I Defining Spacetime Coordinates
PeroK
Insights Author
2024 Award
I was looking at the Static Weak Field Metric, which Hartle gives as:
##ds^2 = (1- \frac{2\Phi(x^i)}{c^2})(dx^2 + dy^2 + dz^2)##
For a fixed time.
Where, for example, ##\Phi(r) = \frac{-GM}{r}##
I was trying to figure out how the coordinates (x, y, z) could be defined. Clearly, they can't be defined by measurements of length. Hartle says nothing about this.
I suspect that the ##r## in the second equation is probably the measurable distance, and not ##(x^2 + y^2 + x^2)^{1/2}##
The best explanation I could come up with myself is that if you measured ##r## and ##\Phi(r)## at every point and knew ##G## and ##M## then you could define ##x, y, z## precisely so that the equation for ##ds^2## holds!
Does that sound right and/or can anyone shed any light on this?
In the usual convention, they are, heuristically, the Cartesian coordinates that would be assigned if space were flat.
In the usual convention, it isn't, it's ##\left( x^2 + y^2 + z^2 \right)^{1/2}##. This basically corresponds to the Schwarzschild coordinate definition of ##r##.
I don't know for sure that Hartle is using this convention, but I suspect he is.
In terms of coordinate time, I can imagine a remote clock in flat spacetime keeping coordinate time. Is there an equivalent for understanding how you can assign Cartesian coordinates to a curved region of spacetime as if it were flat? Projecting onto a flat coordinate map?
That would explain a lot.
More or less, yes. It helps if there is spatial symmetry present; for example, in the spherically symmetric case, you can calculate the "areal radius" ##r## (i.e., the quantity ##\sqrt{A / 4 \pi}##, where ##A## is the area of a 2-sphere containing a given point) and assign x, y, z coordinates using the standard conversion from spherical to Cartesian coordinates in flat space. That's what I think Hartle was doing.
Likes PeroK
My understanding (at least for Schwarzschild coordinates) is that the rubber sheet analogy is actually helpful here. You can imagine a flat sheet with a circular polar coordinate grid drawn on it. Below it you imagine another sheet stretched as in the rubber sheet analogy (I believe the relevant surface for Schwarzschild coordinates is called Flamm's hyperboloid). Then you project the circular coordinate grid vertically downwards. Tangential distances are preserved, but radial distances are not.
Thanks, Peter. That's exactly what Hartle is doing.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
