Deceleration of a projectile (With air resistance)
The discussion revolves around modeling the flight of a bullet considering air resistance using a drag force equation. The user seeks guidance on how to apply the drag force to determine the bullet's flight path over time, specifically its distance traveled during a flight time of 0.553 seconds. Key points include the relationship between drag force and acceleration, and the suggestion to modify the drag equation into a differential equation for better accuracy. The user acknowledges their limited mathematical background and expresses a desire for approximations to simplify the calculations. Resources like Wikipedia's article on ballistics are recommended for further understanding.
SirAmikVarze
Hi there, sorry for asking a question as my first post instead of contributing to the community however I have a problem which I just cannot seem to find an answer to.
I am trying to model the flight of a bullet when taking into account air resistance and I am using this equation to get the drag force of the bullet at certain velocities:
D = \frac{ρ*V^2*Cd*A}{2m}
Where:
D is the drag force in Newtons
ρ is the density of air (1.225 kg/m3)
V is the velocity of the bullet
Cd is the drag coefficient of the bullet (For this let's just assume it's 0.12)
A is the cross sectional area of the bullet (Also for this let's say it's 0.05m2)
m is the mass of the bullet (And let's assume this is 0.150kg)
How would I use the value of the drag force of the bullet to model the flight path over time?
In my head I'm sure it's something simple which I have studied before but I just can't think what it might be
Thank you in advance :)
If you can neglect gravity:
How are the drag force and acceleration of the bullet related?
You can modify your equation to a differential equation, and solve that.
Since this is rough calculation I will be using the height from the ground at the point the bullet leaves the barrel as 1.5m, this gives me a flight time of 0.553 seconds when I don't take into account factors which would provide lift.
The drag force and acceleration are related as such that the drag force on the bullet (with an initial velocity of 600ms-1 at the end of the barrel) causes the bullet to decelerate over the 0.553 seconds in flight, what I need to find out is the distance traveled by the bullet in the 0.553 seconds it is in flight.
Please excuse my lack of knowledge with mathematics here, I am only 16 so haven't studied differential equations yet. In fact we have done SUVAT and my curiosity lead me to studying this myself. It is more complex than I'd imagined.
Okay, then approximations will be better.
What is the initial deceleration of the bullet?
Assuming this stays constant over the whole flight duration (=first approximation), what is the final velocity of the bullet?
What is the deceleration at that final velocity?
Can you improve the first approximation, based on that?
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
