Definition of Image of a linear transformation
says
The image of a linear transformation = columnspace of the matrix associated to the linear transformation.
More specifically though, given the transformation from Rn to Rm: from subspace X to subspace Y, the image of a linear transformation is equal to the set of vectors in X that are mapped to Y. This may or may not be equal to the all of the vectors in subspace X and subspace Y.
I was going to say, the Im(T) = all of the vectors in X that are mapped to Y, but the definition sounds a bit 'muddier', but I'm not entirely sure. Hence my post.
I usually draw a picture like this: http://thejuniverse.org/PUBLIC/LinearAlgebra/MATH-232/Unit.8/Presentation.1/Section7B/image.png to go with my definition, but I wanted to check.
I saw a reference book that said 'the image of a linear transformation f : V → W is the set of vectors the linear transformation maps to.'
The image of a linear transformation ##T## defined by ##T:V\rightarrow W## is the set of all vectors which are the result of the linear map ##T## applied on any vector in ##V##. Which means ##\textrm{Im}(T)## is a subset of ##W##, not of ##V##. In this sense, the last definition:
is the correct one.
No! The "image of a linear transformation" is set of vectors in Y such that some vector in X is mapped to it. Taking the linear transformation to be "T", the image is "all y in Y such that there exist x in X such that Tx= y."
The image is a subset (actually subspace) of Y, not X. It may or may not be all of Y.
Again, no, no, no! Im(T) = all vectors in Y that vectors in X are mapped to it.
The pink area in your picture is the image.
Yes, that is correct, NOT what you said!
2. Homework Equations
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
