De Broglie Waves: Momentum, Wavelength & Light Speed
  • Thread starter Thread starter AakashPandita
    De broglie Waves
AakashPandita
According to Broigle,
λ=h/p
where
p=momentum,
h=planck constant, and
λ=wavelength
But that means,
if λ increases, then p will increase
p=mv
and so v will increase along with the wavelength
But what if the v is that of light,i.e, c?
λ=h/p
where
p=momentum,
λ=wavelength
But that means,
p=mv
For starters, why increase? λ and p are inversely proportional. Or it's New Year's morning and I'm not thinking straight.
danR is correct. If \lambda decreases, then p increases. But, this is not a cause and effect thing.
That aside, if v = c, then p \ne mv.
Best wishes
when p increases ,i.e, mv (that of light)
then either m or v (of light) should increase...
then what will be that would increase?
λ=h/p
where
p=momentum,
λ=wavelength
But that means,
p=mv
There clearly is an inverse relationship between the two parameters of your interest. Also Lambda can't increase as your post suggests , in Q.M as you may know light comes in packets ' photons' which have specific energy levels.
For a given wave , it's wavelength and speed can be related by : c = fλ
This is true only for non-relativistic particles! You want v=c, which is relativistic. Most likely you are talking about light (electromagnetic radiation). In the relativistic case p=E/c, where c is the constant speed of light. For light the photons have zero mass and when you increase E the momentum p increases but the speed of light c remains constant.
The point is that p=mv does not apply when v=c.
Best wishes
Oh i see. thanks.
