning in physics.
babyEigenshep
Show that with d spatial dimensions the potential \phi due to a point charge q is given by
\phi (r) = \frac{\Gamma(\frac{d}{2}-1)}{4\pi^{d/2}}\frac{q}{r^{d-2}}
The electric field strength is known to be:
E(r) = \frac{\Gamma(\frac{d}{2})}{2 \pi^{d/2}}\frac{q}{r^{d-1}}
E(r) = \sqrt{(\frac{\Gamma(\frac{d}{2})}{2 \pi^{d/2}}\frac{q}{r^{d-1}})^2}
E(r) = \sqrt{\frac{1}{d}\sum_{i=1}^d(\frac{\Gamma(\frac{d}{2})}{2 \pi^{d/2}}\frac{q}{r^{d-1}})^2}
E(r) = \sqrt{\sum_{i=1}^d(\frac{1}{\sqrt{d}}\frac{\Gamma(\frac{d}{2})}{2 \pi^{d/2}}\frac{q}{r^{d-1}})^2}
Since the magnetic field will be the same in all directions, we know that
\vec {E}(r) = (\frac{1}{\sqrt{d}}\frac{\Gamma(\frac{d}{2})}{2 \pi^{d/2}}\frac{q}{r^{d-1}},\frac{1}{\sqrt{d}}\frac{\Gamma(\frac{d}{2})}{2 \pi^{d/2}}\frac{q}{r^{d-1}},\cdots)
\phi(r) = -\int\frac{1}{\sqrt{d}}\frac{\Gamma(\frac{d}{2})}{2 \pi^{d/2}}\frac{q}{r^{d-1}}dr
\phi(r) = \frac{1}{\sqrt{d}}\frac{\Gamma(\frac{d}{2})}{2 \pi^{d/2}}\frac{1}{(d-2)}\frac{q}{r^{d-2}}
\phi(r) = \frac{1}{\sqrt{d}}\frac{\Gamma(\frac{d}{2})}{2 \pi^{d/2}}\frac{1}{2(\frac{1}{2}d-1)}\frac{q}{r^{d-2}}
\phi(r) = \frac{1}{\sqrt{d}}\frac{\Gamma(\frac{d}{2}-1)}{4 \pi^{d/2}}\frac{q}{r^{d-2}}
Why am I getting an extra \frac{1}{\sqrt{d}}?
E(r) = \sqrt{\frac{1}{d}\sum_{i=1}^d\left(\frac{\Gamma(\frac{d}{2})}{2 \pi^{d/2}}\frac{q}{r^{d-1}}\right)^2}
E(r) = \sqrt{\sum_{i=1}^d\left(\frac{1}{\sqrt{d}}\frac{\Gamma(\frac{d}{2})}{2 \pi^{d/2}}\frac{q}{r^{d-1}}\right)^2}
How did you go the first equation above to the second? And also, what is it that you are summing over? You have the summation sign, but no i index on any of your terms
PS: to get scalable parenthesis, use the command \left( and \right) between your work :wink:
The first equation is
<br /> E(r) = \sqrt{\frac{1}{d}\sum_{i=1}^d\left(\frac{\Gamma(\frac{d}{2})}{2 \pi^{d/2}}\frac{q}{r^{d-1}}\right)^2}<br />
taking \frac{1}{d} through the sum yields
<br /> E(r) = \sqrt{\sum_{i=1}^d\frac{1}{d} \left(\frac{\Gamma(\frac{d}{2})}{2 \pi^{d/2}}\frac{q}{r^{d-1}}\right)^2}<br />
which is the same as
<br /> E(r) = \sqrt{\sum_{i=1}^d \left(\frac{1}{\sqrt{d}}\right)^2 \left(\frac{\Gamma(\frac{d}{2})}{2 \pi^{d/2}}\frac{q}{r^{d-1}}\right)^2}<br />
so we can collect it into 1 squared term
<br /> E(r) = \sqrt{\sum_{i=1}^d\left(\frac{1}{\sqrt{d}} \frac{\Gamma(\frac{d}{2})}{2 \pi^{d/2}}\frac{q}{r^{d-1}}\right)^2}<br />
I am summing over the dimensions. By definition of E(r) as the magnitude of the electric field,
E(r) = \sqrt{\sum_{i=1}^d \left. E_{x^i}\right. ^2
where E_{x^i} are the components of \vec{E}
The sum is used with the fact that changing the order of the dimensions should not change the electric field to calculate the electric field from the magnitude.
It almost looks like you are using this to argue that E_{x^i}=\frac{1}{\sqrt{d}} \frac{\Gamma(\frac{d}{2})}{2 \pi^{d/2}}\frac{q}{r^{d-1}}[/itex]...but you can&#039;t really conclude this from the fact that \sqrt{\sum_{i=1}^d\left(\frac{1}{\sqrt{d}} \frac{\Gamma(\frac{d}{2})}{2 \pi^{d/2}}\frac{q}{r^{d-1}}\right)^2}= \sqrt{\sum_{i=1}^d \left. E_{x^i}\right. ^2}[/itex] any more than you can conclude that 2=1, 2=2 and 2=3 from the fact that 1+2+3=2+2+2
&lt;br /&gt; &lt;br /&gt; That was indeed what I was trying to argue. I feel quite silly now. Thankyou for your help
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
