Understanding Current: Definition and Comparison to Math-Defined Current
Current is defined as the rate at which charge crosses a surface boundary over time, expressed mathematically as I=dQ/dt. The confusion arises when interpreting this as a change in charge, which can seem to equal zero since charge entering and leaving a conductor balances out. However, current should be viewed as a flow rate, similar to water flowing through a pipe, rather than a measure of change in total charge. The distinction between I=dQ/dt (instantaneous flow rate) and I=Q/t (average flow over time) is crucial for understanding the concept of current. Clarifying the terminology from "change" to "flow" helps resolve the misunderstanding.
Nikitin
This is a very sound stupid question, but I'll go ahead anyway.
Current is defined as the displacement of charge through a cross-section of a conductor per unit time. Okay. But how does relate to its math-definition, current = change of charge with respect to time, I=dQ/dt? I mean, for every charge leaving the cross-section of the conductor, an equivalent one will enter. This means that across the cross-section dQ/dt, the summed change of charge with respect to time, equals 0!
I find I = Q/t, current = amount of charge passing the cross-section per unit time, a much more intuitive definition..
So can you guys help me make sense of this?
Likes person_random_normal
define a surface boundary. it doesn't have to be a closed surface, but it may be (and if it is, then continuity applies). electric current is defined to be the rate (w.r.t. time) that charge is crossing from one side of that surface boundary to the other. nothing else.
if the surface is closed, then continuity requires that the negative of the rate of amount of charge contained inside the closed surface is equal to the current crossing that boundary from inside to out.
The water analogy for electricity isn't perfect but in effect you are saying..
"for every CC of water leaving the pipe an equivalent amount will enter"
That's true.
However electric current is equivalent to the flow rate of the water through the pipe not the change in volume of water in the pipe.
I=dQ/dt is equivalent to measuring the instantaneous flow rate of the water.
I=Q/t would be more akin to measuring the amount of water used over say a year and dividing acccordingly to give the average flow rate over that period.. or perhaps the total amount of water that has ever flowed through the pipe divided by the age of the pipe.
That word is where your problem lies. If you substitute the word 'flow' then your worry ceases to be.
thanks!
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
