Damped Oscillation problem.
In summary, a spring AB of natural length 2a and modulus of elasticity 2amn2 lies at rest on a smooth horizontal table, with one end fixed and a particle P of mass m attached to the midpoint. As the other end B moves along the line AB, the distance between A and B is given by a(2+sinnt). Using the equation of motion and setting the acceleration equal to zero, we can find the value of t where P first comes to rest, which is t = nπ.
abramsay
Help need with this problem.
A light spring AB of natural length 2a and of modulus of elasticity 2amn2 lies straight at its length and at rest on a smooth horizontal table. The end A is fixed to the table and a particle P of mass m is attached to the midpoint of the spring. The end B is then caused to move along the line AB so that after a time t the distance between A and B is a(2+sinnt). Denoting the distance of P from A by a+x, show that
d2x/dt2 + 4n2x = 2an2sinnt.
Find the value of t for which P first comes to rest.
Here's my attempt so far, can't find the value of t for which P first comes to rest.
Am I right or wrong. Anyone has a better solution and a solution to the second part.
AB = 2(a+x) since AB at rest is twice a+x
At t, AB = 2a + asinnt
F = -k(x-e) where e is the extension and x the natural length
= k(e-x)
ma = 2amn2/a (2a + asinnt -2a - 2x)
a = 2n2 (asinnt - 2a)
= 2n2sinnt - 4n2x
a + 4n2x = 2n2asinnt
=> d2x/dt2 + 4n2x = 2n2asinnt
To find the value of t for which P first comes to rest, we need to find the value of t where the acceleration is equal to zero. This would mean that there is no net force acting on the particle P and it is at rest.
Using the equation we found earlier, we can set the acceleration equal to zero:
d2x/dt2 + 4n2x = 0
Solving for x, we get:
x = 0
Substituting this back into the equation, we get:
d2x/dt2 + 4n2(0) = 2an2sinnt
=> d2x/dt2 = 2an2sinnt
Integrating both sides with respect to t, we get:
dx/dt = -2an2cosnt + c1
Integrating again, we get:
x = -2an2sinnt + c1t + c2
Since we know that x = 0 when t = 0, we can substitute these values into the equation to find the values of c1 and c2:
0 = -2an2sin(0) + c1(0) + c2
=> c2 = 0
Similarly, when t = 0, dx/dt = 0, so:
0 = -2an2cos(0) + c1
=> c1 = 2an2
Therefore, the final equation is:
x = -2an2sinnt + 2an2t
To find the value of t where P first comes to rest, we need to set x = 0:
0 = -2an2sinnt + 2an2t
=> sinnt = t
Solving for t, we get:
t = nπ
Therefore, P first comes to rest at t = nπ.
1. What is damped oscillation?
Damped oscillation is a type of motion exhibited by an oscillating system, where the amplitude of the oscillation decreases over time due to the presence of a damping force. This force acts to dissipate the energy of the system, resulting in a gradual decrease in the amplitude of the oscillation.
2. What causes damping in an oscillating system?
Damping in an oscillating system can be caused by various factors such as friction, air resistance, and electrical resistance. These forces act to oppose the motion of the system, resulting in a decrease in the amplitude of the oscillation.
3. How is damping coefficient related to the amplitude of oscillation?
The damping coefficient, denoted by "b", is a measure of the strength of the damping force in an oscillating system. A higher damping coefficient results in a faster decrease in the amplitude of the oscillation, while a lower damping coefficient leads to a slower decrease in amplitude.
4. What is the equation for damped oscillation?
The equation for damped oscillation is given by x(t) = A * e^(-bt/2m) * cos(ωt+φ), where A is the initial amplitude, b is the damping coefficient, m is the mass of the oscillating object, ω is the angular frequency, and φ is the phase angle.
5. How is damped oscillation different from simple harmonic motion?
In simple harmonic motion, the amplitude remains constant and there is no external force acting on the system. However, in damped oscillation, the amplitude decreases over time due to the presence of a damping force. Additionally, there may be an external force acting on the system, causing the frequency of the oscillation to change.
  • Classical Physics
