Delta-epsilon proof (book example)
  • Thread starter Thread starter OrbitalPower
    Example Proof
OrbitalPower
\lim_{x \to 0} x^(1/3)
I know that \delta = {\epsilon}^3
the book gives an example:
\lim_{x \to 2} (3x - 2) = 4 and you chose \delta = \frac{\epsilon}{3}
so
0 < |x-2| < \delta = \frac{\epsilon}{3}
implies
|(3x - 2) - 4| = 3|x-2| < 3 (\frac{\epsilon}{3}) = \epsilon
so i should get something like:
| \sqrt[3]{x} - 0 | = | x - 0 | = \epsilon
But I don't see how you make the connection between | \sqrt[3]{x} | and (|x - 0|) < \delta and I don't see how I can reduce {\epsilon}^3 to just epsilon using this style of proof.
Think of it this way, start out with|x^{\frac{1}{3}}| and try to get this to be \leq |x| &lt; \delta (we both know the limit is zero ;)). Your choice of \delta seems to be correct. Now given that |x| &lt; \delta what is |x^{\frac{1}{3}}| less than?
Good luck
You are suspecting that x1/3 converges to zero as x approaches 0. So how does one show that. First you pick an arbitrary e>0. Then you want to find an d>0 with the following property.
Whenever you take an x which differs from zero by at most d and plug this x into the function x1/3, you want to get something which differs from the proposed limit, 0, by at most e.
The question is how to choose that d, right?
You want |x1/3-0 |<d for all |x-0|<d. We can simplify this to
|x1/3|<e for all |x|<d, right?
Is the first equation not equivalent to |x|<e3? So, how small an x do you have to choose to make sure that this is certified. Well, certainly an x with |x|<e3, right? So what should d be then?:smile:
Thanks.
I thought we wanted |x^(1/3) - 0 | < e for all | x - 0| < d. I think I see where to go, though.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
