Quantum Decoherence & Measurement Time
In summary, quantum gates, if properly implemented, do not cause quantum computers to decohere. However, the issue lies in the time it takes for gate operations to be performed, which can be longer than the coherence time of the qubits. This leads to the need for quantum error correction algorithms, which require a large number of qubits and the ability to entangle them for extended periods of time. While this is currently beyond our capabilities, it suggests that there is a threshold where practical quantum computers can be built. In the meantime, efforts are focused on extending the coherence time of qubits and utilizing short pulses and other techniques for manipulation and measurement.
michael879
698
I was reading about quantum computing and I came across this:
http://en.wikipedia.org/wiki/Quantum_computing#Quantum_decoherence
It seems to suggest that fast logic gates don't decoher qubits while slow ones due. If this is true, it would seem like the term "measurement" in QM is a function of time. I might have misunderstood this but it seems like slow logic gates act as "measurements" while fast ones dont. I don't see any difference between sending a qubit through a logic gate and bouncing a photon off of it (or some other form of measurement). Does this mean that if you could measure a qubit fast enough it wouldn't decoher??
There is something called "adiabatic quantumt computing" (which is what D-Wave are using for Orion) but I suspect that is not what you are referring to.
First of all, quantum gates do NOT cause a QC to decohere if they are properly implemented; quantum gates are used in systems which are designed to USE quantum coherence in some way. The only time a QC MUST decohere is when you read out the final result.
However, the problem is that a gate operation takes some time, let's say 10 ns. (note that a "gate" does not neccsarily refer to anything more than a certain sequence of pulses in quantum computing; it is usually not a circuit) .
Hence. if you have a coherence time of e.g. 1 microsecond that means that you can in theory perform 100 gate operations before the system collapses.
Now, there is something called quantum error correction algorihms which (in theory) can be used to build QCs that can operate for times much longer than the coherence times of the individual qubits. This means that the requirements on the qubits are somewhat relaxed. The bad news is that in order to implement these algorithms you need quite a few qubits, at least a few thousand, and you also need to be able to entangle all of them for the time it takes to perform the error correction.
This is way beyond what is possible at the moment but it DOES mean that there is a threshold beyond which we should be able to build practical QCs of just about any size.
This means that quantum correction is not really useful at the moment(I am not counting re-focusing pulses etc as QC) so instead we simply try to extend the coherence time of our qubits as much as possible and then we manipulate them using very short pulses before reading them out (there are also various "tricks" one can use such as non-demolition measurements etc).
Thank you for sharing your thoughts on quantum decoherence and measurement time. I can provide some clarification on this topic.
First of all, it is important to understand that quantum decoherence is a process by which a quantum system becomes entangled with its surrounding environment, leading to the loss of its quantum properties and becoming a classical system. This is a major challenge in quantum computing, as it can cause errors in calculations.
In the context of quantum computing, logic gates are used to manipulate qubits (quantum bits) to perform calculations. These gates can be either fast or slow, depending on the time it takes to complete the operation. It is true that fast logic gates are less prone to decoherence compared to slow ones. This is because fast gates complete the operation before the qubit can interact with its environment, thus reducing the chances of decoherence.
Now, regarding your question about the role of measurement in quantum mechanics, it is important to note that measurement does not necessarily cause decoherence. In fact, measurement is an essential part of quantum mechanics and is used to obtain information about a quantum system. However, the act of measuring can cause decoherence if the measurement process is not carefully designed. This is why in quantum computing, measurements are done in a controlled manner to minimize the effects of decoherence.
In summary, the speed of logic gates does play a role in reducing the chances of decoherence in quantum computing. However, it is not the only factor and the design of the measurement process is also crucial. I hope this helps clarify any confusion and further your understanding of quantum decoherence and measurement time.
Related to Quantum Decoherence & Measurement Time
What is quantum decoherence?
Quantum decoherence is the process by which a quantum system, such as an atom or a subatomic particle, becomes entangled with its surrounding environment, causing it to lose its quantum properties and behave classically. This occurs due to interactions with other particles or the detection of the system by a measuring device.
How does quantum decoherence affect measurement time?
Quantum decoherence can cause the collapse of a quantum state into a classical state, which can happen at different rates depending on the system. This collapse can occur quickly, resulting in a short measurement time, or it can take longer, leading to a longer measurement time. In general, the more interactions a quantum system has with its environment, the faster decoherence occurs and the shorter the measurement time.
What is the role of measurement time in quantum mechanics?
In quantum mechanics, measurement time is the time it takes for a quantum system to transition from a superposition state (where it exists in multiple states simultaneously) to a single, definite state. The measurement time is influenced by factors such as quantum decoherence and the type of measurement being performed.
Can measurement time be controlled or manipulated?
While measurement time is primarily determined by the dynamics of the quantum system, it can be influenced by external factors such as temperature, pressure, and the type of measurement being performed. Scientists are also exploring methods to control and manipulate measurement time by utilizing advanced measurement techniques and quantum technologies.
What are the implications of measurement time in quantum computing?
Measurement time is a critical factor in quantum computing as it determines how long a quantum system can maintain its quantum properties before decoherence occurs. Longer measurement times allow for more complex and accurate computations, making it a crucial consideration for the development of efficient quantum computers.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
