How Do You Solve z^3 = sqrt(3) - i Using De Moivre's Theorem?
  • Thread starter Thread starter Matty R
    Theorem
To solve the equation z^3 = √3 - i using De Moivre's Theorem, the modulus r is calculated as 2, and the argument θ is found to be -π/6. The roots are derived by applying the theorem, resulting in z = (√2)cis(-π/18 + 2kπ/3), where k is an integer representing the three cube roots. The discussion emphasizes the importance of expressing the roots in either cis or exponential form, with a preference for e^(iθ) in mathematical contexts. The final goal is to identify all three complex solutions, which are evenly spaced around the circle at 120-degree intervals.
Matty R
Hello :smile:
I'm really stuck on this question, and was hoping someone could help me.
Find all complex numbers, z, that satisfy z^3 = \sqrt{3} - i
z^n = r^n cis (n\theta)
r = \sqrt{a^2 + b^2}
\theta = tan^{-1}(\frac{b}{a})
Rotate anticlockwise by \frac{2\pi}{n} radians
z^3 = \sqrt{3} - i
r = \sqrt{(\sqrt3)^2 + (-1)^2} = 2
\theta = tan^{-1}(\frac{-1}{\sqrt3}) = -\frac{\pi}{6}
z^3 = 2cis(-\frac{\pi}{6})
This is where I go wonky.:shy:
n = \frac{1}{3}
(z^3)^{\frac{1}{3}} = 2^{\frac{1}{3}}cis(\frac{1}{3}.-\frac{\pi}{6})
z = \sqrt[3]{2}cis(-\frac{\pi}{18})
Now, from what I've seen in the lectures, I'm supposed to add \frac{2\pi}{\frac{1}{3}} radians, then \frac{4\pi}{\frac{1}{3}} radians, then \frac{6\pi}{\frac{1}{3}} to get 2\pi, and thus complete one revolution (360 degrees).
I've seen an Argand Diagram for this question divided into sections of 120 degrees, but I'm so confused.
Could anyone help me please? I'd very much appreciate it.
Thanks. :smile:
Hi Matty
Ok, you have z3 = 2 cis (-π / 6), then using De Moivre's Theorem :
z3 = 2 cis (-π / 6)
r3ei3θ = 2e-i(π / 6)
Comparing coefficient :
1)
r3=2
2)
ei3θ = e-i(π / 6)
3θ = -(π / 6) ---> this is where you add 2π, 4π, ...or add 2kπ, where k is integer
so it will be :
3θ + 2kπ = -(π / 6) ---> You can also add 2kπ on RHS
Then find θ using several value of k
It's easier to work with an angle with positive measure, namely 11pi/6. You want values of z such that their 3rd powers are 2cis(11pi/6). If you have a complex number in polar coordinates, it's easy to calculate powers of that number by raising the modulus of the number to that power, and multiplying the angle (arg) by that power.
For example 1 + i = sqrt(2)cis pi/4, so (1 + i)2 = (sqrt(2))2cis pi2 = 2i.
In your problem, can you work backwards and find a complex number whose cube is sqrt(3) - i? All three of the numbers are spread equally around the circle 120 deg. apart
Thank you so much for the replies. :smile:
I think I may have worked it out now, but I'm still a bit confused.
songoku said:
Hi Matty
z3 = 2 cis (-π / 6)
1)
r3=2
2)
ei3θ = e-i(π / 6)
so it will be :
Ok then.
z^n = r^ne^{in\theta}
z^3 = r^3e^{i3\theta} = 2e^{i(-\frac{\pi}{6})}
3\theta = -\frac{\pi}{6} = (-\frac{\pi}{6}) + 2k\pi
\theta = \frac{(-\frac{\pi}{6}) + 2k\pi}{3} = -\frac{\pi}{18} + \frac{2k\pi}{3}
z = (\sqrt[3]{2})cis(-\frac{\pi}{18} + \frac{2k\pi}{3})
OR = (\sqrt[3]{2})cis(-\frac{\pi}{18})
OR = (\sqrt[3]{2})cis(-\frac{\pi}{18} + \frac{2\pi}{3})
OR = (\sqrt[3]{2})cis(-\frac{\pi}{18} + \frac{4\pi}{3})
Should they be written like this instead, seeing as I've used the exponential form earlier:
z = (\sqrt[3]{2})e^{i(-\frac{\pi}{18} + \frac{2k\pi}{3})}
OR = (\sqrt[3]{2})e^{i(-\frac{\pi}{18})}
OR = (\sqrt[3]{2})e^{i(-\frac{\pi}{18} + \frac{2\pi}{3})}
OR = (\sqrt[3]{2})e^{i(-\frac{\pi}{18} + \frac{4\pi}{3})}
Would that be (\sqrt3 - i)^{\frac{1}{3}}?
Well, yes, but that doesn't tell your what the three cube roots are.
I W-A'd it... and only got 1 answer.
Ok then.
"cis(\theta)", which is short for cos(\theta)+ i sin(\theta)= e^{i\theta} is primarily an engineering notation. Which is better to use depends on what kind of course this is. If it is a mathematics course being taught be a mathematician, I would say definitely use e^{i\theta}.
