Defining the Square Root: Why Do We Only Consider the Positive Number?
  • Thread starter kenewbie
  • Tags
    Root
In summary: I can't find such a contradiction? (2^2 is obviously equal to (-2)^2)I sort of get the feeling that I'm staring something obvious in the face here and calling it a UFO :/Sorry.
kenewbie
239
I have been doing elementary algebra for a couple of weeks now, and gotten quite used to the idea that the square root of n gives +- n1.
Then moving on to arithmetic and n-roots / powers, I was given the current definition of the square root:
The square root of a number N is the positive number M which gives M^2 = N.
So, what is going on here? Why are we suddenly only interested in the positive number?
Is this related to the fact that the square root of N can be written as N^(1/2) ?
k
The reason you're only interested in positive numbers, is that you can only ever root a positive number.
Consider that two positives are a positive, and two negatives are a positive.
With the exclusion of imaginary numbers (i), there are no numbers which can square to equal a negative number.
so when you take your number N and you put a square root symbol in front of it you get M.
If M was a negative number the negative sign would be inside the root symbol, which is impossible.
It is, however, possible to put the negative on the outside of the root symbol, as that is after the calculation.
First time response, so let me know if I'm just writing crap :/
That would depend on the degree of the root, you can take the cube root of a negative number.
The cube root of -8 would be -2, since (-2)^3 = -8.
Actually, you can take the N-th root of a negative number as long as N is odd.
And I am sorry, but I don't see how this relates to the "problem"?
Hi kenewbie! :smile:
Sort of.
The point is that we mustn't define anything that's ambiguous.
If we want to write N^(1/2), or √N, and there are two possible values for it, then we must specify in advance which value it is to be. :smile:
Same for things like arcsin and log-of-a-complex-number!
Hi Lore! :smile:
No … it's a thoroughly good answer … though not exactly to the right question ! :rolleyes:
More practice needed methinks..\pm
Thanks for that Tim, but could you do me a favour kenewbie and clarify what the problem actually was?
I get that I missed the point, but I still can't find the point :redface:
And that the powers cancel to 1, yes. Am I getting warmer?
Or are you asking about the [tex]\pm[/tex] as Tim was referring to?
Or maybe both?
Sorry if this has already been answered, but I'm confuddled..
Sort of.
But.. but.. why? Algebra is perfectly happy with getting two results and then just branching in two directions for the rest of the calculation. Why not when we work with actual numbers?
I gather that something, somewhere, relies on the fact that the result of a root is positive? But then if that is true, why allow something like the cubic root of a negative number, the result is negative!
I want to see a contradiction or something (preferably something that can be read with my level of math). Some reason which explains why using both results would end up being a bad thing.
Let me try to give an example of what I mean by a contradiction:
The square root of 4 is 2 and -2. But, 2^2 is not equal to (-2)^2 and to avoid this problem, we define the root of N to be the positive number M which gives M^2 = N.
The thing is, I can't find such a contradiction? (2^2 is obviously equal to (-2)^2)
Sorry.
k
ok … saying " let f(a) be a solution of x^2 - 2x + a = 0" is fine. :smile:
But saying " let f(a) be the solution of x^2 - 2x + a = 0" is not fine! :frown:
"The square root of 4 is 2 and -2" is an abuse of the word "is".
I want to see … Some reason which explains why using both results would end up being a bad thing.
Mathematical proofs are linear … they don't operate "in parallel". We can't use "both" results at the same time. :cry:
No … but a lot of things rely on it being uniquely defined!
Aha. Ok, I think I finally see your point. The difference between "a solution" and "the solution" is quite substantial.
The question then becomes, can you show me a simple problem that would occur if the result of the square root was NOT uniquely defined? :)
I gather that the whole thing would come crashing down, but there might be some small easily shown paradox that would occur? I'm not talking about "well, the root of a square with an area of 4 certainly can't be -2", but a fault which would arise in the structure of the math that ties into roots.. if that made sense.
Thanks a lot for your patience tiny-tim, I really appreciate it.
Actually, some things do rely on the square root being specifically positive.
We want to be able to define the function f(x)= ax for all x. Also we want to be able to do all the "algebra" things we do with other functions. In particular we want to be able to use such properties as (ax)y= axy. If we defined x1/2= [itex]\sqrt{x}[/itex] as the negative number y such that y2= x, we would run into trouble with (x1/2)1/2.
Well … for example, any integration over a "triangular" region defined by x > y, where y = √(something). :smile:
Aha! Now that is the sort of thing I was looking for, thanks :)
k
Ok, I'll file that under things to check at a later point :) I'm not quite at integration yet.
k
1. What is the definition of the root of a number?
The root of a number is a value that, when multiplied by itself a certain number of times, gives the original number. The most common roots are the square root (multiplied by itself twice) and the cube root (multiplied by itself three times).
2. How is the root of a number calculated?
The root of a number can be calculated using various methods such as the long division method, the prime factorization method, or the Newton's method. The method used depends on the complexity of the number and the desired level of accuracy.
3. What is the difference between a square root and a cube root?
A square root is the root of a number that, when multiplied by itself, gives the original number. A cube root is the root of a number that, when multiplied by itself three times, gives the original number. In general, the nth root of a number is the root that, when multiplied by itself n times, gives the original number.
4. Can the root of a negative number be defined?
Yes, the root of a negative number can be defined, but only for certain roots. For example, the square root of a negative number is defined as an imaginary number, while the cube root of a negative number is defined as a real number.
5. Why is it important to understand the concept of the root of a number?
The concept of the root of a number is important in various fields such as mathematics, physics, and engineering. It is used in calculations and equations to find solutions, and it helps in understanding the relationship between numbers. Additionally, knowing how to calculate roots can be useful in everyday life, such as calculating mortgage payments or estimating the size of a room.
  • Precalculus Mathematics Homework Help
  • Linear and Abstract Algebra
  • Science Fiction and Fantasy Media
