Office_Shredder said:
In any reasonable category the morphisms are the reasonable functions. Note each morphism is only mapping between two chosen objects, it's not a map on the category itself. For example if you have the category of groups you would define hom(G,H) would be the group homomorphisms between G and H
this, strictly speaking, isn't true. some categories have morphisms that don't even resemble functions. for example:
let C have as objects natural numbers (not including 0).
let Hom
C(m,n) be the set of all mxn matrices with integer entries.
the axioms are satisfied, but a matrix isn't a function from m to n.
another example:
let C have objects {1,2,3,4,6,12,24}
define f:a→b as the only arrow that exists, only if a|b.
then the axioms are satisfied, but arrows (morphisms) don't even remotely look like functions.
a "more natural" example:
let Obj(C) = G, a group.
define g:G→G for each g in G, and set composition of arrows to be group multiplication.
there is a reason morphisms are left "vague". because many kinds of things might be morphisms: edges on a directed graph, functions, homotopy class mappings (the last example should make you think, especially if one is looking at manifolds).
basically, anything which can be "composed" in an associative way, can be a morphism. ANYTHING. that said, the "canonical examples" are sets-with-structure (as objects), and the structure-preserving maps between them (as objects). furthermore, one usually isn't even interested in the sets-with-structure themselves, but only in characterizing morphisms. for example, in topology one might be interested in knowing which identity functions from a set with one topology to the same set with a different topology, are continuous (which tells us "how fine" in comparison the topologies are), or in knowing what well-understood space another (perhaps less-understood) space is homeomorphic to. as another example, with a path, it's not the interval of definiton, or the ambient space the image of the path is in, that is of interest, it's the path mapping itself.
for manifolds, these (morphisms) are typically (n-times) differentiable maps, which can be thought of as "preserving (partial) information about the manifolds they transform". for example, when talking about regions in the plane under two different coordinate systems (like cartesian and polar coordinates), what we're really interested in is the Jacobian matrix of the transform from one system to the other. if the Jacobian is singular (0 determinant), we "lose information" somewhere along the way.
gotjrgkr said:
Then, is it right if I say that a morphism is a kind of a function from one class into another class??
no, the concept you are looking for here is called a
functor. functors are, curiously enough, the morphisms in the category
Cat, whose objects are all (small, or in some texts, locally small) categories.
