Definite double integral of e^x^2
5 replies · 5K views
dobedobedo
Hi guise. I just encountered a problem which I sincerely don't know how to attack. I don't know what kind of variable substitution would help me to solve this problem... It's that goddamn e^x^2 which is a part of the integrand... I don't know if I should use polar coordinates either... Please help!
[itex]\int_{1}^{2} (\int_{x}^{x^3}x^2 e^{y^2}dy)dx + \int_{2}^{8} (\int_{x}^{8}x^2 e^{y^2}dy)dx[/itex]
P.s. The answer is supposedly equal to (1/6)(62e^64+e).
dobedobedo said:
Hi guise.
I'm not a costume. :-p
I just encountered a problem which I sincerely don't know how to attack. I don't know what kind of variable substitution would help me to solve this problem... It's that [edited for language] e^x^2 which is a part of the integrand
The obvious things to try, then, would be [itex]u = x^2[/itex] and [itex]u = e^{x^2}[/itex].
Another common trick is to swap the order of integration and hope you get something simpler out.
I tried the substitution u= x^2, v= e^(y^2). The Jacobian had the value 1/(4xy*e^(y^2)). So far so good. But then I get...
[itex]\frac{1}{4} \int_{1}^{4} (\int_{e^u}^{e^{u^3}}(\frac{u^{1/2}}{ln(v)^{1/2}})dv)du +\frac{1}{4} \int_{2}^{8^{2}} (\int_{e^u}^{e^{8^2}}(\frac{u^{1/2}}{ln(v)^{1/2}})dv)du[/itex]
Which is a complete**#@* mess.And integrating with respect to x first would not be sufficient to eliminate all expressions containing x from the integrand of neither the first nor second term.
I was just thinking one thing... Let the set of points (region, whatever... you get the idea) which the first term is to be integrated over be denoted A.
Then A = {(x,y): x ≤ y ≤ x^3, 1 ≤ x ≤ 2}. Let the set of points that the second term is integrated over be denoted B.
Then B = {(x,y): x ≤ y≤ 8, 2 ≤ x ≤ 8}.
It becomes clear that these two regions of points in the xy-plane intersect at the line x=2. Is it possible to... somehow... reexpress the boundaries for y and x in a way which JUST MAYBE makes the integration easier? Is it possible to "merge" the two terms into one term, with modified integration intervals?
I don't know people... but this problem is supposed to have a solution without the necessity of fancy mathematical methods... but those are welcome as well! As long as they are thoroughly explained. <3
I tried the substitution u=x^2 and v= y^2, but that didn't help either... I always get to the goddamn errorfunction which I basically don't know anything about. This **** is supposed to be solved with elementary functions. Not the error function...
Try changing the order of integration. The first integral has y going from x to x3 and x from 1 to 2. So swapping the order of integration would give
[tex]\int_{y= 1}^8\int_{x= y^{1/3}}^y x^2e^{y^2}dxdy= \frac{1}{3}\int_1^8 (y^3- y)e^{y^2}dy[/tex]
Since we now have odd powers of y, we can write that as
[tex]\frac{1}{3}\int_1^8 (y^2- 1)e^{y^2}(ydy)[/tex]
and use the substitution [itex]u= y^2[/itex] so that du= 2ydy and the integral becomes
[tex]\frac{1}{6}\int_1^{64} (u- 1)e^u du[/tex]
