Definition of magnetic moments and torques
The discussion centers on the definition of magnetic moments and torques in current loops. The torque on a rectangular current loop is expressed as the cross product of the magnetic moment and the magnetic field. The confusion arises from the factor of one-half in the magnetic moment definition found on Wikipedia, which is necessary for accurate area calculations. Participants clarify that this factor is essential to derive the correct torque and acknowledge a misapplication of vector identities in the initial analysis. Ultimately, understanding the correct relationships resolves the confusion regarding the magnetic moment and torque calculations.
center o bass
When one finds the torque on a rectangular current loop one finds that it's equal to
\vec m \times \vec B
where m is the magnetic moment of the loop. I want to generalize this to arbirary current loops with constant current and I found that the torque would be equal to
\left(I\oint \vec r \times \vec dl\right) \times \vec B
so I would think it would be natural to define
\vec m =I\oint \vec r \times \vec dl
for these current loops. However when it up at http://en.wikipedia.org/wiki/Magnetic_moment" I find that the magnetic moment is defined as
\vec m =\frac{1}{2} I\oint \vec r \times \vec dl.
Where does this factor of a half come into the picture? Is'nt 'moments' supposed to be that what generates torques and not just be proportional to it?
Look closely at your formula, does it give the right area when you take for example a circle? (The factor 1/2 is needed to calculate the area correctly)
That's true. But I do not want the right area, just the right torque. I must admit I am a bit confused. I just saw a derivation of a statement that
\vec r \times (d\vec r \times \vec B) = \frac{1}{2} \left( d\left[ \vec r \times ( \vec r \times \vec B\right] - \vec B \times ( \vec r \times d \vec r ) \right)
Which would indeed solve the problem. But does this then imply that
\oint \vec r \times (d\vec r \times \vec B) = \frac{1}{2} \oint \left( d\left[ \vec r \times ( \vec r \times \vec B\right] - \vec B \times ( \vec r \times d \vec r ) \right) = \frac{1}{2} (\oint \vec r \times d \vec r) \times \vec B?
if so that would imply that
\oint \vec r \times ( d \vec r \times \vec B ) - \frac{1}2 (\vec r \times d \vec r) \times \vec B = 0
and can we not then conclude that
\vec r \times ( d \vec r \times \vec B ) = \frac{1}2 (\vec r \times d \vec r) \times \vec B?
which seems to be a contradiction when I would think that
\vec A \times ( \vec B \times \vec C) = (\vec A \times \vec B) \times \vec C.
I would really appreciate if someone could enligthen me.
When two integrals are the same, that does not necessarily mean the integrated functions are the same. Also, in general Ax(BxC) is not equal to (AxB)xC, always watch out with that. (these are just general remarks)
How did you arrive at your first expression for the torque? (in post #1)
edit: I was a little too fast with this reply, I should add that in this case of course you need the factor 1/2 to get to the right answer, and therefore you will need some identity ;). I suspect you (mis)used that Ax(BxC) = (AxB)xC for your first result?
You're right! That exactly what I did. And that solves my problem. Thank you! :)
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
