DC Electromagnetic Motor-small question
The discussion revolves around understanding the movement of a component labeled A in a DC electromagnetic motor, specifically why it moves forward instead of backward when two north poles repel. The initial confusion stems from interpreting the diagram and the arrangement of the brushes and commutator. Clarification is provided by considering the implications of the armature's orientation and the labels "Front" and "Back" in the diagram. The movement direction can be determined by analyzing the setup and the forces at play. Ultimately, the participant gains insight into the mechanics of the motor's operation.
moshrom
[PLAIN]http://img695.imageshack.us/img695/206/95144436.jpg
Hand rules
This is a practice question with the answer already given in the diagram. I know how to draw the coils and use the left hand rule to find the poles. I do not understand b), though. I know the two north poles repel, but why does A move forward instead of backwards?
Thanks.
I think it has to do with manner in which the brushes are drawn with respect to the rest of the commutator. See the part of the diagram near where "Front" and "Back" are written.
Imagine what would happen if it moved in each direction (A moved forward, and A moved backwards). Consider the impact of the way the brushes/commutator are drawn.
Oh okay, I think I get it. Normally the direction can be determined if the armature is drawn slightly turned. I assumed the 'front' and 'back' labels were written as part of the answer, I guess they were originally given. Thanks.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
