Definite integral of exp and error function
The discussion revolves around the evaluation of definite integrals involving the exponential function and the error function (erf). Participants explore the challenges of finding analytical solutions for specific integrals and compare them to related integrals that have known solutions.
  • One participant presents an integral involving the error function and the complementary error function, seeking assistance in evaluating it.
  • Another participant suggests that the integral cannot be solved analytically and recommends exploring the representation of the error function to potentially simplify the problem.
  • A participant questions why a related integral over the entire real line can be evaluated easily using differentiation under the integral sign, while the original integral does not seem to have an analytical solution.
  • Another participant notes that the difficulty may stem from the nature of integrating over a limited range compared to the entire real line, which yields simpler results.
  • A later post introduces a method for solving the definite integral, although the specifics of this method are not detailed.
  • Another participant expresses gratitude for a previous post that clarified a constant of integration in a more general formula related to integrals involving the error function.
Participants generally agree that the original integral poses significant challenges for analytical evaluation, while acknowledging that related integrals can be solved more easily. There is no consensus on a definitive solution to the original problem.
The discussion highlights the complexity of evaluating integrals involving the error function and the conditions under which certain integrals can be solved analytically. Specific assumptions and dependencies on the parameters of the integrals are not fully resolved.
petru
Hi,
I've been trying to evaluate the following integral
[tex]\int_{z}^{\infty}\exp\left(-y^{2}\right)\mathrm{erf}\left(b\left(y-c\right)\right)\,\mathrm{d}y[/tex]
or equivalently
[tex]\int_{z}^{\infty}\exp\left(-y^{2}\right)\mathrm{erfc}\left(b\left(y-c\right)\right)\,\mathrm{d}y[/tex]
[tex]\mathrm{erf}\left(x\right)=\frac{2}{\sqrt{\pi}} \int_{0}^{x}\exp\left(-u^{2}\right)\,\mathrm{d}u, \quad\quad \mathrm{erfc}\left(x\right)=1-\mathrm{erf}\left(x\right)=\frac{2}{\sqrt{\pi}} \int_{x}^{+\infty}\exp\left(-u^{2}\right)\,\mathrm{d}u[/tex]
I guess I tried to employ all techniques I'm familiar with but with no result.
Can anyone help me with this one, please?
Thank you!
To the best of my knowledge, it can't be done analytically. I suggest you start with the erf representation and see if the two exponentials might be combined into one, so that you might have an erf for the integral.
Thanks mathman for your reply. I guess I'm not able to deal with this integral. I have a question though. I'm not a mathematician nor a math student so I was wondering if anyone could explain to me why the integral
[tex]\int_{-\infty}^{\infty}\exp\left(-y^{2}\right) \mathrm{erf}\left(b\left(y-c\right)\right)\,\mathrm{d}y=-\sqrt{\pi}\,\mathrm{erf}\left(\frac{bc}{\sqrt{1+b^{2}}}\right)[/tex]
can be evaluated quite easily (using differentiation under integral sign method) and the integral from my original post seems to have no analytical solution?
Thanks!
I haven't looked at it in detail, but it looks like the problem is analogous to integrating the Gaussian. When you integrate over the entire real line you get a neat analytic solution, but integrating over part of the line ends up with erf.
Ok, I guess I know what you mean. Thanks again!
Hi !
in attachment, a method for solving the definite integral.
Hi JJacquelin! Your post helped me with showing that the constant of integration [tex]C=0[/tex] in a more general formula:
[tex] \int_{-\infty}^{\infty}\exp\left(-b^{2}(x-c)^{2}\right)\mathrm{erf}\left(a\left(x-d\right)\right)\,\mathrm{d}x=\frac{\sqrt{\pi}}{b} \mathrm{erf}\left(\frac{ab\left(c-d\right)}{\sqrt{a{}^{2}+b{}^{2}}}\right),\quad b>0[/tex]
Thank you!
