Define a new topology on the reals
  • Thread starter Thread starter andlook
    Topology
andlook
Verify that taking \mathbb{R}, the empty set and finite sets to be closed gives a topology.
Clearly the empty set is finite as it has 0 elemnts, and so is closed.
If X_i, for i= {1,...,n}, are finite sets then clearly the union of finitely many finite sets is again finite and so is closed.
Let |X_i| = m_i, where m_i is the number of elements in X_i, then |\bigcap X_i | is at most max{m_i} or at least 0 if the intersection is empty. Either way it is again finite and so is defined as closed.
I think I have shown the empty set, arb unions, arb intersections are closed in this topology, but I can't see how \mathbb{R} could be included...
Thanks
Reread the description of the closed sets. It says:
1) That all finite sets are closed.
2) That the empty set is closed (this is really redundant, but there's no harm in including it).
3) That \mathbb{R} is closed.
Of course, as defined in the statement of the question!
Thanks
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
